Cheap/Free Mods
Discussion in 'Technical Chat' started by piercedtiger, Dec 28, 2007.
  1. Aug 6, 2010 at 4:34 AM
    #801
    piercedtiger
    piercedtiger [OP] Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    And a few other weekends I bet! :D
  2. Aug 6, 2010 at 5:58 AM
    #802
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I think he's talking about throttle response and traction control restricting him from putting the power to the ground.
  3. Aug 6, 2010 at 6:24 AM
    #803
    piercedtiger
    Jon
    Southern Tier, NY
    :confused: I don't have traction control so I'm not sure what you mean. I know the ABS kill switch mod can change how those work. Makes the front act like it's locked while in 4wd so if the rear is locked, you're locked front and rear.
  4. Aug 11, 2010 at 6:39 PM
    #804
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Eagle River, Alaska
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    I've got the TRD carpet style floor mats in my truck and was constantly finding the darn things scrunched up after people had ridden in the back or the passenger seat.
    So to stop that and keep them in place I took some tape backed velcro strips and glued them to the underside of the floor mat with some E-6000 to keep them in place if the tape backing didn't. Just make sure that the "hook" portion of the velcro is used and facing the floor so that it grabs the carpet like it would the "loop" portion of the velcro. Once the glue dries drop the mats back in and apply a little pressure above the velcro strips and they shouldn't slide anymore. If you need to clean them, just peal them off the floor and your good to go.
    On a side note, this is my first post so bear with me if its a bit far from perfect.
  5. Aug 15, 2010 at 10:00 AM
    #805
    xjake
    xjake Member
    Santa Cruz, CA
    2010 Access Cab 2WD
    I did this mod and at first I stuck a small piece of plastic between the points on the relay. The power would stay on after the key was removed, but only for a few minutes. I have since stuck a longer piece of plastic, as far as it would go, and the power stays on always now.
  6. Aug 16, 2010 at 1:00 PM
    #806
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    I just did this mod this weekend and to simplify your mod, just run the wire from the terminal on the relay to the green wire that goes to your park lamps. Use a splice and your done. This way you don't have to go inside the cab. The entire mod took me 5 minutes. Fogs come on with park lamps now and they stay on with low beams and high beams.
  7. Aug 19, 2010 at 10:01 AM
    #807
    tacobox
    tacobox Evasive Maneuvers PMKMS
    Nice tweek, yeah you could do it that way too. To be honest, I didn't even think of connecting it to the parking lights under the hood. I was running wires in the cab anyway so it was no extra effort. Either way works.
  8. Aug 20, 2010 at 2:58 PM
    #808
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Took at look at the Cruise Control DIY. Looks prety simple and something I"ll definately be doing.
    For anyone who's done this, A question.
    One really. Regarding the Air Bag ground wire. It says to remove the wire from the white harness, but does not say much about it thereafter. It looks like the wire in the photo got replaced with a possibly shorter ground wire??
  9. Aug 21, 2010 at 9:21 AM
    #809
    MaineYota
    MaineYota Well-Known Member
    Portland, Maine, USA
    '05 SR5 Doublecab
    Soft tonneau, vent shades, tube steps, bed extender, and tacomaworld.com sticker
    Quick housekeeping note: the link pointing to the "iPod Interface - 2005" is broken.
    Thanks!
  10. Aug 21, 2010 at 9:42 AM
    #810
    piercedtiger
    Jon
    Southern Tier, NY
    Link removed.
  11. Aug 23, 2010 at 6:52 PM
    #811
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Got a few questions about this...
    1. I know plenty of folks that have done this, but is it safe for long term for the components given that extra power is being drawn to the fogs?
    2. Why wouldn't the engineers allow the fogs to turn on from the factory? Do they know something about the wiring/fuses/battery that we don't?
    Thanks,
    Colton
  12. Aug 23, 2010 at 7:14 PM
    #812
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    It's actually part of the guidelines auto companies have to abide by. The theory is you shouldn't be driving in fog with your high-beams on. And it makes sense. Have you ever used high-beams in fog? You can't see shit.
  13. Aug 23, 2010 at 7:21 PM
    #813
    Incognito
    VA
    Ok, that makes sense. Never thought about that aspect of it. I've used my high's in fog and you're right, can't see anything whatsoever. Now my next thing would be about the amperage... Will it hurt anything as far as battery/alternator to have both on for long periods of time (2+ hours)?
    Thanks BB!
  14. Aug 24, 2010 at 2:07 AM
    #814
    piercedtiger
    Jon
    Southern Tier, NY
    it's the same as running low beams and fogs at the same time. There's no extra power. Now will running them more often mean you have replace the bulbs more often? Possibly. They do wear out. I've had to replace each fog once in the last 4 years. If that's too often, don't do it. :D
  15. Aug 24, 2010 at 3:27 AM
    #815
    huntinggunns
    huntinggunns Lifes a garden, dig it.
    Fred
    Oklahoma
    2014 MGM SR5 DC SB TSS 4x4
    In progress
    Quaker,
    All you have to do is un plug the air bag ground wire harness and then replace it with the new split harness. The split harness just adds the extra wires needed to plug up the cruise. It can only plug in one way so you can't mess it up.:D
    Varak likes this.
  16. Aug 24, 2010 at 7:59 AM
    #816
    Incognito
    VA
    Gotcha, that's what I thought but wanted to verify. I do know though that the more you run the lights, the faster they will wear out. :p
    Thanks Piercedtiger!
  17. Aug 24, 2010 at 8:22 AM
    #817
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Thanks, I'll keep this marked.
  18. Aug 24, 2010 at 7:55 PM
    #818
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Appreciated.
  19. Sep 1, 2010 at 10:18 AM
    #819
    4x4FishTaco
    4x4FishTaco Active Member
    Paul
    Lafayette, LA
    2010, 4wd, TRD Off Road, Dbl cab, Mag. Grey
    All stock (not for long)
    awesome thread, bookmarked:)
  20. Sep 1, 2010 at 7:12 PM
    #820
    dman597
    dman597 Well-Known Member
    Doug
    maryland
    2012 DC 4X4 SPORT w/Tow
    6" Pro Comp Lift,295-75-R17,access rollup,Tint,front hitch,nfab step bars
    Option: 2
    I bought these j type holders from McMaster Carr because i wanted something that would be a lil stronger plus they are coated with vinyl that will protect the rods: http://www.mcmaster.com/#1730a92/=8nxlvg
    Parts needed: 2x'J' hooks, 2xScrews (sized to fit pre-drilled holes), 2xwashers, 2xwingnuts
    Note: I used my custom Nuts and a 5/16-18 bolts
    Finished look:
    07Taco. likes this.
