Cheap Bumpers on eBay!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ColeRedRubi, Jun 22, 2016.
  1. Sep 12, 2019 at 10:14 AM
    #7441
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    I got this one https://www.amazon.com/gp/product/B019XV6S8O/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    I do believe there are superior brands of LEDs, I do not believe those call for 3x+ the cost. Not a single Nilight light I have/had on my truck ever lost more than 1 led or fogged so badly I couldn't reseal them if needed. They, too, have their own warranty dept and will happily replace them.
    MattCowsmasher, txtaco87 and saundern like this.
  2. Sep 12, 2019 at 12:44 PM
    #7442
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    I’m running the same one, and I had to drill holes to mount it using the brackets it came with as the outermost pre drilled holes wouldn’t line up for it. Measured 3 times drilled once, hit it with black rustoleum and bolted it in. For $599 I can’t complain. Eventually I’ll swap to a BFF hybrid bumper but I feel safer in the Houston traffic for now
    25B6DBA5-7AA5-479A-9BA1-457013980915.jpg 360D374E-2209-4B88-8178-EA08C88C96E8.jpg
  3. Sep 12, 2019 at 1:01 PM
    #7443
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    ^^ Nice grill dude! ^^
    MattCowsmasher and txtaco87 like this.
  4. Sep 12, 2019 at 1:29 PM
    #7444
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    Much appreciated, it’s the grillcraft mx series, simple but I like it. Cut out the center and it bolts in.
  5. Sep 12, 2019 at 2:42 PM
    #7445
    RufusMiles
    RufusMiles Member
    Tommy
    Newbury Park, CA
    2013 4x4 Tacoma
    K&N CAI, MBRP Cat Back Exhaust.
    Thanks guys for the input on the light bars
    txtaco87 and MattCowsmasher like this.
  6. Sep 12, 2019 at 3:02 PM
    #7446
    dirty deeds
    Nick
    Eastern KY
    Yeah, I forgot to mention you do have to drill holes for it. A 20" should line up right, but I couldn't find a single row 20", so the single row nilight won.
  7. Sep 12, 2019 at 3:10 PM
    #7447
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Alexely999 and txtaco87 like this.
  8. Sep 13, 2019 at 7:44 AM
    #7448
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    I ordered one of those in nilight brand identical to it, while it did allow the adjusters to line up with the pre drilled holes, on the new 5pc design, the hoop wouldn’t allow it, it jammed into it. Which is why I had to buy a single row and drill the new holes lol. But the 3/16 steel was easy enough to drill through.
  9. Sep 13, 2019 at 7:46 AM
    #7449
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    Haha it’s all good, I made it work! And I dig it. But for all those who order this light, place the light where you want it, measure measure measure then drill your holes! And the new holes you make should be just outside the outermost pre-drilled holes
    dirty deeds[QUOTED] likes this.
  10. Sep 13, 2019 at 7:53 AM
    #7450
    txtaco87
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    In the pictures above on mine for fog lights, I went with the nilight flood light led pods, I have a set of round ones but didn’t feel like making a separate bracket at this time for it to work. And the nilight cubes required me to put 3 washers between the bracket tab and the light to space them up and center in the hole. The bolt was long enough and still has thread after I tightened down the nut/washer and lock washer underneath. If you need a pic of it let me know and I’ll take one for you from the backside.
  11. Sep 13, 2019 at 11:34 AM
    #7451
    RufusMiles
    RufusMiles Member
    Tommy
    Newbury Park, CA
    2013 4x4 Tacoma
    I probably got the same nilight as you. With the mounts it wasnt going to fit. So I came here and asked my question to see what everyone else uses.
  12. Sep 13, 2019 at 11:38 AM
    #7452
    RufusMiles
    RufusMiles Member
    Tommy
    Newbury Park, CA
    2013 4x4 Tacoma
    I found some 3.5in. round pods that fit. Though, I did need a washer on the under side of the bracket for the nut. Could have put some washers under the light mount, but the bolt/nut for the light and.moint rest on the sides of the bumper bracket. Figured that was good enough.
  13. Sep 13, 2019 at 11:44 AM
    #7453
    RufusMiles
    RufusMiles Member
    Tommy
    Newbury Park, CA
    2013 4x4 Tacoma
    This fits under the hoop?
    Might have to switch to this one.
    Was thinking about possibly puting the nilight back a bit and drilling new holes for it.
  14. Sep 13, 2019 at 12:09 PM
    #7454
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Under the scoop no,on top of the bumper under the center hoop.
  15. Sep 13, 2019 at 12:25 PM
    #7455
    dirty deeds
    Nick
    Eastern KY
    I think I had seen posts about the 20"+ double rows not fitting inside the hoop as well. Also why I went with the single row.
    txtaco87[QUOTED] likes this.
  16. Sep 13, 2019 at 1:32 PM
    #7456
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I had a 21” under the hoop. Fit fine with new holes
    txtaco87 likes this.
  17. Sep 13, 2019 at 1:37 PM
    #7457
    RufusMiles
    RufusMiles Member
    Tommy
    Newbury Park, CA
    2013 4x4 Tacoma
    Yea, that's what I meant. On the bumper, under the hoop. Not on top of the hoop.
    Aesthetically I like way the double row light bar looks. So, I'm gonna return the nilight and getbthat one
  18. Sep 13, 2019 at 1:39 PM
    #7458
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Sweet :bananadance:
  19. Sep 13, 2019 at 2:49 PM
    #7459
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    What winch did you put in yours? I saw harborfreight has their badlands 12500 and you can put a 3 year warranty on it for like 400$
  20. Sep 13, 2019 at 4:41 PM
    #7460
    RufusMiles
    RufusMiles Member
    Tommy
    Newbury Park, CA
    2013 4x4 Tacoma
