Cheap/Free Mods
Discussion in 'Technical Chat' started by piercedtiger, Dec 28, 2007.
  1. Nov 15, 2018 at 11:46 AM
    #2241
    Coffeeholic
    Coffeeholic Well-Known Member
    2005 Tacoma TRD
    I'll try it out when I have a chance to install it, and I'll let you know how it is... and if you don't hear back, I've been run over by accidentally remote starting my truck in gear while working underneath it because the mod didn't work properly. :rofl:
    Rick_Taco likes this.
  2. Nov 15, 2018 at 11:49 AM
    #2242
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Hahahah deal
    I’m gonna sit and think about this one for sure. I’m getting the N2 remote starter from Jimmy in a couple weeks when he’s got it all set. I actually just sent him a link to your post too so he can check it out.
    Definitely looking forward to hearing how it works for you. I had a remote start on my MT Subaru Impreza and it wasn’t super annoying to have to do the “reservation mode” thing but I could definitely live without it.
  3. Nov 15, 2018 at 12:36 PM
    #2243
    Coffeeholic
    2005 Tacoma TRD
    It's not so much the sequence that annoys me, it's more the fact that if you go in the truck to get something, it deactivates it (though I completely understand why from a safety standpoint). Since I use mine as a work truck, I'm constantly in and out of the truck to grab tools, so since I do this, I can't really just remote start after doing so. Ex. if I'm at home, sometimes I'l grab a tool from my truck to fix something around the house, and then when I go to start in the morning to go to work, it doesn't allow it. It doesn't make sense for me to hop in after grabbing the tool, start the truck for a few seconds and go through the sequence just so I can remote start in the morning. :frusty:
  4. Nov 18, 2018 at 1:48 AM
    #2244
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    I may be wrong but I don’t think that vehicle remote starter ever had reservation mode to begin with, that’s a standard non-pro installer DIY’er that added what a professional installer is supposed to do when installing a remote starter on a MT vehicle. If he had reservation mode, why didn’t he mention this bypasses it and open a door? He put his foot on the brake and shifted into gear after starting it, hey doesn’t even have key take over! He essentially added a kill switch to interrupt the initializtion circuit of the remote starter. Our vehicles already have that. However, if you don’t want reservation mode, you’d have to source a remote starter that is “universal” and typically those come with non-plug n play harnesses and it’s up to the pro, or the DIY’er to install all the saftey measures. However a factory that provides a plug n play solution like I do would never oblige to that because it leaves ownership, liability and risk on the installer, and a manufacturer nowadays will NOT take that risk of “I promise to not bypass saftey or trick the vehicle in anyway” because at the end of the day, they sold it. That means they would still bear responsibility on a lawsuit. Remote starters that are plug n play or some that are programmed for manual, DONT give you the option to deactivate reservation mode, it runs in the firmware. Nowadays, the NHTSA is strict on rules that govern these devices, I wouldn’t even be able to sell it in the US if it didn’t meet saftey standards or pass validation.
    Also, if it were a late model vehicle per the posted YouTube video, the alarm would’ve sounded off with him merely sitting on the drivers seat as the air bag sensor would detect his weight, but no key, that’s a no no. His panic horn would’ve been blaring. Also, to show it’s an older vehicle, he didn’t even have sensors in the gear positions, we do. We also have a neutral position switch.
    This is not a video to show you how to by pass reservation mode. This is an old hoopty with old remote starter like they were back in the 90s and early 2000s before there were shifter position switches. So in short, you’re going to add a switch where one already exists, but do nothing to bypass reservation or ready mode on a remote starter that requires it.
    doublethebass[QUOTED] likes this.
  5. Nov 18, 2018 at 8:08 AM
    #2245
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Thanks Jimmy
  6. Nov 18, 2018 at 10:38 AM
    #2246
    Coffeeholic
    2005 Tacoma TRD
    I'm about 1000% sure my 97 Tacoma doesn't have a gear position sensors.
  7. Nov 18, 2018 at 12:36 PM
    #2247
    N2DesignsInc
    Los Angeles, CA
    Oops thought it was 3rd gen, pretty sure you don’t have a plug n play option either. Do you have a remote starter on your 97 currently with reservation mode?because if you did, the installer would’ve had to have that position sensor put in because the starter would be looking for it. That means no reservation mode if you do...
  8. Nov 26, 2018 at 9:52 AM
    #2248
    Wulf
    rock raisin
    I put 3M traction tap on my tube sliders a couple years ago in case I ever need to stand on them to reach something in the bed :thumbsup:
    Inkedgenius85 likes this.
  9. Nov 30, 2018 at 12:16 AM
    #2249
    beetlevegas
    beetlevegas You are no Vader. You are just a child in a mask!
    JP
    Las Vegas NV
    2011 silver Tacoma TRD 6 Speed double cab
    stuff
    I did to. Then I had to tear it off and redo it. The first time I had it going around the bar and my leg slid on it and tore the shit out of my leg. So I redid it to just the top of the slider. I am short and with a lift and tires I need to use the slider to get in and out.
    Taco critter likes this.
  10. Jan 5, 2019 at 7:58 AM
    #2250
    PErsing
    PErsing Well-Known Member
    Paul
    Southern Maine
    2012 Tacoma TX pro
    Caliraised 52" curved lightbar, Fox Shocks, TacomaBeast projector headlights
    Thinking of doing this this weekend. I have a tx pro trd but it does come with the off road package. Will update once done.
  11. Jan 9, 2019 at 4:26 PM
    #2251
    Dhannah
    Dhannah 2017 Tacoma OR DCSB
    Daniel
    North Carolina
    '17 DCSB OR TRD 4x4
    Under Construction
    I'm trying to get this to work on a 17 Tacoma and none of these links are working. Anyone help?
  12. Jan 9, 2019 at 4:51 PM
    #2252
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    Links are having issues for me too. What exactly are you trying to accomplish?
    tcjacado likes this.
  13. Jan 9, 2019 at 5:11 PM
    #2253
    StrangeDuck
    StrangeDuck Well-Known Member
    San Diego
    07 Prerunner AC TRD Offroad; 4.0 6-speed
    265/75 Bridgestone Dueler ATs, 5100s all around, OME 883s front, EL095R Dakars rear (overload removed), custom sliders, Clazzio seat covers, Softopper, KB Voodoo URTC
    Those links are almost 11 years old at this point so it's not surprising that they don't work. Here is a link from post #1 of this thread that explains it:
    Adapt as needed for your 3rd Gen.
    Dakotataco77 likes this.
  14. Jan 9, 2019 at 8:43 PM
    #2254
    Dhannah
    Daniel
    North Carolina
    '17 DCSB OR TRD 4x4
    Under Construction
    The pics aren't working lol but I think i can figure it out.
  15. Jan 9, 2019 at 8:43 PM
    #2255
    Dhannah
    Daniel
    North Carolina
    '17 DCSB OR TRD 4x4
    Under Construction
    Thank you by the way.
    StrangeDuck[QUOTED] likes this.
  16. Jan 9, 2019 at 8:46 PM
    #2256
    Dhannah
    Daniel
    North Carolina
    '17 DCSB OR TRD 4x4
    Under Construction
    I am trying to have power in my ”cig plug” 12v when the it's off. Not sure if it matters that it's a push button. I want power when it's not running so I can leave my fire lights on instead of leaving the truck on. My old truck had it set up if the battery dies I just get jumped after the call lol. It is good to have.
  17. Jan 11, 2019 at 10:06 AM
    #2257
    67siia
    67siia Well-Known Member
    J
    32164
    2009 4WD DCLB aka Chupacabra
    listening
    Dhannah likes this.
  18. Jan 16, 2019 at 2:51 PM
    #2258
    Rewilliams
    Rewilliams Well-Known Member
    Robert
    2017 Tacoma
    Does this work on the 3rd gen Tacomas?
    :fingerscrossed:
  19. Jan 16, 2019 at 2:53 PM
    #2259
    tcjacado
    tcjacado Well-Known Member
    Does what work??
    doublethebass likes this.
  20. Jan 16, 2019 at 2:54 PM
    #2260
    Rewilliams
    Robert
    2017 Tacoma
    Sorry on how to turn off the seat belt chim.
