Cheap Dome Light Mod!!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by wesb1023, Mar 11, 2012.
  1. Mar 11, 2012 at 5:23 PM
    wesb1023
    wesb1023 [OP] Well-Known Member
    Westley
    Eastern NC
    04 Double Cab
    OK guys, I wanted more light inside my truck but didnt want to use a LED bulb, so this is what I came up with.:D
    The only parts you will need is a small length of wire and two radio shack 12V diodes. Parts total cost is less than $4.00.
    Solder the diodes to the wire with the band on the diode positioned towards the wire. Then heat shrink this connection.
    Now install the wire and diodes into the front mirror/light assembly. Light assembly will need to be removed for this to be done. Carefully place the diodes and solder them to the black wires on both map light switches. Make sure the naked wire is not touching ground anywhere. Then route the new wire out the hole in the bottom of the mirror assembly.
    Now cut the wire and install a wire connector. This will allow you to easily remove your mirror assembly in the future. Use insulated wire connectors or heat shrink them. This is the ground circuit for the lights so its nothing serious if the wire touches ground anywhere. The worst thing that will happen is the light will continue to burn. Just make sure they are all insulated.
    Connect another wire connector to the remaining wire and heat shrink. Install the wire in the truck. I used a clothes hanger and fished the wire over the headliner to the middle dome light.
    Sorry for the fuzzy pic, connect the new wire to the black wire with the white tracer. I used solder and electrical tape. Now put the lights back together and presto!!!!
    All three lights come on when the door is opened!!!!!:D
    This is where the diodes come into play. This mod can be done with out them and getting in and out of your truck will be perfect. However, while riding down the road if you push one map light switch, it will turn on ALL THREE lights!! So the purpose of the diodes is to allow for proper map light function. :rolleyes:
    So what do you guys think?
    bcraws, Toyomonkey59 and jrallan26 like this.
  2. Mar 11, 2012 at 5:34 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Nice work. :thumbsup:
  3. Mar 11, 2012 at 5:46 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Great tip!
  4. Mar 11, 2012 at 6:04 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    :thumbsup: for thinkin' outside the box.
    Good Mod, Thanks for the Write-Up
    CC
  5. Mar 12, 2012 at 6:12 PM
    wesb1023
    Westley
    Eastern NC
    04 Double Cab
    Thanks guys, it really came in usefull this am with the time change and all, its dark:30 when I leave for work!
  6. Feb 12, 2013 at 10:18 PM
    losers101
    losers101 Well-Known Member
    Brandan
    Texas
    96 4x4 V6 LX
    K&N CAI, Magnaflow 14", pioneer headunit, 4 kicker 6 1/2, dual 8" kicker subs in tool cubbies, JL amps, Donahoe coilovers, allpro 3" leafs, trail-gear 5.5" greasable shackles, custom plate bumper, warn M8000
    I just installed map lights into my 96 Tacoma from a 4runner and did this mod in the process, works great!!
  7. Feb 21, 2013 at 1:40 PM
    ExOkie
    ExOkie Well-Known Member
    Gary
    Denver Metro
    02 Red TRD
    Deckplate Mod, Airaid Intake Hose and Filter Kit, Leer 100R Camper Shell, WeatherTech floor mats, WeatherTech bug deflector, WeatherTech window deflectors
    This is too cool! Thanks!
  8. Nov 23, 2015 at 10:17 AM
    Maestro
    Maestro Well-Known Member
    The Master
    Great work!
    Nothing beats LEDs though - I can no longer tolerate the dim orange glow of the old bulbs now that I have grown accustomed to SEEING everything in my cab!
  9. Nov 23, 2015 at 6:36 PM
    ThunderOne
    ThunderOne I was here before your Tacoma was even born
    Mitchell
    Nashville, TN
    1ST GEN OR GTFO
    Just have to FIND a radio shack, the most difficult part of the whole project. :)
  10. Nov 24, 2015 at 9:13 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    my 2000 sr5 has a switch for door on/off in the middle of those two black push button and also the center dome. :bananadance:
  11. Jan 21, 2017 at 11:38 PM
    BThorson
    BThorson Well-Known Member
    Oregon
    2003 red Tacoma TRD 5speed
    3" toyotec coils, wheelers progressive leaf, bilstien 5100, pro comp wheels, 285/75r16 cooper st maxx, grey wire, weather tech, floor mats, bug deflector and rain guards, old man bed shell, tint
    awesome write up. I am going to do this ASAP my 1990 Toyota PU had the option to have maps light on with doors. It has always bugged me that my tacoma does not.
  12. Jan 22, 2017 at 7:34 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Hu, that's really weird not all of our Tacoma's have the 3rd button to have the option of lights on or off with the door open...if i were callin the shots at toyota they would all have that when built if nothing more than just a money thing, all would be the same so different parts and such wouldn't cost extra $$! They would all have the third switch like my trucks have! Those guys at toyota sure had weird option differences! One thing.that really made me go wtf toyota, was on certain trucks ESPECIALLY the 01-04's not having a tach! Stupid having to make different parts but they really looked stupid with just a giant speedo and a big temp and gas guage on either side! I know that configuration was around from the get go but to still have it around on the last of the 1st gens seemed so silly....
    BThorson likes this.
  13. Jan 1, 2018 at 4:13 PM
    wesb1023
    Westley
    Eastern NC
    04 Double Cab
    My radio shack diodes went bad after a year or so. I asked one of my coworkers if they had any laying around. He handed me a diode trio that he found in the parking lot. I installed it and it’s worked ever since
