Cheap/Free Mods
Discussion in 'Technical Chat' started by piercedtiger, Dec 28, 2007.
  1. Nov 7, 2013 at 9:31 AM
    #1521
    keninsb
    keninsb "Senior", Senior Member
    Ken
    Goleta, CA
    '13 Taco DC 4WD V6 LTD
    Matt at TRD Sparks is THE man. Call or email him and he will give you the straight skinny.
    Ken
  2. Nov 7, 2013 at 6:02 PM
    #1522
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Absolutely zero difference.
    I did the wiper swap and cruise control installation in 15 minutes in the parking lot at work with nothing more than a multi-tool and $220 worth of parts.
  3. Nov 7, 2013 at 6:32 PM
    #1523
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I didn't check motors, but I am one who did the change to the intermittent. Been over a year and zero issues.
    I'll echo what someone else said, the dealers don't seem to know this for some reason..
  4. Nov 8, 2013 at 5:32 AM
    #1524
    vandeveer
    vandeveer Member
    michigan
    2013 Tacoma Base 4cyl
    Mick,
    Thanks for the response and the reassurance that this will work on 2013 models. May I ask if you bought the unit through a dealership and how much you had to pay? I have gotten two quotes from local dealers, each of which are around $180. I have read in the forum where others have gotten better deals but have not come up with a good source yet.
    mike
  5. Nov 8, 2013 at 5:39 AM
    #1525
    vandeveer
    vandeveer Member
    michigan
    Mick,
    I should have read the rest of your posting. You gave a link to an earlier post that indicates your hassles with the dealer and the $150 charge for the part. I'll check around for getting a similar price.
    Thanks to all for the helpful responses. This is a great forum.
  6. Nov 8, 2013 at 1:36 PM
    #1526
    AeroKen
    AeroKen Well-Known Member
    Kendrick
    Littlefun, CO
    2wd Tacoma, 2.7L 5spd
    None so far
    Now this I want to do. I miss these features from my Corolla.
  7. Nov 8, 2013 at 5:32 PM
    #1527
    Rich91710
    Rich
    Los Angeles
    08 Base
    Wiper stalk:
    http://parts.camelbacktoyota.com/pa...ICAL&subgroup=SWITCHES&component=WIPER SWITCH
    $111.... reset search parameters for the 2013, but the only difference from '05 to '13 is the direction you turn the knob to adjust the delay, and whether it has words or symbols.
    Cruise control:
    http://parts.camelbacktoyota.com/parts/2011/Toyota/Tacoma/Pre Runner/index.cfm?siteid=214329
    $75 for the stalk....
    You'll also need the clutch switch if you have a manual, the new wire harness, and a new cover for the steering wheel... total will be about $100.
  8. Nov 9, 2013 at 4:50 PM
    #1528
    Faryota
    Faryota Well-Known Member
    Mic
    Ridgefield, WA.
    13, 4x4, long bed, Sport, Debad
    6" BDS lift in front, warn winch, AFE cold air intake & exhaust, Body Armor Rear bumper, Tuffy in bed storage box, DZ bed mat, ARB front bumper & Warn winch w/light kit, Husky floor mats, dash mat,
    Help!!! I did this on my 2009 with no troubles, but can't seem to get it to work on my 2013...any one have a fix??? Seat belt chime driving me nuts while off roaming..
  9. Nov 9, 2013 at 4:52 PM
    #1529
    VetteVert
    VetteVert Well-Known Member
    '17 Storm Trooper DCSBOR
    Doesn't work on the new ones... Only the dealer can do it.
  10. Nov 9, 2013 at 5:02 PM
    #1530
    keninsb
    Ken
    Goleta, CA
    I have a 2013 Tacoma LTD and was able to disable both the driver and passenger side seat warning using THIS. It will be the best $35 you ever spent, especially if you own other Toyotas. One thing to note is that you have to have a PC/Laptop running Windows XP to run the program.
    Ken
  11. Nov 9, 2013 at 5:23 PM
    #1531
    replica9000
    replica9000 Death to AI!
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I remember when it was as easy as disconnecting a wire from the seat belt.
  12. Nov 10, 2013 at 6:44 AM
    #1532
    Faryota
    Mic
    Ridgefield, WA.
    Thanks I will order and un hook the chime...
  13. Nov 10, 2013 at 7:15 AM
    #1533
    BigMick
    BigMick Member
    Mick
    Annapolis, MD
    2013 PreRunner
    Extang Trifecta Bed Cover, Intermittent Wiper Stalk, Backup Camera, Camera-View in Radio
    Ken,
    Do you also need the dealer software (I forget what it's called) to make the mod?
    Mick
  14. Nov 10, 2013 at 9:32 AM
    #1534
    keninsb
    Ken
    Goleta, CA
    No worries, but remember, you need a pc with Windows XP to run the program,
    Mick, the kit comes with a small CD with the TIS (Toyota Information System) software and VIM (Vehicle Interface module). Everything you need minus the PC. Anyone wanting to do this, should check out thread on Tundra Solutions. There is a TON of info and advice on there for using the program. Unfortunately, there is not NEARLY as many functions on out Tacos as there is on the Tundra, but the chime thing is there (I have done it). You can also view live data, read and erase codes, etc.
    Ken
  15. Nov 10, 2013 at 1:06 PM
    #1535
    Rich91710
    Rich
    Los Angeles
    08 Base
    The cable comes with a cracked version of Techstream.
    DO NOT under any circumstances attempt to use the software to log into Toyota's TIS, or to reflash your ECU.
    The connection on these cables is a bit shaky and they frequently drop the connection. If it were to drop during a reflash, you would need a tow to the dealer and have to explain what you did (no warranty, probably $500).
    Attempting to connect to TIS may (I don't know for certain) disable the software. It is a cracked version of Techstream and is not a legal copy.
  16. Nov 11, 2013 at 11:45 PM
    #1536
    yarro
    yarro Well-Known Member
    Tacoma, WA
    11' TRD Off Road DCSB
    TREX Eyelids. RIGID Fogs Toyota Skid Plate. AVID Light Bar. Rigid SR 20"Combo LED bar OEM Toyota Running Boards, LEER Canopy RIGID Roof Rack - COMPLETE. FJ cruiser Switch panel install in center isle. (4 new slots for OEM switches) Glove box & Center counsel Lighting with amber switch.
    Hey guys so I looked at Jivewalker's method and basically did the same thing. ;) works like a charm after you have all the needed tools.
    I used primary wire 16guage that I bought at Autozone, can be bought at any auto shop. I also bought a pack of the Quick Disconnects from Radio Shack fro $2.50, which worked perfect when fitting unto the male prong. I used black wiring because I didn't want it to be so noticeable when I open to look at all wires, so its hard to see in photo. As described in all above posts you just put the other end in that green wire slot. ;) hope these photos help others who needed a few more photos :) anyways looks great and now I can use my fogs when I want to.. FREEDOMM!! lol
  17. Nov 12, 2013 at 5:51 AM
    #1537
    TACOlin
    TACOlin Well-Known Member
    Colin
    Marietta, GA
    2010 TRD Off Road 4x4 DC SB
    URD Short Shifter, TRD Shift Knob, Rear Leaf Spring TSB, Flowmaster Super 40 muffler w/ 2.5" pipe and 3" tip, Cobra CB radio, 2' Truck Spec antenna, under hood PA speaker, JVC KW AV71BT Headunit, Anti-theft tailgate protection mod, locking bed storage compartment mod
    Hey yarro, thanks for the great pictures! But how did you plug the wire into the green wire slot? like what connector did you use or do you just shove the wire down in there? i couldnt tell very well from the picture
  18. Nov 13, 2013 at 1:00 PM
    #1538
    yarro
    Tacoma, WA
    Hey TACOlin i used the same disconnects i did for the other side going to the relay. (radio shack). Except on this side, i used the male prong.i had to trim it from both sides since it was a little big. I decided to use the dissconnects rather than just shoving the wire down there because i think it fits tight and its a cleaner mod. But i think as long as you can make it stay there your good, the goal is to not have to worry about going back under the hood and put it back in place:))
  19. Nov 13, 2013 at 5:24 PM
    #1539
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    I did this mod and it is amazing. I have spider halo led lights with separate bulbs for bright and dim.
  20. Nov 15, 2013 at 12:19 PM
    #1540
    TACOlin
    Colin
    Marietta, GA
    OK sweet thanks for getting back to me! Gonna try it this weekend hopefully
