Cheap/Free Mods
Discussion in 'Technical Chat' started by piercedtiger, Dec 28, 2007.
  1. Feb 23, 2008 at 9:14 PM
    #141
    budisit
    budisit Active Member
    Buddy
    white, long bed, TRD, dbl cab
    Doesn't work.
    The sequence works up to the point of #9 where the doors are supposed to cycle once. But instead the doors cycle twice which means it didn't work / do over.
    I tried it 3 or 4 times and it's a no go.
    It's not hokey pokey however because the sequence definately causes the key to be programmed. It could be if you kept trying then you'd get it. I know that's how it worked on my seatbelt chime. It took me a few tries.
    Close but no cigar...yet.
    Anymore clues please let me know. I'll keep trying.
    thanks,
    BUDDY
  2. Feb 25, 2008 at 7:49 PM
    #142
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. Custom dents.
    This is what I have
    Program your factory keyless entry functions
    Print
    Rate ArticleHelpfulNot Helpful
    For 2001+ Tacomas equipped with a factory alarm or keyless entry, here are some programming options that allow you to adjust the way your locks work.
    The first programming option allows you to set the entry unlock to: (A) unlock the driver door with one push, and the remaining doors with a second push OR (B) unlock all of the doors with a single push.
    1. Open the driver's door. Remove the key from the ignition switch.
    2. (Complete these steps within 40 seconds)
    A. Insert the key into and remove it from the ignition switch 2 times.
    (IN - OUT - IN - OUT)
    B. Close, then open the driver's door 2 times.
    (SHUT - OPEN - SHUT - OPEN)
    C. Insert the key into and remove it from the ignition switch 1 time.
    (IN - OUT)
    D. Close, then open the driver's door 2 times.
    E. Insert the key into the ignition switch and leave it in.
    F. Close the driver's door.
    G. Turn the key from LOCK to ON 4 times, ending at LOCK
    (LOCK - ON - LOCK - ON - LOCK - ON - LOCK - ON - LOCK)
    H. Wait for the locks to stop, then remove the key from the ignition switch.
    3. On the key fob, press and release both LOCK and UNLOCK buttons at the same time.
    A. [For all doors unlock] press and release the UNLOCK button.
    B. [For driver door unlock] press and release the LOCK button.
    4. Open the driver's door. The programming is complete. If programming did not occur, start over.
    The second programming option allows you to set the doors to lock when when the key is turned on, and unlock when the key is turned off.
    2. (Complete these steps within 30 seconds)
    A. Insert the key into the ignition switch.
    C. Turn the key from LOCK to ON 5 times, ending at ON
    (LOCK - ON - LOCK - ON - LOCK - ON - LOCK - ON - LOCK - ON)
    3. Programming option (select one of the following).
    A. [Ignition controlled lock ON] Close the driver's door.
    B. [Ignition controlled lock OFF] Close the driver's door twice, leaving it closed.
    (SHUT - OPEN - SHUT)
    4. Turn the key to LOCK. The programming is complete. If programming did not occur, start over.
    When performing the programming, the park lights may or may not flash to confirm that the program was accepted. The only way to confirm the programming is to test them to see if they are functioning as desired.
    These procedures may or may not apply to pre-2001 models.
    fökai671, Taco_Sam and Calgaryguy like this.
  3. Feb 25, 2008 at 7:52 PM
    #143
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I have never tried this, hope it works. The numbering is slightly different so I posted it hoping you can get the desired effects.
  4. Feb 26, 2008 at 5:18 AM
    #144
    piercedtiger
    piercedtiger [OP] Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Courtesy of AdrenaliNate over on TN. :D (I think I'm going to have to do this soon.)
    New Engine Bay Light!!! - Toyota Forums :: Toyota Nation
    Smithgun2020 likes this.
  5. Feb 26, 2008 at 5:20 AM
    #145
    piercedtiger
    Jon
    Southern Tier, NY
  6. Feb 26, 2008 at 5:24 AM
    #146
    piercedtiger
    Jon
    Southern Tier, NY
    I'm thinking about doing the above mod, but putting a cigarette lighter plug under the hood instead of the switch. That way I can plug in my spot light at the front of the truck as well as that little work light. I already have a 12v outlet in the bed, so one under the hood means I could use either light all along the truck. :D
    TacoLou likes this.
  7. Feb 27, 2008 at 6:46 AM
    #147
    sooner130
    sooner130 Member
    Oklahoma City
    08 Prerunner TRD
    Aries nerf bars, skid plate, bed mat, bug shield, MP3, Tow PKG
    A guy on Ebay has these for $55 anf that includes shipping. Just got one this week.
  8. Feb 27, 2008 at 9:08 AM
    #148
    piercedtiger
    Jon
    Southern Tier, NY
    $55 for the $3 light above? :eek: Damn... I'm definitely hitting up K-Mart, Wal-Mart, and Advanced Auto this week to find it.
  9. Feb 28, 2008 at 7:32 AM
    #149
    sooner130
    sooner130 Member
    Oklahoma City
    08 Prerunner TRD
    No, my bad. $55 for the EZ down tail gate strut. Sorry everyone.
  10. Feb 28, 2008 at 7:49 AM
    #150
    piercedtiger
    Jon
    Southern Tier, NY
    OH! ok. :laugh: That sounds better. Good luck with the install. Several people have mentioned how it doesn't fit right and rubs. Hopefully your's will work as it should.
  11. Mar 2, 2008 at 6:04 PM
    #151
    silvertaco408
    silvertaco408 Well-Known Member
    San Diego, CA
    17 double cab long bed 4x4 trd off road
    Pioneer Avic Z2 navigation with ipod and bluetooth, K&N 77 Series intake, DT Headers, Flowmaster 50 exhaust, All Weather Mats, Fog Light Mod, Debadged, 20% tint all around, custom blue dome, maps, steering wheel, shifter lights, and cluster, Midland CB with PA, XD Series Revolvers wrapped in BFG AT's, black mesh grillcraft grill
    Debadging should be added to this list. I havent done it yet but my brother did it and it looks good...is deffinitely a cheap/free mod.
    fökai671 likes this.
  12. Mar 2, 2008 at 6:08 PM
    #152
    piercedtiger
    Jon
    Southern Tier, NY
    True. I could add that. I don't have any pics since I didn't do it myself. Could find a post elsewhere or just general instructions.
  13. Mar 2, 2008 at 6:32 PM
    #153
    mvega1969
    mvega1969 Well-Known Member
    Laredo
    '17 Tacoma DC LB 4X4 TRD Off Road.
    It is nice but... you better check a all inclusive option from GM (junkyard), there are several photos that shows the TILT HOOD LIGHTS and this mini mod you did to your underhood, the corded reel light I installed comes with a 24 foot long cable and with built-in on-off switch, here are the photos of both:
    HOOD TILT LIGHTS from a GM truck (No Flash).
    Corded Reel Light.
  14. Mar 2, 2008 at 8:31 PM
    #154
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hey pt.......sears has these lights(here in rock hill anyway) for right under $6 per light. i think im gonna stop in tomorrow and pick up a few of them myself.
  15. Mar 3, 2008 at 5:43 AM
    #155
    piercedtiger
    Jon
    Southern Tier, NY
    I got one at Wal-Mart for $4. Just waiting for it to warm up above freezing to install it! Got the light, cig plug, and a pin switch so I can leave it plugged in so it'll come on when I open the hood.
  16. Mar 3, 2008 at 1:57 PM
    #156
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    let me know....or post it, how you do the pin switch deal.....thats kinda what im wanting to do man.
  17. Mar 3, 2008 at 2:07 PM
    #157
    mvega1969
    Laredo
    With the TILT under hood lights you will need only a direct cable to the battery or as I did a fuse box to power them and ground is already "included" when bolted to the hood, they turn on as you open the hood and if you add as some of us has done… hood struts it will be a fully automatic light.
  18. Mar 3, 2008 at 2:09 PM
    #158
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, i definitely still need to get hood struts.
    GoletaTaco likes this.
  19. Mar 3, 2008 at 2:58 PM
    #159
    piercedtiger
    Jon
    Southern Tier, NY
    Did it today and will get pics up as soon as I can and do the right up.
    My driveway is damn near the only flat place I park. I'd rather not have a mercury or other tilt switch draining my battery while I'm parked on a hill. So I don't touch mercury switches.
  20. Mar 3, 2008 at 3:04 PM
    #160
    mvega1969
    Laredo
    Living in a flat state as Texas, hills are almost no problems at all and now I know your main reason for not to get these kind of lights, you are totally right. O wonderful Texas... you are big :cool:
