Cheap Radiator Comparison & Radiator Horror Stories
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dalandser, Jun 30, 2017.
  1. Jun 30, 2017 at 8:27 PM
    Dalandser
    Dalandser [OP] ¡Me Gustan Las Tacos-mas!
    Anthony
    Downey
    Empty Wallet Mod
    Like the title says I'm looking to get a cheap radiator to keep my current engine cool on my first gen. The one I have is leaking coolant out of the top (not the cap) and I'd like to drive it around at least to the gas station and car wash if not take it for a spin once in awhile. I'm rebuilding an engine for it so once I'm done I'll install an oem rad which is only $30 or less more than the big 3 parts stores in my neck of the woods. I'll keep the cheap one for a backup.
    Here's the options for now with the 22 5/8" between tanks measurement (barring any good 4th of July sales that I haven't found out about yet).
    Autozone with a 20% off ship to home plus $10 dollar gift card putting it at $139 with taxes:
    http://www.autozone.com/cart/cart.jsp?_requestid=1663855
    Pepboys with a $47 discount bringing it to $122
    https://www.pepboys.com/parts/belts_hoses_water_pumps_cooling/radiators/01664/1998/TOYOTA%20TRUCK/TACOMA%20PICKUP/0/V6-3378%203.4L%20DOHC
    O'Reilly's is not doing so well with only a free shipping promotion which leaves it at full price basically:
    http://www.oreillyauto.com/site/c/s...year=1998&make=Toyota&model=Tacoma&vi=5014126
    I'm thinking of going Pepboys unless someone pipes up in defense of one of the other two being way better than Pepboys. Any thoughts? I for sure don't want to install an oem right now and run the risk of breaking it or clogging it up from schmootz from my current engine which is only going to be in there temporarily. Thank you!
  2. Jun 30, 2017 at 8:32 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Any of those will be fine. Actually probably better than what was original.
    My ,
    '98 had 4 radiators and non were from the same place. They all fit perfectly.
    I consider rads to be replaceable items. They are so cheap, they are great insurance to keeping your truck running good for a long time.
  3. Jun 30, 2017 at 8:35 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I think when I looked them up a few months ago and they were all under $100 - I was pretty surprised at the increase since then. I figure having a back up around won't be a bad idea - like you said I agree they're going to be replaced periodically. This truck is on it's 2nd in 20 years at 10 years a piece so hopefully the next one will be needed in about the same amount of time.
    An oem is only $185: https://parts.conicellitoyotaofcons...oling-system-cat/radiator-and-components-scat
  4. Jun 30, 2017 at 10:02 PM
    Indy
    Indy Master of all I survey.
    I've been driving for25 years, replaced 1 radiator I accidentally hit with a sawzall. What are you doing that requires multiple replacement radiator?
    Ritchie and Speedytech7 like this.
  5. Jun 30, 2017 at 10:28 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    A factory rad is $201 it seems like a no brainer to spend the extra couple of bucks. A close second would be the Denso from CockAuto
    Dalandser[OP] likes this.
  6. Jun 30, 2017 at 10:29 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    TYC makes a good cheapo rad. 85 to the door
  7. Jun 30, 2017 at 10:48 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Offroading out in the middle of nowhere is why I want a backup as well as what I mentioned in the first post. I'm looking for something I can get in the next couple of days and install quickly.
  8. Jun 30, 2017 at 10:49 PM
    koditten
    Kirk
    Central Michigan
    The 1st was leaking at the seam between the tank and core, that one was original. The next 2 died from trauma. Deer and wild Turkey. 4th was removed from the truck when the frame rusted in 2 @ 300,000 miles and now resides in my present '04
  9. Jul 1, 2017 at 3:46 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I like my All Copper and Brass one .
    I took a good OEM one out to install it.
    To bad your across the country I would give it to you.
  10. Jul 1, 2017 at 5:39 AM
    Indy
    We always had spares of common parts in the club runs, you would be the first radiator :laugh: you'll need a few gallons of coolant with you as well but if you're planning on a trail swap I'd run something non toxic instead.
    The only thing more expensive than buying the right part the first time is buying the right part the 2nd time. If there is only a few dollar difference between oem and aftermarket I'd just buy oem and be done. The 1 rad I have had to change, aftermarket was a lot less, and it was going on my $200 tacoma. I started that as a cheap truck and kept the trend going.
  11. Jul 1, 2017 at 5:58 AM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    I put a Denso in my truck about 4 months ago from rockauto.com, free shipping and I think it cost around $129
    NM Lance likes this.
  12. Jul 1, 2017 at 6:58 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I had one aluminum Radiator fail in the back country never again .
    Sure it was a Freak one of a kind thing the tank cracked .
    This was back when Aluminum Radiators were thought to be the hot thing Young and easily impressed .
    So all the newer epoxies were years away If I could have got it clean enough to bond
    Since that time my Trusty Propane Torch flux and solder have fixed a few.
    Since I tend to travel in well watered country finding water is not a problem
  13. Jul 1, 2017 at 8:36 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I mentioned I just want to get my truck driving without losing coolant and in the meantime I'll be ordering an oem one for my new engine. I'd rather have the knock off take a chance at getting something lodged in it from my current 20 year old engine and potentially have something happen to it (I'll still be careful) during the engine swap while my good one sits in its box waiting to be installed with the new engine.
    As far as trail swapping if it cracks and epoxy won't fix it, I travel with at least double the amount of water I plan on drinking out in the desert so I could dilute a bottle of concentrate with some distilled water I'll bring with me for both potential purposes. Sometimes it can be ~100 miles to the nearest well stocked part store in the areas I like to go visit (with little to no cell service sometimes) so limping that far on a leaking rad wouldn't be enjoyable or practical.
    For both of these reasons and a radiator being an shape that's easy to tuck away in storage while I'm not on vacation, I don't mind the extra $200 or less for a new radiator and some coolant, plus it will give me some experience installing a radiator before I install one on the engine I'm building so it'll be one less thing that I'll be doing for the first time, even if it's pretty a straightforward and simple process. Experience is at least a confidence builder. The reasoning I have for buying a spare not be important for some, for me it seemed worth it especially if I can get one on sale.
    IronPeak likes this.
  14. Jul 1, 2017 at 8:44 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    factory is a Harrison. Nothing special. Remember these trucks weren't made in Japan. Plenty of factory stuff is 'meh'.
  15. Jul 1, 2017 at 8:46 PM
    koditten
    Kirk
    Central Michigan
    I've never had the "pink milkshake" from any of the after market rads.
  16. Jul 2, 2017 at 3:38 AM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    I have a Spectrum from Pepboys in mine. I replaced the OEM (with similar leak as yours) a few years ago. No issues at all. Just got back from a 5000+ mile trip with a lot of climbing (Rockies) and desert (Utah, NM) driving. The truck barely went above the halfway mark on the temperature gauge.
  17. Jul 2, 2017 at 6:41 AM
    AlohaGoat
    AlohaGoat Active Member
    99 x cab
    Any is fine. Just always try to replace the cap with a known brand one, use toyota pink coolant and wash out the overflow tank.
  18. Jul 2, 2017 at 7:36 AM
    Itchyfeet
    They weren't made in China either.
  19. Jul 2, 2017 at 2:36 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I've had one from napa for a few years now, probably 30,000 on it, which includes a summer cross country trip through death valley, Arizona, Utah etc. Even living down here I haven't had a problem with cooling.
  20. Jul 2, 2017 at 3:39 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Where are 'factory' ones made nowadays? Lots of things have changed origin in the last 15-20 yrs.
