Cheap clean inside glass?
Discussion in 'Detailing' started by pinktaco808, Jun 8, 2018.
  1. Jan 30, 2019 at 4:28 PM
    #41
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Nope !!!!! , I've got tinted windows and started using invisible glass on the tinted windows and windshield
    Hamer95USA likes this.
  2. Apr 19, 2019 at 9:32 AM
    #42
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    Any of the Foaming glass cleaners work well unless in direct sunlight, then it evaporates quickly. Otherwise I use either ONR, Megs D120 or Vinegar/Isoporpyl Alcohol/Distilled water mix. If you use any dillutable chemical then use distilled water...this will help eliminate water spots if it dries. Also, the Megs D120 will last FOREVER and smells like blueberries! Mixes 10:1 and you can only get a gallon, also strictly adhear to the dilution ratio or you can get some streaks as well.
    These towels have been a life saver also. When you wash microfiber towels use ALL Free and Clear and if they are really bad, a little bit of dawn or pre-soak. Dry on LOW (anything over 140 degrees can start to melt the microfibers and will not absorb anymore) with NO DRYER sheets,NEVER use a softener of any kind or powder detergant.
    https://www.theragcompany.com/premium-korean-microfiber-16-x-16-blue-glass-and-window-towel/
    pinktaco808[OP] likes this.
  3. Jun 26, 2019 at 10:29 AM
    #43
    spicytacos
    spicytacos Well-Known Member
    2017 Cement Tacoma TRD Pro
    Invisible glass (the pressurized aerosol one) is the best I've found
    pinktaco808[OP] and ace96 like this.
