Chasing down a rattle/ chirp/ squeal noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by badweatherbiker, Feb 9, 2022.
  1. Feb 9, 2022 at 8:29 PM
    badweatherbiker
    badweatherbiker [OP] Well-Known Member
    North Florida
    2011 blue Tacoma crew cab 4.0 TRD off road
    Any ideas? Sounds like it's coming from the driver's side when I let the windows down but that could be because I am sitting on that side.
    Around 1700 rpm, sometimes right before idle slowing down. Makes no difference if I shift to neutral or whatever. I am thinking idler pulley? Brakes seem to have enough pad left.
  2. Feb 9, 2022 at 8:46 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    grease the whole chassy
  3. Feb 9, 2022 at 8:47 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Good luck with this. I have a similar squeak as well, sometimes it sounds like it is on the passenger side, but then it sounds like it's on both sides, sometimes it's louder if I roll the windows down sometimes it doesn't.
    I'm starting to wonder if my issue is the body mounts being dry. It is possible I have some metal to metal action going on at the grill though so I don't know.
    As for you, it may be something else. It would be best to state what sort of chirp noise it is and whether or not it sounds like it's metal on metal or not.
  4. Feb 10, 2022 at 12:58 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Pull the belt off and spin and feel each rotating pulley.
    2011 could be all idlers and tensioner , AC comp, alt, PS or not.
    Or simply quess away or just wait and it will get louder and more obvious.
  5. Feb 10, 2022 at 1:05 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    If it sounds behind you Check your carrier bearing. I started getting one recently and yep that sucker is toast. A common failure on 2nd gens too. If it's the front then yah pulleys and such. I'm with @muddog321
  6. Feb 10, 2022 at 8:00 AM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    Mine was a bad alternator at 125k
  7. Mar 17, 2022 at 1:39 PM
    badweatherbiker
    North Florida
    Narrowed it down I think, the reason it was so odd is it was 2 noises. A faint squeal coming from the front turned out to be an idler pulley and a chirp coming from the rear I can prob assume it's the carrier bearing.
    I ordered a carrier bearing and it hit the doorstep today, what's everyones thoughts on replacing the u-joints at the same time? Should I do all 3 or just the rear or wait for them to go later? Truck has 120,000 miles now.
  8. Mar 17, 2022 at 3:03 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I only want to pull the driveshaft once.
    I would do a 3 at the same time. If one is bad, the others are probably not far behind.
  9. Mar 17, 2022 at 3:56 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Is it rotational? Is it RPM or speed based? Greased U joints regularly?
  10. Mar 17, 2022 at 8:41 PM
    badweatherbiker
    North Florida
    Factory u-joints are non greasable
  11. Mar 17, 2022 at 11:46 PM
    Gor1019
    Gor1019 Member
    2010 Tacoma TRD sport
    I need to replace my carrier bearing and u joints. Is there a brand i should go for?
  12. Mar 18, 2022 at 6:42 AM
    badweatherbiker
    North Florida
    I bought Spicer
  13. Mar 18, 2022 at 8:50 AM
    nd4spdbh
    SoCal
    If you are doing the carrier spend the 100 or so on 3 greaseble spicer joints and replace them all considering you will have the tools to take apart one joint to do the carrier
    TnShooter likes this.
  14. Mar 18, 2022 at 9:14 AM
    TnShooter
    Deogee
    STOCK
    I have always liked spicer.
  15. Mar 18, 2022 at 10:34 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    worn exhuast doughnut to muffler makes some squeek chirp noises when slowing down that not fun to pin point, go shake your muffler input under the cab
  16. Mar 18, 2022 at 1:47 PM
    Gor1019
    Gor1019 Member
    What about the carrier bearing, what brand should I get.
  17. Mar 18, 2022 at 2:33 PM
    nd4spdbh
    SoCal
    Spicer for sure
