Cheapest brakes that are worth buying
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rmorse, Jun 15, 2019.
  1. Jun 15, 2019 at 3:59 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    Every now and then at work, I see weird stuff like Nissin pads for like $20... which are OE-quality pads. But generally, yeah, crap is cheap. If it's cheap and it's not a name you *know* is quality, odds are it's not quality.
    I go with Advics or Akebono pads, and coated Raybestos (Napa) rotors. The pads are good, the rotors are reasonably priced (though not what I'd call cheap) and have a hassle-free warranty if I have a problem. I've never paid someone to do a brake job, figure I'll use that savings to get nice(r) stuff. It's not like I do it often.
  2. Jun 15, 2019 at 4:03 PM
    rmorse
    rmorse [OP] Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    Jesus Christ. Again, I’m NOT asking for crap. I’m asking for the cheapest (lowest priced) GOOD brakes.
  3. Jun 15, 2019 at 4:04 PM
    rmorse
    Bobby
    Bowie, MD
    If you have 3 different high quality brake kits, at $400, $450 and $475, and shot quality at $50, the cheapest good brakes are the $400 ones.
    BillsSR5 likes this.
  4. Jun 15, 2019 at 5:23 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  5. Jun 15, 2019 at 6:08 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I have honestly had great luck woth autozone duralast break pads.
    I forgot to add that means I have regular brake dust amounts, no squealong or noise, get about 60 thousand miles a set on the front wheels.
    I also brake safely which of course is the most important thing.
    Tacorific likes this.
  6. Jun 15, 2019 at 6:12 PM
    jandrews
    '09 FourDubDee TRD OR
    Auto parts store stuff will work fine, it'll just be noisy, not last as long, and create more dust.
    OEM is probably the best value for the dollar, but that's my $.o2
  7. Jun 15, 2019 at 8:51 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Ebay,from a dealer on the Ebay site.
    rmorse[QUOTED][OP] likes this.
  8. Jun 16, 2019 at 1:04 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Ditto on the autozone brakelast or oreilly select ceramics. The top line pads average $60 and have a lifetime warranty - if the pads wear down evenly, they will be replaced when they wear down to 3mm. The parts dudes have told me this and scotty kilmer has also mentioned this on his car videos. I have them on my taco and es350; vehicles brake fine. I've used wagner thermoquiet pads before and they are also good pads; have them on daughter's camry. Have durago pads/rotors on the corolla; these are cheap lower end brake parts but they also stop fine.
  9. Jun 16, 2019 at 3:39 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Haha...agreed. I’m glad my condom-wearing days are long over.
    Oh and OP...go with OEM brake pads for best results.
  10. Jun 16, 2019 at 5:52 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    I like the TRD brake pads by the way, little dusty, improved stopping though. :)
  11. Jun 16, 2019 at 12:01 PM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    Amazon.......
    regular OEM 'Yota brakes vs the TRD pads........?
    worth the $25ish extra ?
  12. Jun 16, 2019 at 12:11 PM
    TegoTaco
    Ontario, Canada
    I think so!
  13. Jun 16, 2019 at 12:25 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Look on Autoanything site shows all types and 22% off today - fathers day.
    I have Powerstop drilled and slotted with z36 pads as I tow my boat and trailers and wanted some increase in stopping power - help some. Better than stock. I still have stock calipers.
    We just put the Powerstop complete 4 wheel plain old rotor set and pads on a hemi challenger and they work well too as the guy was feeling cheap - 1/3 to 1/2 less.
    With all their pads read and follow the new pad/rotor burn in procedures as makes a big difference in the end result stopping response.
