Chasing extremely poor MPG...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JergenIrwin, Jan 31, 2025.
  1. Jan 31, 2025 at 12:48 PM
    JergenIrwin
    JergenIrwin [OP] Member
    08 Dark pearl blue Sport Tacoma, manual
    D.T. LT headers K&N intake Borla Cat back OME coil lift + Bilstein 5100 URD stage 2 clutch kit Braided stainless steel brake lines
    Hello I've been chasing poor fuel economy for the last year. 08 v6 manual transmission with 209k miles.
    Mods: fuel beast wheels, 265/70r17 ko2.
    DTLT headers with sim, borla cat back, k&n intake.
    For the record, the dive happened long after all of the mods were installed. (3 years roughly) I only ever got 13.5-14.5mpg regularly. However a year ago the fuel economy dropped 11mpg, now I'm at 10mpg. I've had a code for maf and 1 upstream sensor, which was replaced with Denso parts. Mild improvement, but still lower than usual. Since then I've replaced pcv, plugs, injectors, (had new gaskets installed), cleaned throttle body. Checked cats. No codes. Plenty of low end power, but does seem to struggle more on the upper end than it use to. Wheels spin freely, no brakes sticking.
    I'm at my wits end. URD pump kit coming in a couple days, but I'm sick of throwing parts at it with no progress. I noticed an improvement running 1 bottle of lucas fuel system cleaner through it. (A whole 11mpg) but right back down after a second. My usual shop has been too busy to do live data, dealership is a joke... i know that's a long read, but does anyone have ANY idea what else might cause this before the last two things are done?
  2. Mar 13, 2025 at 10:53 AM
    Blade29
    Blade29 Member
    Blake
    2011 Tacoma TRD Off Road
    I really don’t know if you’ve cleaned the MAF and made sure the tires and inflated to the correct pressure. My last fill up I got 15.8 all city but I drove it like a baby to run a test. Not really sure if that’s any good. What is this Lucas fuel system cleaner stuff? Is it known to help improve more than 1 mpg?
    reallifedog likes this.
  3. Mar 13, 2025 at 11:21 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    What are your fuel trims?
    b_r_o and MGMDesertTaco like this.
  4. Mar 13, 2025 at 11:23 AM
    MGMDesertTaco
    02 sensors
    GTGallop likes this.
  5. Mar 13, 2025 at 11:50 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Look for evidence of an exhaust leak at the headers and pipes, like black soot at a gasket or connection. An exhaust leak would allow fresh air into the exhaust stream and can confuse the O2 sensors, driving the system rich
