Cheap but durable Snow Plow for Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kevinztaco, Dec 7, 2016.
  1. Dec 7, 2016 at 9:24 PM
    Kevinztaco
    Kevinztaco [OP] Well-Known Member
    none yet
    Any out there?
  2. Dec 7, 2016 at 9:31 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    I didn't research it all that much but I remember reading that the frame isn't the best for a snow plow. Might want to look into it. I think the concern wasn't so much with the slow buildup of snow, but if the plow accidentally contacted something such as a curb, or rock.
  3. Dec 7, 2016 at 10:14 PM
    DistortedAxis
    DistortedAxis Well-Known Member
    Toronto
    Desert Sand Mica, 2006, V6, 6SPD Manual, SR5, DCSB, 4X4
    STOCK
    Cheap and durable don't go together when looking for a plow setup. Plenty of Taco plow trucks out there. Mid-size trucks handle a lot of the inner city and park work here in Toronto. I'd look at a poly blade. I wouldn't go over 7 ft blade. Find a plow with adequate down pressure, otherwise you'll just outgrow it. Fisher & Western are great brands. Every plow will break -- key is finding a supplier that can get parts in quickly.
    You should expect to shell out $4000-5000 for a "good" plow system. http://www.arcticsnowplows.com/snowplows/poly-snowplows/standard
    YMMV if you find a used plow, but buyer beware; No such thing as a "used" plow in "good" shape....
    Unless it was never used...
    Remember, plows are heavy. You will need to also upgrade the front suspension to handle the weight. 400-500lbs of weight added to the front of the truck.
    Other things you will need; Good Snow Tires, Lights ( usually the standard plow lights are horrible) and a signal light (usually required by law in most areas).
    Kevinztaco[OP] and Naveronski like this.
  4. Dec 8, 2016 at 6:55 PM
    Kevinztaco
    none yet
    Good point. That's true for just about everything. Isn't it?
  5. Dec 8, 2016 at 8:43 PM
    Bobcdn
    Bobcdn Well-Known Member
    WTB; 2nd gen well built Tacoma
