Cheap Floor Mat Retainer Fix
Discussion in 'Technical Chat' started by tacoman355, Sep 29, 2011.
  1. Sep 29, 2011 at 11:49 AM
    tacoman355
    tacoman355 [OP] WORD!?!
    Tyler
    Hampton,VA
    03 Reg Cab Taco
    sold....
    I have a floor mat retainer hook in the driver side floor that holds the floor mats in place. I pulled my floor mats out one day and the grommet that holds the small hook that is found under the carpet broke. I'm sure I'm not the only one who this has happened to them and I searched and couldn't find the part to replace it or any way to fix it so me and matt "bandit" figured out a cheap easy way to do it. We got two washers that were a tight fit at the bottom of the hook, that way it won't just slip out of the hook. We then put one of the washers on the hook and pushed it through the carpet. I pulled the scuff plate up so I could get under the carpet in order to place this washer on to the hook so you have two washers on the hook holding the carpet in between. Put the scuff plate back on and you'll have this.
    This allows the hook to swivel the way it should. No one wants this ugly washer showing so I found the best thing I could to cover it up.....
    ......weathertechs. now your done and your floor mat retainer holds the mats in place like they're supposed to.
    lo2hi likes this.
  2. Sep 29, 2011 at 12:20 PM
    TreyTRD
    TreyTRD Well-Known Member
    Trey
    Tennessee
    16 T4R TEP and 13 FJ
    Toyota sells replacement ones, I believe they're just a couple dollars, thats a neat idea to fix it yourself though.
  3. Sep 29, 2011 at 12:48 PM
    tacoman355
    Tyler
    Hampton,VA
    03 Reg Cab Taco
    sold....
    I think it works just as well if not better. Pretty easy also
  4. Sep 29, 2011 at 1:33 PM
    TreyTRD
    Trey
    Tennessee
    Yeah I'm sure that metal is stronger cause the replacement one they sell is plastic.
  5. Sep 29, 2011 at 1:43 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    good fix...thanks for sharing!
  6. Oct 14, 2012 at 2:23 AM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    I had a broken one and my dealer parts dept gave me two for free.
  7. Nov 4, 2016 at 10:18 AM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    Can't see the pictures but 3/4 of my retainers are broken and i'd like to fix it
  8. Nov 4, 2016 at 10:36 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Why I absolutely hate PhotoBucket and other image service sites. Why not use TW attachments/galleries?
    AR15xAR10[QUOTED] likes this.
