Cheap Mod: DIY AUX Input in a 2005-2008 Factory Head Unit
Discussion in 'Audio & Video' started by fbconvert, Jun 9, 2011.
  1. Mar 19, 2014 at 7:49 AM
    #341
    fbconvert
    fbconvert [OP] Well-Known Member
    Brian
    Seacoast, NH
    2005 Tacoma Double Cab TRD Sport
    Welcome to TW, do you have any pictures of where you soldered the ground?
  2. Mar 20, 2014 at 1:29 PM
    #342
    crumf20
    crumf20 Well-Known Member Vendor
    Wesley
    Tempe, AZ
    2000 Tacoma 3.4L 4x4
    33 x 12.5 x 15 Cooper Discover STT Pro's, All new UCA's LCA's including all balljoints, Bilstein 5100's all around with Dakar leafs w/ AAL in rear with 1inch extension Shackles, Eibach coils up front with 5100's set at 1.75 and 1/2inch spacer as well. Kenwood Double din deck with JBL 12in Sub: 300rms. Rockford Fosgate speakers front and back. New OEM black grill, Black Anzo Headlights with ddm tuning 6000k HID's. Seat Covers Unlimited black and grey 2 tone seat covers. Cobra CB Radio and PA system.
    Just did this mod on my friends 2nd gen non jbl, single disc head unit and it works great but the disc that was in it before we did it wont eject and we also get a message on the unit that says "Error 3". ANYONE know what it means or how to fix it? The mod still works though.
  3. Mar 20, 2014 at 1:58 PM
    #343
    fbconvert
    Brian
    Seacoast, NH
    I am assuming you forgot to remove the CD before performing this mod? I never got that error before but my guess is there is something that is jamming the eject mechanism. If it were me, I might try to remove the CD manually, but then you might ended up with nothing working. You could carefully disassemble it and make sure there is nothing binding in there first. Sorry I can't be much more help.
  4. Apr 23, 2014 at 11:01 AM
    #344
    s0lid
    s0lid New Member
    Ben
    Maryland
    06 SR5 Lifted
    Fog Lights, Extra Tie-downs, 2.75" Lift with new tires, TacomaWorld.com sticker
    Has anyone tried using something like one of these bluetooth adapters with their DIY AUX port? http://www.amazon.com/VicTsing-Blue...269&sr=8-14&keywords=3.5mm+bluetooth+receiver
    Just wondering if the AUX outlet would provide enough power for these to work. Some of the bluetooth receivers have a little power plug, but i'm more interested in one that would be powered solely by the AUX outlet. If so, this may provide an easy way to add bluetooth capability and clean up some of the wiring. You could maybe even mount the bluetooth adapter behind the dash somewhere or leave it in the glove box and just connect via bluetooth.
    Also, would the CD player override this when its plugged in but not playing music?
    I had a friend do this to his Tacoma a while back and when I tried my S3 it didn't work, but I since gotten a new phone and it looks like you guys figured some ways around the S3 issue. He sold his truck recently so I can't just plug one of these into his AUX outlet. I took another look at this forum and I'm very interested in doing this, but being able to connect over bluetooth would make this even more appealing for me. Thanks guys.
  5. Apr 29, 2014 at 6:12 PM
    #345
    crumf20
    Wesley
    Tempe, AZ
    So is there a way to turn this original mod into a wireless/bluetooth mod?? And is the quality of sound as good as the original mod?
  6. May 1, 2014 at 2:54 PM
    #346
    bhai81
    bhai81 Member
    Lincoln, NE
    06 Double Cab Long bed Sport
    Cheap cheap cheap AUX input
    The aux outlet does not provide power. You will have to use the provided 1 x USB Cable to charge the device.
    I did this mod couple of years ago, and it's great. I recently bought http://www.amazon.com/SMARTmini-Blu...sim_cps_2?ie=UTF8&refRID=14SRWKZX2CVESCM5VF4K , and the CD plays while my phone is not transmitting anything to the device.
  7. May 2, 2014 at 5:34 AM
    #347
    s0lid
    s0lid New Member
    Ben
    Maryland
    06 SR5 Lifted
    Thanks bhai81. So just to be clear, do you have to use a usb cable to power your goGroove? or did you mean to charge the phone?
  8. May 2, 2014 at 7:19 AM
    #348
    bhai81
    bhai81 Member
    Lincoln, NE
    The USB cable is not required to power the goGroove, you only need it to charge the goGroove, it has an internal battery that according to their website "USB rechargeable with 6 hour playback.". I have the power cable connected to it all the time, I'm just afraid that it will die during my 30 min commute.[​IMG]
    I also have another cable to charge my phone, which I also plug in as soon as I step in the truck.
  9. May 8, 2014 at 2:54 PM
    #349
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Instead of going thru the process of installing a jack and all that, I just cut one end off a male-male audio cable and soldered it to the board of my 06 Tundra CD player.
    The process basically consists of:
    Removing the cdplayer from the dash
    Disassembling headunit by removing 20-30 small screws
    Separating CD player from control unit
    Locating correct channel solder points
    cutting the end off one 4ft 3.5mm audio cable, stripping the wires, soldering them to the board.
    connect ground
    reassemble cd player unit
    reinstall
    A CD must be in the player. When nothing is plugged in, the cd player works as normal. When I plug any audio source into the wire it picks up that signal and overrides the CD player output, giving you an aux input.
    Their is no static or interference whatsoever except for when the phone is charging by the cig lighter. When not charging the sound quality is higher and cleaner then most CD's and is loud enough to damage the factory speakers.
  10. May 8, 2014 at 3:31 PM
    #350
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
  11. May 22, 2014 at 5:44 AM
    #351
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    And boom. I did this mod last night thanks to these pics. OMG these pics make the connection points look relatively big...these things are microscopic, lol. But after much screwing around, I got it done.
    I also left out the resistors, actually I used a small needle nose pliers to break them from the circuit board rather than unsolder them.
    Thanks to you guys for figuring this out!
  12. Jun 12, 2014 at 11:28 PM
    #352
    crumf20
    Wesley
    Tempe, AZ
    This radio is from a 4runner and i found what i think is the correct Left and Right channels but im not sur ewhich set it is!!?? ANy help please is it the pair that says "L", "R", or "L CH" and "R CH" Please Help!!
  13. Jun 13, 2014 at 10:01 AM
    #353
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    L CH & R CH
  14. Sep 13, 2014 at 5:05 PM
    #354
    fire03
    fire03 Member
    matthew
    az
    2005 toyota tacoma double cab prerunner
    do you know anyone who has used them? i'm not real savvy when it comes to electronics and this seems like a pretty good deal. thx!
  15. Nov 12, 2014 at 5:17 PM
    #355
    TacomaCowgirl
    TacomaCowgirl Well-Known Member
    Liv
    CA
    2007 Toyota Tacoma TRD
    just bought my 07 and wanted a quick fix to make it look less stock: Gotta love spray paint :D[​IMG]
  16. Nov 22, 2014 at 6:07 PM
    #356
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Worked Like a Charm Thanks :D
  17. Jan 15, 2015 at 9:48 AM
    #357
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Can't get much more stock looking than that. And I don't have the cable hanging out of the dash. Nicely hidden and doesn't get in the way of the coffee cups.
    Only issue I sometimes have is my left channel on the CD player will occasionally disappear when playing a CD. Works fine with the Aux and Radio though. Go figure.
    Edit - Both speakers work 100% of the time now.
  18. Feb 10, 2015 at 6:46 AM
    #358
    Tacomalover303
    Tacomalover303 Well-Known Member
    Colorado
    08 TRD Sport
    So I tried this mod last night on my 08 TRD Sport and when I soldered the L and R Channel the solder pads just popped off and now there is no place to solder. Does anyone have a pic of the other solder pads I can solder to? I am pretty good at soldering but for some reason the pads just fell off pretty easy. Thanks
  19. Feb 10, 2015 at 4:39 PM
    #359
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Happened on mine. You can solder to the board if you can see where the connections were.
  20. Feb 10, 2015 at 6:50 PM
    #360
    Tacomalover303
    Colorado
    08 TRD Sport
    How do you get the solder to connect to the board if there is no pad?
