Chattering sound from engine bay
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LMC, Jan 14, 2021.
  1. Jan 14, 2021 at 7:08 AM
    LMC
    LMC [OP] Well-Known Member
    2015 Black Tacoma TRD Sport
    There is a weird chattering sound coming from my engine bay when I start my truck when it's cold. Once my truck is warm it stops making the sound. I have a 2015 tacoma with 103 k on it
    Any ideas ?
    Gunshot-6A likes this.
  2. Jan 14, 2021 at 7:10 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Chipmunks? Squirrels mating?
    Seriously, make a close inspection of the serpentine belt, idlers, tensioner......also all the belt driven components.
    LMC[OP] likes this.
  3. Jan 14, 2021 at 11:59 AM
    TacoTime10
    TacoTime10 Well-Known Member
    New Hampshire
    2010 ACLB 4x4 SR5 2.7L 5MT
    2021 TRD OR wheels and tires, bed stiffeners, fog lights
    Maybe it’s the emissions air pump? Mine spins up until the engine warms up and then shuts off.
    LMC[OP] likes this.
  4. Jan 14, 2021 at 12:00 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Probably an idler. i have a similar issue and it is an idler that makes noise on cold mornings. After running for a couple minutes it's gone
    LMC[OP] likes this.
  5. Jan 14, 2021 at 12:01 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Chatter or more of a plasticly rattle down by the gas pedal part of the engine bay? I get the same thing when it's cold, but never have been able to really track it down.
    LMC[QUOTED][OP] likes this.
  6. Jan 14, 2021 at 1:22 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    mine makes clackity sounds on the first startup of the morning, always has, uses no oil never an issue... just run it.
  7. Jan 14, 2021 at 1:30 PM
    LMC
    Appreciate all the help !
  8. Jan 14, 2021 at 4:52 PM
    Normshark
    Normshark Well-Known Member
    Great White North
    2014 Tacoma DCLB Limited
    Sounds like a belt or idler. My Tundra has an idler that is noisy when it's really, really frigid but goes away in about 5 minutes. The noise is a little more high pitched. Chattering, like chipmunks or squirrels mating, is not uncommon when belts are starting to reach their end of life.
    Cheers.
    LMC[OP] likes this.
  9. Jan 14, 2021 at 4:57 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    At least replace the tensioner pulley for $30, now instead of waiting for it to explode and fuse itself together forcing you to replace the tensioner assembly for $130 plus probably a new belt. Good luck!
  10. Jan 14, 2021 at 5:13 PM
    LMC
    Good idea ! I'll do that thanks !
    Steves104x4 likes this.
