Cheap mods you are proud of
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ThAkki, Dec 6, 2022.
  1. May 5, 2024 at 10:40 AM
    #821
    joncure
    joncure Well-Known Member
    VA
    2021 TRD Sport Access Cab manual
    Question: Any concerns with the effects of heat (from engine or hood in the sun) on the adhesive used to attach the LED strip?
  2. May 5, 2024 at 12:13 PM
    #822
    Joshuma
    Joshuma Member
    Josh
    '21 Tacom TRDOR 4x4 DCSB
    Stock
    Easy. Larger cup holders. Not sure why they don't come from the factory like this.
  3. May 5, 2024 at 2:00 PM
    #823
    ITmaD
    ITmaD Well-Known Member
    Atlanta
    Not really it looked like high tempt double sided 3m, been rolling around last few days without issue.
    joncure[QUOTED] likes this.
  4. May 5, 2024 at 2:27 PM
    #824
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Not who you asked, but... I've had underhood lights (2 strips) installed for about four years now (GA sun) and have not had any indications of weakened adhesive.
    RxYoda, joncure[QUOTED] and ITmaD like this.
  5. May 5, 2024 at 2:36 PM
    #825
    joncure
    VA
    Good to hear! It’s a perfect use of LED strip lighting.
  6. May 6, 2024 at 6:53 AM
    #826
    NlOffRoad11
    NlOffRoad11 Well-Known Member
    Tyler
    2021 Cement TRDOR
    What’s the purpose of removing the sway bar?
  7. May 6, 2024 at 7:01 AM
    #827
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Allows front suspension to run independently giving more articulation in your front shocks.
    When you hit a bump on passenger side and feel both tires move or a jarring front end.....
    You won't feel that.
    LarryDangerfield likes this.
  8. May 6, 2024 at 9:17 AM
    #828
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    Can confirm taking the swaybar off improves ride quality greatly
    drizzoh and bkhlrTaco's like this.
  9. May 6, 2024 at 11:45 AM
    #829
    NlOffRoad11
    Tyler
    2021 Cement TRDOR
    For on and off road? Are there any downfalls to removing it
  10. May 6, 2024 at 11:49 AM
    #830
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
  11. May 6, 2024 at 11:50 AM
    #831
    LarryDangerfield
    Tyler
    Northern Wisconsin
    Yes the ride quality is improved on and off-road. The main downfall is less stability under hard cornering and evasive maneuvers. I have to imagine a stock TRD off-road would be pretty sketchy without the sway bar because of how soft and jiggly the stock suspension is but with aftermarket suspension taking the sway bar off really lets the aftermarket suspension do its thing without being hampered. It allows more droop and more importantly it lets it be truly independent. As mentioned above if you hit a pothole with the left side tire and you have your sway bar on it jerks the vehicle but if you don't have the sway bar on then just the left side will feel the impact of the pothole but the right side will remain unbothered.
  12. May 6, 2024 at 12:03 PM
    #832
    Rednecktacoma22
    Rednecktacoma22 Well-Known Member
    Logan, UT
    22 TRD OR 6MT
    2 things, 1) does the button in that location automatically turn on the lights when opening the hood/turn them off when closing the hood? Or is it just a matter of pressing the button when you would like to activate it? 2) not to be that guy, but it appears this is installed on the driver side, not passenger :rofl:I was trying to figure out if the image was mirrored but then saw the battery behind the button, had me there for a second!
    Definitely want to go with this same setup either way. Been looking for materials on my own, so thank you for having a budget-friendly option laid out!
  13. May 6, 2024 at 12:24 PM
    #833
    ITmaD
    Atlanta
    1. The the button I used is manual so you have to press it to turn on/off, I prefer that to it being on all times of day when I pop the hood. The LED Kit comes with a switch that triggers the lights to come on every time the hood is open that I didn't want to use.
    2. Yes you're right hahaha I noticed that the other day but have been to lazy to correct passenger to driver side .
  14. May 6, 2024 at 12:29 PM
    #834
    Rednecktacoma22
    Logan, UT
    22 TRD OR 6MT
    Thanks for the swift response amigo! Yeah, I have both items in my cart for a quick install this summer. Getting money saved up for an OTT tune and doing the Accumulator Clutch Disk Delete has taken the forefront of the project bandwidth, but I've been slowly trying to find a simple and cheap solution for this mini project, so thank you again!
  15. May 6, 2024 at 1:29 PM
    #835
    Aod
    Aod Ex STi enthusiast
    B.
    NorCal/Bay Area
    2023 Tacoma TRD Pro
    Get yourself some 21-22 RAV4 Prime / 19-22 RAV4 knobs. Part number 90010-23059. They make a world of difference, have grip and (to me) look like they should've been there to begin with. Light up like the standard OEM ones also. Make sure you take the black plastic piece out first before installing. https://www.tacomaworld.com/threads/2020-tacoma-radio-knobs-mod-rav4-knobs.657365/
  16. May 6, 2024 at 7:55 PM
    #836
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    I think this mod has the highest happiness/cost ratio of any change I have made to my truck.
    The H9 bulbs and OCD tray for the centre console are competing for bronze and silver.
  17. May 7, 2024 at 7:51 AM
    #837
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Absolutley yes. Removing it can yield some positive attributes, but its not all good with no bad - it serves a significant purpose, and removing it can be dangerous. As he stated, removing it allows your front suspension to flex independently. You'll notice the pro's of removing it at lower speeds. At higher speeds, it can be flat out dangerous. The truck will no longer respond like it used to, and it will have much more body roll. Something else to consider with or without sway bar is towing limitations. Moral of the story - it can be beneficial; it can also be dangerous. The same can be said for all mods we do. Many go without a sway bar, and its not all bad. Just like its not all good. Thanks for asking the question - its nice to be informed before making a decision! FWIW, I run without one. You get used to it after a while, but if I allowed anyone else to regularly drive my truck, there's no way I'd run without it. It absolutely changes the drivability of the truck (some characteristics for the better, some for the worst).
  18. May 7, 2024 at 5:05 PM
    #838
    BillyE
    BillyE Well-Known Member
    I’ve run vehicles without a sway bar before. The Tacoma was too unstable for my taste so I put it back on.
  19. May 7, 2024 at 5:09 PM
    #839
    kent50
    kent50 Well-Known Member
    Kent
    Gold River California
    2017 Tacoma Sport DCSB MGM
    3" Lift XD Wheels 33" K02s Predator Steps TRD Oil Cap Backflip Bed Cover Factory All Weather Mats WeatherTech Bed Mat TRD Pro Shift Knob Vinyl Air Bag Decal Covers Vinyl TRD and Tacoma Inserts Factory Mud Flaps Factory Remote Start Factory Door Sill Protectors Console Organizer and Tray Pro Fogs Grill Mounted LED Light Bar TRD Faux Grill DeBadged TRD Sport Door Emblems Factory Bed Lights Pop Lock Tailgate Lock Rear USB Ports DIY Power Panel
    I tend to drive my 2017 Sport like a sports car so I think that I will keep mine one. However, if I off-roaded more often I would be tempted to remove it.
    NlOffRoad11 likes this.
  20. May 7, 2024 at 6:51 PM
    #840
    joncure
    VA
    The ole Rubicon push button sway bar disconnect would be a nice Tacoma modification.
    Will 7, musicisevil and TomTwo like this.
