Cheap/Free Mods
Discussion in 'Technical Chat' started by piercedtiger, Dec 28, 2007.
  1. Jul 6, 2011 at 2:54 PM
    #1001
    Trachito
    Trachito Well-Known Member
    New Orleans
    good points of view. thanks for the info, guys.
  2. Jul 13, 2011 at 1:36 PM
    #1002
    trdtaco10
    trdtaco10 Well-Known Member
    Fayetteville, NC
    '10 TRD OR 4X4
    UWS toolbox, window tint, Bilstein 5100s on all four corners, black 16" TRD FJ wheels, 14" Shorty Antenna, Weathertech all weather floor liners, Satoshi Grill Mod, Rear leaf TSB, OME 885x's, Desert Racing UCAs, Icon 3 leaf AAL
    Just did the Anytime Locker Mod and amazed myself by getting it right the first time! Thanks to TW and piercedtiger! Works great and makes you wonder why the heck doesn't Toyota just do it from the factory since the Prereunners can do it in 2WD! Thanks again piercedtiger for the post and all these great "Cheap Mods"
  3. Jul 13, 2011 at 2:23 PM
    #1003
    piercedtiger
    piercedtiger [OP] Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    You're welcome. :D And glad it worked out so well for you. I know it took me some time when I did it.
  4. Jul 14, 2011 at 6:16 PM
    #1004
    rcbs204
    rcbs204 Well-Known Member Vendor
    FOG LIGHT ANYTIME MOD
    Now that i have finally done this mod, i can truly see the need for the foglight on indicator, so i am gonna spend a little time on this. I think what i can do is steal the signal from the relay that is being modded, and use that to light an indicator.
    There is an indicator in the switch already, but it is only for the dash lights, mine was out, so i replaced with an LED while i was in there. I also noticed that there is location for a second light just above the dash light but needs to be cut out to accommodate an indicator.
    Stay tuned!
    EDIT: Never mind, looks like it is done already!!
    http://www.toyotanation.com/forum/showthread.php?t=194356&highlight=illuminate+fog+light+switch
  5. Jul 17, 2011 at 12:40 PM
    #1005
    kills4kiks
    kills4kiks Well-Known Member
    Adam
    CALI
    05 PreRunner SR5
    murdered out, Halo H.I.D. Head lights, Icon coilovers, aal, pro comp 3000 struts, powder coated rims, Hella Black Magics
    Works like a charm! my fuse box was set up diffrent but i found the fog relay and the green wire. love it! now when i drive through fog i dont have to open my hood and disconect my HIDs
    Thanks
  6. Jul 25, 2011 at 4:47 PM
    #1006
    jandoh0104
    jandoh0104 New Member
    ohio
    04 prerunner sr5
    i thought i could find my rear axle ratio not even the dealer .how can i find the axle ratio for 04 tacoma 4 door with vin 5tegn92n24z425576
  7. Jul 25, 2011 at 6:09 PM
    #1007
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    On the 05+ tacos it's on drivers door, but you need to decode it like the VIN number. Probably the same for 04.
    Sent from my ADR6300
  8. Jul 25, 2011 at 6:56 PM
    #1008
    meeestirg
    meeestirg Well-Known Member
    Vance County, NC
  9. Jul 26, 2011 at 5:30 AM
    #1009
    BBJ285
    BBJ285 Well-Known Member
    Scurry, TX
    03 Pre-Runner
    SnugTop cap, "SuperSpring" helperspring, flowmaster muff,K&N CAI, CB, small amp & 2 6x9s in the bed on a toggles switch for nights at the drive-in...
    Your Tacoma will have either 3.909 or 4.100 gears, according to your VIN, you do not have DIFF LOCK. IT originally came with p225/75r15 tires. A tech here at the dealership I work at said more than likely it has 3.909 gears. The 4.100 are normally for 4x4 but there are always exceptions. On the door or door jam plate, it "should" have what gears are listed though.
  10. Aug 5, 2011 at 6:10 PM
    #1010
    tacomatweaker1
    tacomatweaker1 Active Member
    Brad
    Naples FL
    07 PreRunner SR5 Looking to Modify
    K&N
  11. Aug 12, 2011 at 11:27 AM
    #1011
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    Ever had to remove the spare tire?
    Have you noticed that even if you practiced doing it, it's PITA to engage the rod on the elevator?
    Grab a PVC 1 1/2" sanitary pipe and cut a 14" section, drill a hole about 1" from the end and install it with a zip tie as seen in the pictures, works like a charm and total cost was $2.35 for the whole 10ft pipe.
    Why didn't Toyota did that in the fist place?
  12. Aug 12, 2011 at 11:35 AM
    #1012
    Namyo
    Namyo -
    :thumbsup:
    FoolishFrog likes this.
  13. Aug 13, 2011 at 8:42 PM
    #1013
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Awesome. I'm going to do that when I get a chance. It's a paint to deal with!
  14. Aug 14, 2011 at 8:58 AM
    #1014
    pyrate
    pyrate Active Member
    Ever had the stock radio out and see if the tape or CD inputs can be rewired for an iPod jack? I am using one of those things that plug into the iPod and then go in the tape deck and was wondering if there was another way without replacing the whole unit. Thanks.
  15. Aug 14, 2011 at 9:03 AM
    #1015
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    If you have a tape deck I'm sure you could make this work for you too.
    http://www.tacomaworld.com/forum/au...iy-aux-input-2005-2008-factory-head-unit.html
  16. Aug 14, 2011 at 1:18 PM
    #1016
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
  17. Aug 15, 2011 at 7:09 AM
    #1017
    pyrate
    Yeah, that is what I am looking for. I wasn't sure if there was a big difference between 1st and 2nd generation models. I have a 2003.
    Thanks. I will take a look at this later.
  18. Aug 15, 2011 at 6:07 PM
    #1018
    deerslayer75
    deerslayer75 Well-Known Member
    Tim
    jersey shore
    11 TRD sport Dblcab Lngbed
    pop-n-lock, mcgard tailgate lock, chrome tube steps, bed extender, chrome brush guard, Fold a cover (G-4) tonneau, weather tech floor mats and rain gaurds, sock monkey: TRD 3rd brake light and whitetail decals, LED bed lights, blue map & dome, 3rd brake light and license plate LED mod, illuminated 4x4 switch, fishing rod holder mod, scangauge II, Remote start & alarm, TW sticker, Flyzeye cupholder light mod
    great mod I do a lot of fishing and always worry I will open my tonneau and a rod will be broken. I will be doing this soon!
  19. Aug 19, 2011 at 8:44 AM
    #1019
    Charged05
    Charged05 Active Member
    Colorado
    2005 TRD Charged 4.0 6SPD
    SuperCharged
    With all these mods to get locker anytime, has anyone damaged the locker or rear end by locking it and driving it? its not limited slip so wont the locker damage things when turning on curvy roads?
  20. Aug 19, 2011 at 8:57 AM
    #1020
    bitejr138
    bitejr138 CTID
    Kelly
    St. Maries, Idaho
    Don't know about the Taco locker, but with other rigs I've owned with full time lockers (Detroit) or part time (ARB air locker), you just wear the hell out of your tires and/or disengage it when not in use.
    It seems to depend on type and use/abuse....
