Cheap/Free Mods
Discussion in 'Technical Chat' started by piercedtiger, Dec 28, 2007.
  1. Jun 21, 2014 at 2:47 PM
    #1661
    ajohnson225
    ajohnson225 Well-Known Member
    Austin
    Baton Rouge
    Silver 05 DCLB Sport
    3" toytec lift, 285/70/17 trail grapplers, 17" ballistic offroad, flowmaster 40 delta flow, TRD CAI, debadged, pioneer touch screen, 2 kicker 10" on 1100 watt hifonics, 30" light bar, 15% tint front 20% tint back, interior LED's, all bulbs changed to LED's, LED pod reverse lights
    Would 1ohm work
  2. Jun 21, 2014 at 3:14 PM
    #1662
    DR007
    DR007 Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    There's one way to find out. It should though. The resistance will just affect your blink rate.
  3. Jun 21, 2014 at 5:47 PM
    #1663
    ajohnson225
    Austin
    Baton Rouge
    May sound stupid but how do you get a wire through the fire wall? the grommet by steering wheel area? I cant seem to get a wire to feed into the grommet the wires are in there to tight.
  4. Jun 21, 2014 at 5:52 PM
    #1664
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    You can get away with resistors in parallel to your turn signals for TURN SIGNALS, but not for DRLs. DRLs are on all the time, and that generates a LOT of heat in the load resistors. Turn signals are only on for a short time, so they don't have time to build a lot of heat.
    No.
  5. Jun 21, 2014 at 5:57 PM
    #1665
    bicyclist
    bicyclist Well-Known Member
    Yup, that's the one. If you feel around under the bundle of wires, you'll find a tit sticking out of the grommet. If you cut off the end of that tit, it will open up a passage to get wires through. Poke a stiff wire, like a piece of coat hanger, through and tightly tape your wires to it. Then go around the other side and you can pull the wires through.
  6. Jun 21, 2014 at 5:58 PM
    #1666
    DR007
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    This is not true DTRL. It is actually lower light part of the blinker that stays on and then the higher part comes on when it need to blink. The resistors will work and not cause any hear because I have been personally running this for over a year.
  7. Jun 21, 2014 at 6:02 PM
    #1667
    ajohnson225
    Austin
    Baton Rouge
    I ended up getting load resistors that I spliced in and led Blinker bulbs. I can't do the DTRL because too much heat in the load resistors? Thanks for all the help
  8. Jun 21, 2014 at 6:06 PM
    #1668
    DR007
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    You can do the load resistors and be fine. Obviously with any mod monitor it to make sure you have no problems but you shouldn't.
  9. Jun 21, 2014 at 6:14 PM
    #1669
    ajohnson225
    Austin
    Baton Rouge
    gracias, just finished up putting dash back together
  10. Jun 21, 2014 at 6:31 PM
    #1670
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Here is a thought.....Since the DTRL filament and the turn signal filament are the same, you could wire up the load resistors in parallel so the signals work properly. To prevent the resistors from heating up when the DTRLs are on, you could take a 100-200 mF (microfarad) 35 volt capacitor and wire it up in series with the load resistor. You might have to play around with a few different values before you find the size that works the best.
    Since the resistance in the capacitor increases over time as it charges up, it will essentially act as an open circuit (infinite resistance) once it has fully charged.
    If the capacitor is sized correctly it will allow the blinkers to turn on and off normally and also block current to the load resistor when the DTRLs are on thereby preventing it from heating up (and wasting power) after the capacitor has charged up.
    I have not tried this but the theory is sound. :D
  11. Jun 21, 2014 at 8:40 PM
    #1671
    Rich91710
    Rich
    Los Angeles
    08 Base
    It depends on the year.
    Before 2011 or 2010, the sockets were only 2 wire (as described above) and the turn signal itself was used for the DRL.
    Such would be the case if I were to install the DRL retrofit harness I have into my '08.
    Instead, I'm going to go with Jumper's switchbacks, which use the harness but tap the DRL voltage off and route it into the 3rd pin on the socket.
    The 3157NA lamps using the "hot" filament for both turn signal and DRL is the root of the turn signal lens melting issue.
    You have an '06? How did you install the DRL? Using one of the tricks described in this thread, or the factory harness behind the fuse box?
  12. Jun 21, 2014 at 8:46 PM
    #1672
    Rich91710
    Rich
    Los Angeles
    08 Base
    A capacitor in series with a resistor across the lamp would simply serve as a buffer, slowing down the time to max brightness and time to "off"
    Go large enough, and you simply end up with a turn signal that never goes fully "off" because the capacitor is discharging so slowly. It would just get dimmer and dimmer until it reached 50% where it would remain until the turn signal is shut off.
    At night, when the DRL's are off, it would go the other way... it would gradually brighten to 50% and hold.
    And you'd be talking like a 10 farad capacitor to do that.
  13. Jun 22, 2014 at 9:58 AM
    #1673
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    I don't know what kind of electronic background you have, but this DOES work as I described. Perhaps you misunderstood exactly how this is wired up. The capacitor needs to be in SERIES with the resistor. These are then wired PARALLEL to the LED lamp.
    I'm not sure where you are getting your 50% number from either. Yes there are two circuit paths very briefly while the capacitor is charging (for 1/4 of a second maybe), depending on how big the capacitor is. However, once the capacitor is charged, it acts like an open circuit so the only circuit path is through the LED. When power is removed, yes the capacitor will discharge through the LED again very briefly.
    This is basic electronics 101. I just happened to be playing around with this and some other things last night as well.
  14. Jun 22, 2014 at 7:06 PM
    #1674
    Rich91710
    Rich
    Los Angeles
    08 Base
    Try it on the Tacoma.
    It won't work as intended
    I get the 50% from the turn signal duty cycle being 50%. That's where the circuit will stabilize if the capacitor is large enough.
    If the capacitor is smaller, the flasher relay won't "see" the load resistor and you'll get a rapid flash.
  15. Jun 22, 2014 at 8:29 PM
    #1675
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    I see your point. It works in theory and in practice as long as the load resistor has enough resistance to slow the charge rate of the capacitor and the time to charge the capacitor is longer than the duration that the turn signal lamp is on.. I think I saw somewhere that these load resistors are around 1 ohm? If this is the case then this would not be a practical solution because the capacitor would need to be ridiculously large.
    On my test bench I was using resistors with much higher resistances (200+ ohms) I forgot that the bulbs on 12v systems have very little resistance. :eek:
    It might be possible to design a slightly more complex circuit using an RC network to control the gate of a transistor which would remove the load resistor from the circuit after 2 seconds, but if someone is going to go that far they could just crack open the flasher relay and swap out the resistors that sense the lamp circuit resistance, or just get a different flasher relay.
  16. Jun 22, 2014 at 8:36 PM
    #1676
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ya... a 25w lamp on 12v will be pulling around 2a, so the resistance of the lamp will be around 6 ohms, which is what the flasher module is going to be looking for.
    1 ohm is way too low for a standard load resistor. The mod to the flasher relay is to run two 0.22ohm in parallel in place of the shunt. That is a much better option than load resistors.
  17. Jun 30, 2014 at 3:39 PM
    #1677
    daxdaman
    daxdaman New Member
    socal
    black dd monster
    too,many
    so glad i came accoss this
  18. Jul 1, 2014 at 7:37 PM
    #1678
    Ricks2013
    Ricks2013 Well-Known Member
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    Great thread!
  19. Jul 8, 2014 at 2:29 AM
    #1679
    SupraMan
    SupraMan Well-Known Member
    Victor
    Vladivostok, Russia
    '12 TRD Off Road DCSB
    LEER 100XR, 2" IronMan 4x4 Lift Kit
    Is there locker anytime mod writeup for 2012? I wanted to do it with DPDT relay, but wire colors are different on my 2012.
  20. Jul 9, 2014 at 11:54 AM
    #1680
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
