Cheap secondary battery setup
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KRich, Oct 15, 2021.
  1. Oct 15, 2021 at 9:51 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Ping me anytime. I'm not on much on weekends, but very often during the week.
  2. Oct 15, 2021 at 9:56 PM
    KRich
    KRich [OP] Well-Known Member
    BC, Canada
    07 Black DCSB TRD Sport 4x4
    Couldn't I use the secondary battery to power my amp and subs so only the head unit and stock rear speakers are being powered by the starting battery? Also then I could have the option to link the batteries for starting up if the starting battery happened to get too low and the secondary still had juice?
  3. Oct 15, 2021 at 10:10 PM
    YF_Ryan
    Kent, WA
    Yup! That would work. And I looked at that isolator again, and it does have the manual override. It would just need a small switch connected to it and you'd be able to self jump.
  4. Oct 16, 2021 at 3:12 PM
    KRich
    BC, Canada
    So if I decided to just get a good priced deep cycle battery that would still work for starting the truck in down to -15 weather what would be a good option or do those exist?
  5. Oct 16, 2021 at 3:26 PM
    KRich
    BC, Canada
  6. Oct 16, 2021 at 4:14 PM
    Waasheem
    Waasheem
    2007 xrunner
    Optima used to make good batteries, not anymore. There’s tons of threads on replacing with an agm battery and replacing something so it charges properly.
  7. Oct 17, 2021 at 12:58 AM
    KRich
    BC, Canada
    Should I look at something like an Odyssey or a Northstar? I found this one but definitely breaking the bank now
    https://saskbattery.com/ecommerce_488.htm
  8. Oct 17, 2021 at 7:25 AM
    Waasheem
    Waasheem
    2007 xrunner
    Wow, yeah not cheap.
  9. Oct 17, 2021 at 3:34 PM
    KRich
    BC, Canada
  10. Oct 18, 2021 at 7:35 AM
    YF_Ryan
    Kent, WA
    I never suggest a brand of batteries, simply cause I only have experience with one brand, and it's Optima, hahaha. People really have negative feelings towards them so I usually keep my mouth shut. I had three 27Fs in my truck, two blue top and one yellow top (starting battery). The blue and yellow are actually identical internally, only difference is the Blue have an extra set of smaller terminals to make hooking up accessories easier. But in regard to the "replacing something so it charges properly", YUP, some AGMs need higher voltage than a Toyota Tacoma smart alternator puts out. You have to trick the alternator into putting out more voltage to fully charge the Optima.
    https://www.ebay.com.au/itm/224393420344?frcectupt=true
    I went with this guy from HKB Electronics out of Australia. All you do is replace a fuse under the hood with it. From my understanding, the fuse is on the line for the sensor that tells the computer how much voltage the alternator is making, and lies to the computer telling it that it's putting out less 0.5-0.6 volts less than it is, so the computer tells the smart alternator to pump up the voltage by that much, thus pushing the correct voltage needed into the battery so it can be fully charged. The fuse replacement is still a working fuse, and is just as simply to replace as any standard blade fuse.
    But again, I'd like to say I'm not suggesting anyone goes this route unless they need to. Not all deep cycles or even AGMs need it. So battery research is a must when deciding. I'll keep my Optima, but it may not be for everyone!
