Chasing Overheating Issue...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AZTaco-86, Jul 14, 2023.
  1. Jul 14, 2023 at 11:19 AM
    #41
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    I'm thinking buildup/blockage inside the radiator decreasing its effectiveness in warmer weather
  2. Jul 14, 2023 at 11:20 AM
    #42
    AZTaco-86
    AZTaco-86 [OP] Active Member
    Bryce
    Phoenix, AZ
    2015 White Tacoma TRD Sport
    it’s a fairly new radiator maybe 6 month old/ 2l miles.
  3. Jul 14, 2023 at 11:42 AM
    #43
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Your ''fine sand'' is likely silicate residue.
  4. Jul 14, 2023 at 11:58 AM
    #44
    Waasheem
    Waasheem
    2007 xrunner
    The sand. When I was younger, I got convinced I needed a new fangled billet coolant filter. At some point I took if off to see what it caught, there was a tiny bit of sand in it. The collective gear head opinion was that it’s from the sand casting when the block was cast.
  5. Jul 14, 2023 at 12:13 PM
    #45
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I have nothing new to add to this discussion other than I would second the recommendation of flushing with distilled water a couple of times and see what comes out.
    This is a question of ignorance, but is there a difference in head gaskets over the years? Is there any chance a water passage is blocked from the gaskets?
  6. Jul 14, 2023 at 12:21 PM
    #46
    steel wheels
    steel wheels Well-Known Member
    2020-ACLB-4x4-Sport-M/T
    I saw where the radiator is fairly new. Lower the coolant slightly below the tubes in the radiator and look for a build up on the tube ends. Your radiator may need to be boiled out by a radiator shop.
  7. Jul 14, 2023 at 12:24 PM
    #47
    jimmy c
    jimmy c Well-Known Member
    jim
    Port St. Lucie Fl.
    2015 tacoma
    I would second checking the condensor. Also check the ac pressures. Is high and low side within specs. i live in south florida, our normal temp readings very from 200-220 deg over that i would get concerned. Putting a secondary electric fan in from of condensor is not a bad idea. A good one you can set to come on at a certain temp, say 200 and should maintain that or go lower. would also help the ac greatly.
  8. Jul 14, 2023 at 12:33 PM
    #48
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    Your first post mentioned a Brand new cooling system...what does that included? Radiator and water pump? Or just radiator? What about the heater core? If you have sediment in the coolant, maybe it is really collecting in the heater core and there is a blockage there? As Someone said before, flush, flush and more flush, until absolutely clear.
    I am thinking it is something thermostat related, I know you said you already replaced, but try again and double check.
    Also what about your full list of mods?
    On a footnote, as you can see I have 2 large offroad lights that significantly block my radiator and I have no overheating issues in South Texas with daily 106 heat (I have the towing package radiators). I know AZ is slightly hotter, but I as a reference I think our Tacomas coolant system is very effective and well made.
    Good Luck, and we are all here to help out best we can.
  9. Jul 14, 2023 at 1:37 PM
    #49
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Towing package radiator isn’t a thing. They all have the same radiator
  10. Jul 14, 2023 at 1:44 PM
    #50
    Primo 95
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    Let me clarify, mine has the towing package transmission cooler...so there is an another small radiator in front of the main coolant radiator on the driver side.
  11. Jul 14, 2023 at 5:35 PM
    #51
    Primo 95
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    105 today in S TX, and mine stayed in the middle of the temp gauge. for those of you with an ultragage, what actual temperature does that equate to??
  12. Jul 15, 2023 at 3:39 AM
    #52
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    EXACTLY, not actual sand, but rather decomposed coolant debris and engine corrosion debris.
  13. Jul 15, 2023 at 3:50 AM
    #53
    PMK
    Florida
    10 DCLB TRD Sport
    South Florida, temps are pretty warm currently. My truck still operates at 190*f max coolant temp. I run a dedicated trans cooler and no transmission fluid enters the radiator.
    I have purchased the items to do a flush and fill of the cooling system. Recently, I tried that billet thermostat housing setup. Total waste of money as it is improperly designed. During that install, when draining coolant, I too had silica sediment in the bucket. Previously over the years of ownership since new, the truck has had two flush and refills in the 95k miles since new.
    For this flush and refill, I will accomplish a Thermocure flush with distilled water. Then second distilled only flush, followed by refilling with 50/50 Peak coolant. Yes, again, I will remove both engine side drain plugs for a complete flush.
    On a side not, while contending with the POS billet thermostat housing, the increased temps from that had me question my oem radiator. That was replaced with an all aluminum radiator from URD. Even now with the oversized cooling system, temps are the 190*f as before.
  14. Jul 15, 2023 at 7:12 AM
    #54
    davep2012
    davep2012 Well-Known Member
    Dave
    2012 Silver Tacoma
    Weather Tech floor mats and Marathon Seat Covers
    -I agree with more flushing to remove silt/silica that could be plugging up the new radiator.
    -Also, with the engine good and hot (before doing additional flushing) check around the seams of the new radiator where the tanks are crimped/glued to the core and look for any signs of moisture.
    -After the final flush and fill is completed, you might add a bottle of Water Wetter for good measure.
    https://www.amazon.com/Red-Line-802...locphy=9028784&hvtargid=pla-334077729758&th=1
  15. Jul 15, 2023 at 10:15 AM
    #55
    TacoTuesday2165
    TacoTuesday2165 Active Member
    David
    05 TRD Sport DCSB What, Me Worry?
    Interesting comment to note on Amazon's page, I did find one that may be helpful to some TW owners:
    "...After doing a crap load of research on the topic of coolant mixtures and temperatures associated with different mixtures, I decided to drop the coolant mixture down to 25% coolant, and 75% distilled water. I actually got this ratio from Redline's technical sheet on this product. If you read the information on this product and look at the dyno testing they did, you'll see that they saw the biggest temperature drop when this product was added to pure water, and the temperature climbed slightly with more and more antifreeze added. That's exactly what's supposed to happen.
    Modern cars use a 50/50 mixture from the factory so that the cooling system can operate in any climate. A 50/50 mixture gives you optimal protection from freezing while not raising the temperature too high. If you were to just run straight anti-freeze the temperature in the cooling system would spike dramatically. But if you were to run just straight water all the water would boil out, you also would have no corrosion inhibitors.
    Basically what I'm getting at is that if you want to see results with this you should run a 75/25 mixture and a bottle of this product. And read the technical sheet on this product...
    Happy tinkering."
  16. Jul 15, 2023 at 11:46 AM
    #56
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Welcome to the forum :hattip:
    Running only 25% coolant only gives freeze protection down to about 10 degrees above zero. While 10 degrees sounds really cold and obviously not that common in AZ it isn't unrealistic that the OP might encounter a temperature that cold on a weekend getaway trip for example.
    Some years ago a friend was scraping his windows (northeast) as his truck warmed up, he heard several odd cracks and suddenly steam erupted from under the hood.
    He knew his old antifreeze wasn't quite the best and thought "it should be ok".
    It was a carburetor equipped truck running on fast idle, the engine was cold so the thermostat was still closed.
    The truck had a towing package with a full fan shroud and a big 7 blade fan.
    The cold winter air rushing through the radiator with no circulation (closed thermostat) pulled the temperature of the substandard coolant low enough that it froze, water expands about 9% when frozen - the radiator obviously expands 0% and it burst the radiator core in multiple places.
    He got lucky, only the radiator was damaged - about $400. :eek:
    I did have some small satisfaction mentioning the high cost of deferred maintenance.
    :boink:
  17. Jul 15, 2023 at 11:54 AM
    #57
    TacoTuesday2165
    David
    TY! This place is a wealth of information and the main reason for purchasing my new (to me) old taco. Best of luck! @AZTaco-86 [OP]
  18. Jul 15, 2023 at 12:22 PM
    #58
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Another problem (arguably larger) with running a reduced percentage of coolant is reduced corrosion protection.
    Coolant doesn't wear out in the sense that it becomes "freezable" so much as the additives that provide corrosion protection become depleted.
    Modern engines are mostly made of aluminum which is highly susceptible to corrosion, the coolant "works harder" to protect these engines than the heavy cast iron engines of the past.
    The only thing protecting the head gaskets is the additives in the coolant, replacing head gaskets is an expensive job, coolant service is fairly inexpensive by comparison.
    Steves104x4 likes this.
  19. Jul 15, 2023 at 12:23 PM
    #59
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    One thing I have learned is new doesn't always mean its good.
    I had a Volvo in the shop once with a similar complaint, the temp would spike after a run on the highway and coming to a stop. The radiator had been changed the prior winter due to a leak so I was sure it was an airflow problem. We proceeded to replace the fan clutch since you could not hear the roar of it kicking in. Then I went after the antifreeze/water concentration. Still had the issue.
    Long story short it was the radiator. I don't know what brand it was but it simply could not transfer enough heat fast enough when sitting still after a heavy load on the system.
    I feel your pain, cooling seems to be a pretty straight forward system but strange things will throw you for a loop.
    I also had a temp spiking issue that was related to the plastic impeller on the water pump not being tightly secured and was spinning on the shaft. It was intermittent too, it drove me nuts.
  20. Jul 15, 2023 at 12:30 PM
    #60
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
