Cheap Leveler
Discussion in 'Suspension' started by superdave, May 4, 2011.
  1. May 4, 2011 at 7:46 PM
    superdave
    superdave [OP] Active Member
    Dave
    St. Louis, Mo
    TRD Sport
    Camper Shell
    Ride Control by AIR LIFT . . . .
    I installed this kit (Kit No. 59561) because when putting luggage, tools, etc. into the bed with a camper shell on it, the headlights irritated oncoming drivers. I got a "T" for the air line, & put the valve at the license plate hole on the rear bumper. I keep 20 lbs of air in mine all the time & the ride is still really good (don't notice any harsh ride).
    It was really easy & inexpensive to fix the ride/load problem.
    superdave
  2. May 4, 2011 at 8:48 PM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    Good job! Nice looking kit!
  3. May 4, 2011 at 10:33 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i hear that putting a T connector in allows the air to move from bag to bag when weight shifts or hard cornering. seems like having the bags seperate would be better
  4. Sep 24, 2011 at 6:32 PM
    mikesfarm
    mikesfarm Well-Known Member
    Florida
    2025 4wd Tacoma SR5 DC
    Ok a old thread dredged up by searching. In the future I will add air bags. How about a single valve to make it easy to fill both sides equally, then close a inline valve in one side to prevent the cross flowing ? If you wanted different psi in each you could fill them both to lowest desired level on 'valved' side then close valve and finish filling the other.
