Cheap mods you are proud of
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ThAkki, Dec 6, 2022.
  1. Nov 9, 2024 at 4:45 AM
    #1121
    RiverMando
    RiverMando Well-Known Member
    2019 TRD OR DCLB
    Also forgot plywood on tailgate. My knees are much happier!
    tacoma_ca and Spadi_5 like this.
  2. Nov 9, 2024 at 1:42 PM
    #1122
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    there are 12 cup holders in the truck already :popcorn:
  3. Nov 9, 2024 at 1:47 PM
    #1123
    RiverMando
    2019 TRD OR DCLB
    It replaces the front two. There are still 12!
  4. Nov 9, 2024 at 1:49 PM
    #1124
    RIX TUX
    16 + 16 = 32
  5. Jan 11, 2025 at 2:55 PM
    #1125
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Nice!
    I might look into one of those
  6. Jan 12, 2025 at 4:53 AM
    #1126
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Most recent cheap mod that is super satisfying is the 4 window auto switch. One touch auto up & down. Backlight is not a perfect match. It is a light blue, never bothered me as its kind of out of the way.
    https://amzn.to/3DUuRe3 currently has a 5% coupon.
  7. Jan 12, 2025 at 7:11 AM
    #1127
    Suggestausername
    Suggestausername Nerd
    J
    Tampa
  8. Jan 12, 2025 at 8:16 AM
    #1128
    Spielightdude
    Spielightdude Well-Known Member
    Joseph
    Canterbury
    2023 TRD Offroad
    How hard is it to swap out the start stop switch as I'm considering the same thing?
  9. Jan 12, 2025 at 8:36 AM
    #1129
    notsotacomad
    notsotacomad Member
    2022 Taco SR5
    Thought I was the only one that did that. Works like a charm and lasts a decent amount of time before the noise returns.
  10. Jan 12, 2025 at 8:45 AM
    #1130
    Spielightdude
    Joseph
    Canterbury
    2023 TRD Offroad
    I want to do this but in red to match my truck I'm working on doing all red and black. Where did you get them?
  11. Jan 12, 2025 at 8:47 AM
    #1131
    notsotacomad
    notsotacomad Member
    2022 Taco SR5
    IIRC etsy or ebay, people do some smaller custom work like this
  12. Jan 12, 2025 at 12:21 PM
    #1132
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    I did this as well - I would rate it very easy - just pop out the old and pop in the new. I think thee may even be a Youtube video but it pretty simple and intuitive.
    jrzjoe likes this.
  13. Jan 12, 2025 at 12:56 PM
    #1133
    OSUTacoma
    OSUTacoma Well-Known Member
    OHIO
    2023 Lunar Rock TRDSport DCSB
    I got mine from tacos4cheap
    https://tacos4cheap.com/
  14. Jan 19, 2025 at 10:31 AM
    #1134
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    So I was looking at and using my analog IFR altimeter that sits in my cupholder along with using my ‘analog’ book of topo maps to help navigate a BLM trail I was on the other day and I realized that I probably never properly thanked you for posting that description about your altimeter. When using it with paper topo maps, it’s actually much easier and faster to get a precise location than it is with GPS. I found one just like yours and I love it. Thanks so much!
    pdxTacoSR5[QUOTED] likes this.
  15. Jan 19, 2025 at 11:08 AM
    #1135
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    :thumbsup:
    If using for an extended period of time you need to reset the barometric pressure (ie. elevation) to keep the elevation accurate.
    i used to use on old navcom to get pressure off tuned in VORs but now I just set elevation at a known spot (garage usually) and accept that over time barometric pressure will change and elevation accuracy will degrade. if you are using topo maps and can identify where you are in 2D, you can easily maintain elevation accuracy. is that what you are doing or do you have some way of accessing barometric pressure?
    paper USGS topo maps are great. assuming they are not burned up in a wildfire, when all digital comm goes dark, they will still work :D
    TartanEagle likes this.
  16. Jan 20, 2025 at 9:05 AM
    #1136
    OnHartung'sRoad
    I can calibrate it on my driveway also before leaving for a day trip, and as I’m in the west a lot of passes have elevation markers or I am also able to use a Delorme topo map book that I keep in the truck to also do it. I have an old surveying altimeter that is accurate to smaller than a foot and it would also make a good barometer, but it also requires doing temperature calculations along with barometric calibration to get that type of accuracy and it’s about a foot in diameter- too big for the cup holder to take on trips!
  17. Jan 20, 2025 at 10:49 AM
    #1137
    pdxTacoSR5
    PDX area
    required calculations aside, i'm sure you could find a way to mount that on the dash :thumbsup::D
