Cheap DIY Shell Roof Rack
Discussion in 'Tonneau Covers, Caps and Shells' started by WormSquirts, Feb 22, 2017.
  1. Feb 22, 2017 at 10:38 AM
    WormSquirts
    WormSquirts [OP] Armageddon
    Braeden
    BC
    A while ago, I needed to put a roof rack on my rack-less Leer 100xq canopy. I wanted a system that used tracks, and a rack that slides in them, rather than hard mounted towers. I checked out all the usual suspects, Thule, Yakima, etc. and found that just the tracks cost around $250 (CAD) and then the towers, cross bars, and locks were an additional $600 or so. There's no way I could spend that kind of money, so I decided to go a different direction.
    I headed over to the Pick n Pull, and searched around looking for anything that might work. What I found was a very large number of Ford Windstar minivans with stock roof racks on them! The crossbars themselves are basically useless for anything more than maybe 1 ski, but the tracks they slide in are absolutely perfect. Five bolts each to remove them, $10, and I was out the door!
    Cleaned them up, and they were the exact right length for my Long Bed.
    To install, I measured them to be about equal front to back. I discovered that the canopy isn't straight, but sort of tapered towards the back, so I measured across to make sure the tracks would remain parallel to each other, so I could slide my rack up and down as needed. I drilled through the canopy and used 1/4" bolts, fender washers, nylock nuts and silicone to bolt them on and make sure there were no leaks.
    BONUS: As a little side note, I used longer bolts than I would need for mounting the tracks to the cap, so that I would have extra threads on the inside of the canopy. These I used to bolt up some cheap stretchy netting on the inside so I could throw blankets or sleeping mats or whatever light thing you can think of up on the top out of the way. Netting: https://www.amazon.ca/gp/product/B011ARI7TC/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 I just used fender washers and wingnuts to attach it!
    From here, you can just buy regular Thule or Yakima towers and crossbars, and call it a day knowing you saved yourself about $240. I decided to carry on and build my own rack as well. The reason was I wanted the rack to be as low profile as possible for my roof top tent. The bought racks generally end up being about 5-6" high, and that wasn't going to work for me. That and I didn't really want to spend $600 bucks.
    So, with the tracks complete, I moved on to the rack itself. I bought 10' of 1" square tubing, and had some 1" flat bar lying around. All in all I think I spent about $80 on steel and bolts etc. For this part, I'm sorry I don't have many good pictures.
    I cut 8 sections of flat bar 3" long. I did have to grind them down just slightly narrower to slide easily in the tracks.
    Taking 8 - 5/16x1" bolts, I cut the heads off. I then drilled 2 - 5/16" holes through all of the pieces of flat bar, about 1/4" in from each end. Taking 4 of these pieces, I welded my studs into the holes so I had 4 pieces with 2 studs each, something like this: _||____||_ . These would be what slide in to the tracks.
    I then built the rack part using the 1" square tubing. These you can make as wide or narrow as you want. I ended up going with 56" wide so I would have some more mounting options even with the RTT on. You can also go as high or low as you want. I went with towers 1.5" tall (2.5" from the track to the top of the crossbar, or 3" from the canopy to the top of the crossbar). I decided on this height to accommodate for the cab of the truck. I don't know if AC are the same, but my DC raises up a bit towards the front. I wanted to be able to put long things on my rack, with out it hitting the roof. However, I also wanted the rack to be as low as possible. This is the height I settled on, but your mileage may vary. This 1" steel square tubing is quite strong. I propped it up on either end and stood my 180lbs in the middle, and we couldn't see any deflection at all.
    From here, the rack was a simple matter of welding the tubing together with 2 supports per cross bar, and the remaining 4 pieces of flat bar with holes in them as feet on each upright. Paint or powder coat or whatever you want to do (I spray painted), then finish off the rack with 4 end caps from Home Depot to give it a nice clean look.
    Now you can slide the four pieces with the studs into the tracks. Take your crossbars and line up the feet with the slides, and use 8 nuts to bolt them down, squeezing the tracks in between the 2 pieces of flat bar.
    And for a grand total of $100, and a few hours of time, you're done! I've now been using this set up for about 8 months, and have done hundreds and hundreds of km's of nasty dirt roads with my RTT on, and had no problems what-so-ever. Also, I will admit that I once forgot that I had the RTT on, and drove into an underground parking. That is A) a mistake I will never make again B) really super embarrassing, and C) a testament to the strength of the rack and canopy set up!
    If you have any other questions, let me know and I can grab more measurements or pictures!
    (I'm not sure why my third brake light looks blacked out, but it's not...
  2. Feb 22, 2017 at 11:10 AM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    @ETXTacoma This guy has a RTT on a shell with windows...
  3. Feb 22, 2017 at 12:00 PM
    ETXTacoma
    ETXTacoma Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
    But I think he also has a shell that can handle the weight of one.
    I would love to have a RTT on the truck, but would much rather have a shell that has the reinforced roof.
  4. Feb 22, 2017 at 1:40 PM
    WormSquirts
    Braeden
    BC
    Mine is just the regular Leer 100xq, it's not reinforced. They do have a reinforced one as well, but this isn't it. No problems with mine, and there are a few other people on here that have the same with no trouble. Could be different for you though.
  5. Feb 22, 2017 at 1:47 PM
    ETXTacoma
    Steven
    Tyler, Texas
    If mine was brand new, I would be fine with having a RTT on it. But since it is used, I was like ehhhh....
    Someday I want to get a trailer to run a RTT on, until the... going to get an Oz-Tent
  6. Feb 22, 2017 at 3:19 PM
    WormSquirts
    Braeden
    BC
    Oz tents are pretty slick too. Pros and cons.
    My shell is around 10 years old and came with the truck which I bought used as well, if that helps you at all haha
    dziner likes this.
  7. Feb 22, 2017 at 3:41 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I bought the 100XQ and just paid the $200 for the tracks because they reinforce the shell at the factory to handle add'l weight. I like to DIY most things but I didn't want Leer to have a leg to stand on if I ever have a warranty issue.
  8. Feb 25, 2017 at 7:23 PM
    sherstcp
    sherstcp Well-Known Member
    Calvin
    Seattle
    '11 Pyrite TRD Sport
    OME 3" lift, BFG's, more to come soon...
    Ooooo finally! I have been trying to decide which canopy to buy for the past two weeks due to load restrictions for a rooftop tent. Everyone keeps giving me different answers. Did the Leer dealer tell you that the XQ with tracks would handle more weight? How much?
  9. Feb 27, 2017 at 2:00 PM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    Very cool.
    I need to do this for mine.
    WormSquirts[OP] likes this.
  10. Mar 12, 2017 at 8:50 AM
    jessetoedtman
    jessetoedtman Well-Known Member
    Jesse
    San Diego
    2010 Tacoma SR5 DCLB 4x4
    Good idea on the light at the bottom of the rear hatch! What light did you use?
  11. Mar 12, 2017 at 11:24 AM
    WormSquirts
    Braeden
    BC
  12. Mar 12, 2017 at 6:59 PM
    jessetoedtman
    Jesse
    San Diego
    Thank you- going to order some up!
  13. Mar 12, 2017 at 10:29 PM
    TangoKilo
    TangoKilo Well-Known Member
    Republic of Alberta
    2007 TRD 300,000Km
    Do you have a part number for these square tubing end caps from the Home Depot?
    I've been searching their website for a while with no avail....
  14. Mar 12, 2017 at 11:28 PM
    WormSquirts
    Braeden
    BC
    TangoKilo[QUOTED] likes this.
  15. Mar 26, 2017 at 6:49 AM
    motohevy
    motohevy Well-Known Member
    Podge
    Charlotte, NC
    '14 Tacoma DCLB 4x4
    For what it's worth, I contacted Leer a month or so ago to inquire about the dynamic weight limit of a 100XQ since they're reinforced from the factory. Per Leer's response, the roof of the 100XQ is rated for #250. That's a considerably higher number than the #160 limit advertised by Leer for their factory installed Thule racks. Given how people tend to exceed "limits" in most, if not all, instances, a near 40% reduction by Leer in the Thule rack load limit seems to make sense.
    So, my understanding from discussions with a number of individuals in the industry is that if static loads are not provided by a manufacturer, they may be "safely" (please consider the term relative) calculated by multiplying the dynamic load by a factor of 2.5. Using this method, the 100XQ shell, based on Leer's 100XQ dynamic load rating, should have a static weight limit up to #625.
  16. Oct 9, 2020 at 9:20 PM
    Kiltman
    Kiltman New Member
    2011 double cab 4x4 black
    This is absolute genius. I have been running a number of ideas around in my head and had thought of something like this at one time (along with many more). I lack some of the skills, eg welding, that you have but perhaps I can convince someone to help me. I also love the idea of $100 instead of a huge cost. Thanks for sharing mate. Cheers, Chris from northern Alberta.
  17. May 8, 2021 at 1:40 PM
    TacoManSam
    TacoManSam Well-Known Member
    Sam
    Saint Augustine, FL
    2013 White Tacoma TRD Sport DCLB V6 4x4
    Faux TRD Pro Grille | 3rd Gen TRD-OR suspension | 6' Leer Topper | Running Boards
    Nice write up, bro!!! :thumbsup:
    I'm looking into installing a truck topper tracked based roof rack system and I wish I knew how to weld so I could fabricate something like this. :p
    But excellent write up and "how-to". I'll have to keep my eyes out for some Ford Windstar tracks for sure! :D
  18. Aug 27, 2021 at 10:01 AM
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    I may have to visit my local pick-a-part and browse the minivan section...
  19. Aug 29, 2021 at 5:43 AM
    Andiamo
    Andiamo Well-Known Member
    I’ve always wanted to do something like with the net
  20. Sep 17, 2022 at 9:13 PM
    tonyv1996
    tonyv1996 New Member
    Tony
    2009 Short Bed 4x4
    Hey WormSquirts, love this setup and looks wicket on your rig, I have a 2009 shortbed with the shell and just picked up a Tupei Explorer 3 weighing in at 130lbs, just wondering how your shell is holding up? going to mount the roof rails i scored from the junkyard and start to fab the roof rack this weekend. Just want to see how yours is holding up on the topper, I did my readings and i did purchase bed stiffiners to help with the added weight on the shell, it will be me and my misses sleeping up there so about 300lbs combined, plus the 130 for RTT (430lbs Total). Cheers!
