Cheap lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by DustinSK, Aug 17, 2010.
  1. Aug 17, 2010 at 4:29 PM
    DustinSK
    DustinSK [OP] Well-Known Member
    Is there a way to cheaply lift a 02 tacoma? Even only .5inch or so
  2. Aug 17, 2010 at 4:35 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    get bigger tires. they might rub some on the frame, body, fenderwell but itll raise about .25" - 1.0" depends on tire size.
  3. Aug 17, 2010 at 4:47 PM
    DustinSK
    I actually just got some...31s n I had to cut the frame with a dremel
  4. Aug 17, 2010 at 4:52 PM
    jblaze805
    jblaze805 Well-Known Member
    Ventura/Fresno, CA
    04 trd pre-runner
    2.5" king coilovers, caburg uca, magnaflow exhaust, aem intake
    where abouts are u from bc i have some front spacers for an 02-04 im looking to get rid of
  5. Aug 17, 2010 at 4:54 PM
    DustinSK
    Nor Cal
  6. Aug 17, 2010 at 5:00 PM
    jblaze805
    Ventura/Fresno, CA
    04 trd pre-runner
  7. Aug 17, 2010 at 7:12 PM
    quattrokiwi
    quattrokiwi Well-Known Member
    Bruce
    Nor Cal
    04 Tacoma, Limited, TRD, Locked, Geared, 4x4
    are you for real, you cut the frame?
  8. Aug 17, 2010 at 7:38 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    He probably did the pinch weld mod. No biggy.
  9. Aug 17, 2010 at 7:41 PM
    quattrokiwi
    Bruce
    Nor Cal
    lets hope thats all he did
  10. Aug 17, 2010 at 7:43 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    my frame hates me :)
  11. Aug 17, 2010 at 8:54 PM
    DustinSK
    No my mistake, I cut my plastic bumper with the dremel...I was paying attention...Lol
  12. Aug 17, 2010 at 9:09 PM
    tacomazach
    tacomazach Well-Known Member
    Zach
    Mississippi
    01 doublecab 4x4
    you could probably go with a spacer in the front and block in the back or aal... my guess is thats the cheaper end of lifts...
  13. Aug 18, 2010 at 7:57 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    ToyTec makes a 3/4" top plate spacer that might be what you are looking for.
  14. Aug 18, 2010 at 12:02 PM
    DustinSK
    hah. Are these spacers easy to put in
  15. Aug 18, 2010 at 12:40 PM
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    what's "cheap" and what do you use your truck for? does ride quality matter to you? you get what you pay for is all I'm trying to say.
