Cheap/Free Mods
Discussion in 'Technical Chat' started by piercedtiger, Dec 28, 2007.
  1. Nov 17, 2013 at 9:27 PM
    #1541
    mack1961
    mack1961 New Member
    robert
    virginia
    2011 reg cab 4x4
    you say it worked on your 2009 is the 2011 the same really would like to have the intermittent wiper option on my truck ?
  2. Nov 17, 2013 at 9:37 PM
    #1542
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Any of the stalks will work on any Tacoma from '05 and up.
    The difference in the 3 part numbers is the direction of the rotation of the delay and whether you get words or symbols.
  3. Nov 22, 2013 at 5:13 PM
    #1543
    NoMoreMrRiceGuy
    NoMoreMrRiceGuy Well-Known Member
    jonathan
    San Anlsemo, CA
    2011 DCLB 4x4, 1997 240sx w/1JZ swap
    could you make a tutorial for that air compressor set up? thanks!
  4. Nov 22, 2013 at 5:24 PM
    #1544
    piercedtiger
    piercedtiger [OP] Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    You mean on the longer cables? :confused: That's the only thing I changed.
  5. Nov 22, 2013 at 5:30 PM
    #1545
    NoMoreMrRiceGuy
    jonathan
    San Anlsemo, CA
    oh okay lol, do you just connect it to the engine?
  6. Nov 22, 2013 at 5:37 PM
    #1546
    piercedtiger
    Jon
    Southern Tier, NY
    Yes. I leave it in the bag behind the rear seat and clamp to the battery when I need to use it. That also lets me hook it up to other vehicles.
  7. Nov 22, 2013 at 5:52 PM
    #1547
    NoMoreMrRiceGuy
    jonathan
    San Anlsemo, CA
    is there a way to connect it to the 12 v in the back and will this kill/drain your battery if you aren't careful?
  8. Nov 22, 2013 at 6:52 PM
    #1548
    piercedtiger
    Jon
    Southern Tier, NY
    Not with the stock configuration. I tried installing a 12v adapter in the bed for other tools, but it corroded within a year and has been useless (ditto for the one I put under the hood).
    I supposed you could run a wire from the positive side of the battery to a terminal and use the factory clips on the compressor on that terminal, and ground....
    I would just lengthen the cables honestly. It's easier and more versatile. The compressor has a 30amp fuse in it, so you want to take that into account if you're not hooking it straight to the battery. That's more than most other automotive compressors I've seen, so yes it will run the battery down if you're not careful.
    I've run it for a few minutes with the ball inflation tip to blow out equipment with the engine off without problem. I also have the tow package with bigger battery, and 130amp alternator to charge it back up quicker too.
  9. Nov 22, 2013 at 7:31 PM
    #1549
    NoMoreMrRiceGuy
    jonathan
    San Anlsemo, CA
    oh alright sounds awesome, id most likely use it to either fill a flat on the road, or take it with my on biking trips to quickly fill up tires, so i wouldnt run it for more than 5-10 minutes if i used it
  10. Nov 22, 2013 at 8:33 PM
    #1550
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    I had the MV50 for a while. Absolutely awesome compressor when it works.
    But it has a relatively short life.
    In my case, the one-way flapper valve inside the head broke off. This was easy to predict, considering it was a simple piece of spring steel that was always being flexed back and forth when the compressor ran. Think what happens when you do that to a paperclip.
    If you need a backup compressor, this is about the best there is. Great for keeping as a spare, or for times of emergency.
    If you need a compressor for dedicated OBA, this is NOT what you want! I am speaking from experience here!! I had fabricated a nice mount for it, ran dedicated lines along my frame with a fitting front and back. I got eight complete air-ups (from 18psi to 38psi) out of it before it left me with one half-filled tire in Mojave.
    If you are looking to do OBA, you will want a compressor that can handle it. This is why ARB and ViAir are so popular.
    If you want a compressor that beats ARB or ViAir in all ways (except weight or size), check out the Puma 12V compressor from Buzzard Gulch on eBay. It cost me $230 shipped to my door. It flows 3.5cfm at 100% duty cycle, and comes with a 1.5-gallong tank. The problem with it is size: If you are like me and want to mount it somewhere, you're going to be hard-pressed to find a spot for it. And forget about putting it in the engine bay, unless you re-route your intake like I did (search "different approach to a snorkel").
    If you want help, tips, or pointers on putting together your OBA, let me know. I've had mine up and running flawlessly for about a year now, including 3-gallon tank, air bags, and connectors front & back.
    Yes, you can find many reviews online praising the MV50. But you can find just as many saying the exact opposite, usually from those who need it more for OBA purposes than for the occasional flat tire. Just note the purpose and use the reviewer needed it for, and how long s/he had it, and how much use s/he put it through.
  11. Nov 23, 2013 at 1:30 PM
    #1551
    vandeveer
    vandeveer Member
    michigan
    2013 Tacoma Base 4cyl
    After reading the instructions for the intermittent wiper mod, I ordered the part and just finished successfully installing it on my 2013 regular cab Tacoma. Thanks to those of you sharing your expertise on this installation. Someone mentioned having a beer afterward. I managed to complete the job despite having two pints beforehand. I was puzzled by how to access the tab holding the unit in place until realizing it is necessary too turn the steering wheel 90 degrees to expose the tab. I blame it on the beer beforehand. The unit works fine although the intermittent function works opposite the picture on the stick.
  12. Nov 23, 2013 at 2:34 PM
    #1552
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  13. Nov 23, 2013 at 4:15 PM
    #1553
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Huh. That's pretty sweet. Video looks like it works really well. You have experience with the name brand stuff compared to this? Also where did you buy it at? Never heard of the place he said he got his.
  14. Nov 25, 2013 at 7:08 AM
    #1554
    Ham N Egger
    Ham N Egger Well-Known Member
    33.414842, -111.909319 or 36.107324, -115.175744
    09 PreRunner V-6
    I haven't purchased the LEDs yet for the Dome light, Map light mod, but attempted to remove the lenses on the three lights using a driver with tape as mentioned in most of the posts here on TW.
    Instead of a risking marring the plastic surround on the lights, I "borrowed" a plastic Tupperware Citrus peeler from the kitchen. The plastic is flexible, so you have to use care and patience, but it will pop the lenses off without a chance of marring the plastic surround.
    Here is a link to the Amazon site to take a look, but your wife, mother, significant other may have one of these if they have ever attended a Tupperware party in the past century.
    http://www.amazon.com/Tupperware-Ci...1385391642&sr=8-7&keywords=tupperware+gadgets
  15. Dec 28, 2013 at 9:34 PM
    #1555
    Li0nel1234
    Li0nel1234 Well-Known Member
    Lionel
    Denver
    14 TRD OR DCSB SSM
    They sell it at Lowes. I used some other stuff similar to it on a project for my Camaro and it's the same but much less expensive.
  16. Dec 29, 2013 at 6:11 AM
    #1556
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Nice. Thanks!
  17. Jan 18, 2014 at 9:34 AM
    #1557
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    This thread is awesome. So many mods I need to get to work on
  18. Jan 18, 2014 at 9:58 AM
    #1558
    fyremanpat
    fyremanpat Well-Known Member
    Pat
    757
    2013 DC LB TRD Sport w/Entune
    OME 886x and 5100's all the way around. Toytec AAL. Phillips x-treme vision headlights. 886 reverse lights. Borla exhaust. 20% tint. Hi 6 mod. 285/65/18 Nitto TG on 18" Moto Metal 955's. Airaid intake. Scanguage2.JBA LT's.GC Grill..more to come.
    "Peel n seal" Ive used this stuff a dozen times on several vehicles. It works great and at a fraction of the cost of other sound deadening materials. It IS thinner but works well...you can always double up if you want. It sticks well through summer heat too. They sell it in wide rolls like the video and in thinner rolls.
  19. Jan 18, 2014 at 6:52 PM
    #1559
    2007TacBorla4X4
    2007TacBorla4X4 Well-Known Member
    Bob
    Jax, FL
    TRD Sport 4X4 Short Bed
    Borla cat back, K&N cold air, Silver star bulbs, Nerf bars,NEW BFG, Weather teck windows, Flash light on the drivers seat, TRD off Road ft tow hook, Rear driving lights on bumper, Weather teck windows & ft bug guard, 4X4 switch glows, Windows tinted 20% sun shade
    I did the inner door & outer door the floor on Sunday
  20. Jan 20, 2014 at 8:38 AM
    #1560
    81shark
    81shark Well-Known Member
    nice idea. gonna take a look at this. i hate when it slips out
