Cheap/Free Mods
Discussion in 'Technical Chat' started by piercedtiger, Dec 28, 2007.
  1. Jun 7, 2009 at 5:23 PM
    #541
    replica9000
    replica9000 Death to AI!
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    So where can I get these aftermarket lights for no money and in 10 minutes? :D
    Nautiq176 and ChemDawg like this.
  2. Jun 7, 2009 at 10:45 PM
    #542
    peleus21
    peleus21 Well-Known Member
    okanogan, b.c. canada
    red trd sport
    led taillights HID dual beam headlights bolts and clamps to handle off road
    hehe i guess a 5 finger discount might work as long as you don't live near me :p
    seriously i got mine online with the HID low beams for 400 for a pair
    Isack51515 likes this.
  3. Jun 8, 2009 at 4:22 AM
    #543
    piercedtiger
    piercedtiger [OP] Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Well the mod itself is free, and if you already have aftermarket lights... lol I wouldn't mind trying this myself but I'd be concerned about melting the housings.
  4. Jun 8, 2009 at 9:54 PM
    #544
    peleus21
    red trd sport
    well it does look great at night but i also got the HID kit so that makes a huge difference too
  5. Jun 8, 2009 at 10:07 PM
    #545
    peleus21
    red trd sport
    i did a mod on my fog light and got some interesting results
    what i did was pull the switch apart and broke off the post for the light ground and soldered it to the signal output post. this makes it so the switch is only illuminated when it is on. but it also makes it so your fog lights are on all the time if your vehicle is running (i did fog anytime mod). if switch is off, headlights are off, fogs are on. if switch is off, headlights on, fogs are off. i like it cuz they are now my daytime running lights and at night i have full control of em. i could post pics if necessary but if you have followed the fog light indicator mod, it has pics and shows what is what
  6. Jun 13, 2009 at 7:56 PM
    #546
    kubota man
    kubota man Well-Known Member
    hazard ky
    08 trd off road dc 4x4
    i have the same relay same number 275-218 and the numbers are obbset of your diagram looks the same but for example your ground is shown on # 8 and its #7 on mine all the # are obbset on mine acording two the picture just trying not to mess it up could some one help me out and led me toward the correct way
  7. Jun 13, 2009 at 8:41 PM
    #547
    piercedtiger
    Jon
    Southern Tier, NY
    Ok there seems to be too much confusion over this since you're the second person questioning the wiring diagrams/color codes. It doesn't really matter HOW the relays are setup pin-wise as long as it's a double-pole double-throw.
    Refer to this diagram:
    Regardless of the pin numbers on whatever relay is used just match up the light blue and light green wires to the constant side of the relay, and the other 4 to the appropriate switched ones.
    For example, for the light blue wire match up violet to the normally closed and pink to switched open. For light green connect green/black to normally closed and violet to switched. Don't pay attention to pin numbers other than to match up that relay's diagram if it's not printed on the relay itself.
    That just leaves power and ground for the coil to activate the relay.
    When I did this I didn't have someone giving me pin numbers to go off, and I don't have the time to pin out every single relay out there. Use the diagram above to understand how this works and apply it to whatever relay is used. Think of it as blue toggling from violet to pink and green from green/black to violet when the relay is active. Wire whatever relay you have to achieve that goal based on the diagram of your particular relay without getting hung up on numbers.
  8. Jun 13, 2009 at 9:46 PM
    #548
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Sorry about the confusion. Numbers 7 and 8 are interchangeable. 7 and 8 cause the relay to switch back and forth. Whichever way you wire those 2 connectors it will work. just connect a ground to one and the stock button (switch) to the other...
  9. Jun 14, 2009 at 7:44 AM
    #549
    kubota man
    hazard ky
    thanks man for the quick response im having a hard time with the diagram but yours is so much easier to understand. i admit im not the brightess tool in the shed when it come to all the diff. switchs and such also thanks for not drilling me to the wall like the other guy did
  10. Jun 17, 2009 at 12:42 PM
    #550
    jwicker
    jwicker Well-Known Member
    Southern Indiana
    2003 Lunar Mist Double Cab 4x4
    ARB shell
    Just received a very helpful PDF from my inside contact at Toyota Manufacturing.
    The posts that I found regarding programming the keyfob/keyless entry options were a little off for my (2004 PreRunner Auto with keyless entry) application.
    This document worked perfectly for me.
    I was able to set the "unlock both doors with a single click" option as well as the "lock doors on ignition on option".
    Hope this helps.
    jwicker
  11. Jun 18, 2009 at 6:42 AM
    #551
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    Do you know if this works for the 05+ trucks as well?
    I didn't see anything in the front of the document that says it's specifically for the first gen models.
  12. Jun 18, 2009 at 7:06 AM
    #552
    piercedtiger
    Jon
    Southern Tier, NY
    It states for 2004 Tacoma. If they wrote it in 2004 for the 2004 model how would they know what a 2005+ truck does? :confused: :laugh:
    You could try it, but I bet it doesn't work unless they've kept the same procedures.
  13. Jun 18, 2009 at 7:50 AM
    #553
    hotbrass
    hotbrass Well-Known Member
    Cowtown
    2005 Tacoma
    I would like to see one for 2005 also if anyone has access to the codes.
    Thanks!
  14. Jun 18, 2009 at 8:07 AM
    #554
    Rocketball
    Scott
    Westminster, MD
    Well, if they wrote it in 2004, they would know everything about the 2005. The engineering would have been done, and parts manufacturing would be underway to support the next model year hitting the dealer lots. :cool:
  15. Jun 18, 2009 at 10:44 AM
    #555
    jwicker
    Southern Indiana
    ARB shell
    Sorry - but I am not sure if my earlier post will work for 2nd Gens.
    I'll try to hit my buddy up for a later year document.
  16. Jun 18, 2009 at 11:02 AM
    #556
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    Did anyone try this on a 2009 or anything besides a 2004?
  17. Jun 19, 2009 at 6:13 PM
    #557
    peleus21
    red trd sport
    i would love to but the instructions are very vague on what will happen and where. i would think it should work for me with a 06 but not sure till i figure this dumb thing out
  18. Jun 19, 2009 at 8:18 PM
    #558
    gavonder
    gavonder She's Kickass!
    Ct
    08 TRD Sport Access Cab
    Sunroof, Leer Cap w/ Thule rack, Factory Running Boards, Fog Light Mod, Hood Struts, Scangauge, w/homemade mirror mount, AC/Defrost mod, Rear Spring TSB, TRD Center Caps
    I tried one of these for my '08 and messed up my key fob. I had to have Toyota fix it. I think it only works if you have the optional alarm system, not the factory key fobs.
    I would love to find one that works, but from what I've read and heard, it's not possible.
    GA
  19. Jun 20, 2009 at 6:31 PM
    #559
    jwicker
    Southern Indiana
    ARB shell
    When i tried the (much earlier) previously posted instructions, my keyfob also quit working.
    I used the Toyota PDF instructions after my fob stopped and it worked fine afterwards.
    May not help or apply to later models...but I am just saying that I thought that the early instrcutions also goofed my remote...but stepping through the ones I posted worked.
    I just set to open driver first and pass. second click and the fob started working again.
    I then selected the single click = both doors and all is good.
    HTH
    jwicker
  20. Jun 22, 2009 at 11:09 AM
    #560
    Wardog
    Wardog New Member
    2009 4x4 Crew Cab OR Barcelona Red
    Tried the DIY to disarm the Seat Belt Chime this morning on my brand new 09 Crew Cab 4x4 OR and it worked brilliantly. Too easy. Thanks for the tip.
