cheap moving?
Discussion in 'Towing' started by TacoTuesday1, Apr 25, 2024.
  1. Apr 25, 2024 at 2:04 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    alright folks I wanna hear your creative loopholes that workaround trashing $2k just to borrow a POS surge brake UHaul 6x12 for extra stuff that might not all fit in the truck (long distance)
  2. Apr 25, 2024 at 4:59 PM
    cspcrx
    cspcrx Well-Known Member
    21 TRD Sport 4x4 Cement
    You put a fifth wheel connector in your Taco? This could be epic!
    keep in mind these weight 4500 to 5000 empty.
  3. Apr 25, 2024 at 8:16 PM
    TacoTuesday1
    FL
    hopefully avoid that if I can figure out a loophole
    bringing a rental trailer to return at the same location would turn it from $2k to $30
    but driving back accross the country just to do that is not realistic
    More gas, and too much time beyond the rental period
    maybe if there was one of these enclosed and taller vertical to hold more than just one low layer of boxes that wouldn’t utilize the carrying capacity these things are rated at (some of them 750lbs) - not sure how the hitch likes it. But folks carry motorcycles that way so it’s probably fine.
  4. Apr 26, 2024 at 8:46 PM
    TacoTuesday1
    FL
    so apparently
    for only around $500, HFT sells a folding trailer
    with side holders for vertical wood bars (2x6?)
    that, with a little bit of effort, appear would hold plywood walls
    to hug boxes inside from falling out so it's not open deck like a vehicle trailer
    this...looks pretty good....
    Then, when not in use, can be stored pretty tucked away to keep as a useful universal tool
    whether its a crappy plywood wall setup for moving to throw away
    or time taken on the design something that's removable walls to stow
    then you actually get to own something new with use
    or sell it
    may not need registration, or is possible to (not stolen)
    rather than Uhaul lighting money on fire getting nothing
    says 2" ball (like uhaul) includes wiring, lights, chains
    so it could be designed from the getgo to hit the road...
