Cheap/Free Mods
Discussion in 'Technical Chat' started by piercedtiger, Dec 28, 2007.
  1. Jun 13, 2012 at 7:46 AM
    #1221
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    Saw a set of these bed rail tie downs on eBay for $29. Built my own set (of 4) for just under 14 dollars.
    All that is needed:
    4- 3/8" unistrut spring nuts
    4- 3/8" short eye bolts
    12- 3/8" fender washers
    They fit great. Slide when loose. And you can unscrew them and they will pop in anywhere on the bedrail.
  2. Jun 13, 2012 at 8:02 AM
    #1222
    MaineYota
    MaineYota Well-Known Member
    Portland, Maine, USA
    '05 SR5 Doublecab
    Soft tonneau, vent shades, tube steps, bed extender, and tacomaworld.com sticker
    I like your ingenuity, but those pics scare me a bit.
    It looks like the nut that's actually IN the rail doesn't sit behind the rolled steel edges of the rail, but wedges between them. Not a huge deal under light tightening/light loads, but too much torsion on those puppies while they're under load and you'll pinch/crease a section of your rail.
    Worst-case could find them bending the rail enough to let them slip out.
    Is there a way to put a couple washers in that rail between the nut and the rail? That might solve the problem right nicely (sorry about the grammar - I'm from Maine, after all.)
  3. Jun 13, 2012 at 12:39 PM
    #1223
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    This is usually used in construction - usually electrical. The 4- 3/8" unistrut spring nuts fit in the unistrut - that is what they are made for. 3/8 bolt threads into the spring nut just as it is supposed to do. Nice job.
  4. Jun 13, 2012 at 3:52 PM
    #1224
    piercedtiger
    piercedtiger [OP] Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    There're probably channel nuts. I've seen them at Fastenal. They have grooves near the ends to lock into the bed rail channel.
  5. Jun 13, 2012 at 7:01 PM
    #1225
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Unistrut fail
    The spring goes on the opposite side from the bolt. The spring holds the nut in position until the bolt is tightened.
    Reversed as shown....
    The grooves are on the wrong side.
  6. Jun 13, 2012 at 8:34 PM
    #1226
    787tester
    787tester Well-Known Member
    Everett, wa
    11 double cab trd long bed
    When I did mine, I used half inch unistrut nuts and ground them a little on the bench grinder. I eliminated the spring though. Didn't need it. I did use washers on the inside of the rail to lock it into the notches in the rail. Keeps it from migrating down the rail. Nice clean look to the op though.
  7. Jun 13, 2012 at 8:38 PM
    #1227
    787tester
    Everett, wa
    [​IMG]here is another option. Used one of the cheap stake pocket bed tie downs found for about 4 bucks at auto part stores. Ground down the nut and removed the rubber block. Looks and works great
  8. Jun 13, 2012 at 8:41 PM
    #1228
    787tester
    Everett, wa
  9. Jun 19, 2012 at 6:01 AM
    #1229
    StreetTaco05
    StreetTaco05 Active Member
    SR5 access Cab Mildly moded
    3" Pro Comp Lift 285/70/17 Pro Comp A/T Flowmaster Exhaust AFE Intake Custom Decals ATFL Mod
    There is a black connector in the one fuse block under the dash that's leads to the dome light I recommend splicing from there. I have to do a write up on it I've just been busy as hell
  10. Jun 19, 2012 at 9:43 AM
    #1230
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Eagle River, Alaska
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    Write up on what exactly?
  11. Jun 20, 2012 at 5:09 AM
    #1231
    StreetTaco05
    Sorry that post can be deleted I posted it in the wrong forum
  12. Jun 20, 2012 at 5:47 PM
    #1232
    Rich91710
    Rich
    Los Angeles
    08 Base
    Delete it yourself.
    Edit > Delete Post > Confirm (don't put in a reason for deletion).
  13. Jun 25, 2012 at 9:45 AM
    #1233
    OldFatGuy
    OldFatGuy Well-Known Member
    Robert
    Greenville, NC
    2012 4WD double cab with minor mods
    Flow Master 50 Series dual K&N Filter Cheap Toyota Skid Plate (better than Nothing) 2.5 Hell Bent leveling Kit 1.0 blocks on rear 285-75-16 BFG KO High Performance Bed Mat De-Badged Westin Light bar -W/ 3 KC 100watt slim lights
    Great idea!!!
  14. Jul 11, 2012 at 2:13 PM
    #1234
    replica9000
    replica9000 Death to AI!
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    So I'm not really a fan of the stock bottle jack or the breaker bar. Went out and bought some better replacements. - Under $20 - Under $25 - About $5
    The bottle jack I bought extends about 3" shorter than the factory jack, but most of us lifted Tacos are probably shoving a block of wood or brick under the jack anyways. It's all tucked in where the factory jack goes, even using the rubber things to prevent rattling.
  15. Jul 12, 2012 at 7:51 AM
    #1235
    gottahot1
    gottahot1 Well-Known Member
    T.D.
    Arizona
    08 BLUE double cab 4x4 short bed Sport TRD
    'Caribe' fog light mod - Power port always on mod - Defrost A/C override mod - Illuminated 4x4 switch - Read diff breather relocation
    Great idea for those who want or need replacements. Will you list the sources for the stuff that you bought?
  16. Jul 12, 2012 at 8:14 AM
    #1236
    replica9000
    2019 T4R ORP
    Updated my post with links to the products.
  17. Jul 19, 2012 at 9:16 AM
    #1237
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    Just a FYI, for someone who may not know, but for some models of Tacoma's the wheel lugs are 21mm. So, of course, some may require a . Hate to see anyone swap out the factory and have the wrong size for their application. Because when you really need it, it'll be in a 107°F blizzard amidst a wildfire on the side of the road at 3:00 in the morning.
    I always carry both sizes at minimum. Some lower end trailers use 19mm. My Tacoma just happens to also have a 17mm >thin wall< socket, because I needed it once (hot chick in Audi) and didn't have it. Won't let that happen again! LoL
  18. Jul 19, 2012 at 9:53 AM
    #1238
    replica9000
    2019 T4R ORP
    Definitely a good idea for anyone to check their rim/lugs to buy the appropriate socket to make sure it can fit on the lugs, and inside the rim. Also make sure it fits on the key for locking lug nuts, if they are used. I only still have that pouch in my truck to I can drop the spare if necessary.
  19. Jul 27, 2012 at 7:10 AM
    #1239
    2010TRD
    2010TRD Well-Known Member
    Thomas
    Waldo, FL
    2010 MGM trd offroad DCSB
    Billistein 5100 front/rears, Toytec 2" AAL Custom grill, All Pro rear bumper, All Pro sliders, Anytime elocker/foglights, Rear diff vent relocated, W/O seat covers, weathertech mats/visors, nfab tire racK, cobra 75 stealth CB, Custom engine/trans skids 3/8", Hella and HID behind grill, LED bar backup light, LED pods under cab (rocklights)
    Subd
    So far:
    Rear locker anytime mod (no relay method)
    Fogs anytime mod
    Seatbelt chime OFF
  20. Jul 28, 2012 at 3:52 AM
    #1240
    Mytaco09
    Mytaco09 Active Member
    Edmonton, AB, Canada
    '09 TRD Sport Supercharged
    TRD Supercharger, billet grill, Toytec ULK on the front with AllPro Expos bringing up the rear, a work in progress
    One more thing that I personally carry for tire changes is a speed wrench. I had a set of winter tires a few years ago on my winter car that I bought used and for whatever reason they wouldn't hold a bead in really cold temperatures so I constantly found myself changing tires in -25 to -30 degree celsius temperatures....SUCKS!! It was so bad I never put the tools away, carried an extra full size spare so I'd have 2 and tossed in the front mat from my door step to kneel down in the snow. Time being of the essence though I bought a speed wrench and now always have one. Use your breaker bar to break the nuts and of course re-torque them as a speed wrench can't apply any significant amount. Once you break them loose, switch your socket to the speed wench and raise the vehicle and you'll have them off almost as fast as an impact.
