Cheapest oil analysis and why to do it?
Discussion in '2nd Gen. Builds (2005-2015)' started by egres, Sep 1, 2013.
  1. Sep 1, 2013 at 8:54 AM
    egres
    egres [OP] Well-Known Member
    DELCO PA
    13 singel cab - 2WD - manual - 17K before tax:)
    Bench-seat covers $180 (Can't believe its not leather),Bed Liner $375 (Bed rug), Roof rack $180 (Rhino-rack 2500 Series, plus DK clamps and pads), Modified Bed extender $85 (Extend-A-Truck 944 Truck Bed Extender), Hood lift assist $80 (RedlineTuning), Hood light $53 (tacomaworld.com âtacodaneâ), Hitch receiver $120 (Curt Manufacturing 13323 Class III Receiver), T connector for trailer $43 (CURT Manufacturing 55513 T-Connector), Manuel tailgate lock $30 (gatekeeper tailgate lock), Tailgate assist $28 (Sachs SG329900EZ Lift Support), Tailgate lock $67 (Pop & Lock Tailgate Lock Tailgate Lock PL5301), Spare tire lock $12 (Trimax ST30 Trimaflex Spare Tire Cable Lock), Hardwired battery float charger $20 (Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps) , Vin # Glass etching $33 (vinguard.org), Easy oil drain plug $30 (Fumoto Engine Oil Drain Valve), Floor mats $80 (Husky Liners 2-Piece Front Liner 2-Piece Front Liner), out of space :)
    I see from time to time some guys talking about sending oil in for analysis. I started to think i could try that too and checked price for service, it's over $20.
    So if one wants to know how his engine doing he does one of this test but would it be counter productive to do this test just to find out if one needs to change oil? Even if it comeback "don't change your oil" you have little life left on it.
    My oil and filter is around $35, why not just change it?
    2nd. question: Do you know any place cheaper then $20?
  2. Sep 1, 2013 at 9:06 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    I wouldn't do it, ever. Ill let some other schmuck fund blackstone.
  3. Sep 1, 2013 at 9:06 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Just change the oil and filter out at Toyota's recommended intervals... especially since your under warrenty.
  4. Sep 1, 2013 at 11:55 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    This.
    UOA is generally used to verify oil life for people who have bought into the false economy of extended drain intervals using synthetic.
    UOA is a useful tool to evaluate oil if you are comparing brands and grades, but beyond that, it is OCD overkill for most consumer vehicles.
    Where it has value is in OTR trucks, which carry several gallons of oil, and change intervals are measures in tens of thousands of miles. For them, that $30 (with TBN) is worthwhile if they can put off a $300 oil change for another 20k. It is also useful for boat owners, where engine hours are the "mileage" equivalent, but idle time and high load conditions vary drastically, as well as heat and humidity levels that can impact condensation (and they too take 2+ gallons per engine).
    Like OffroadToy said.... Change it every 5,000 and you're golden. My recommendation is to stick with the factory filter (cheap and good), and use a quality synthetic like Mobil-1, Amsoil, or Redline.
    You have a '13 2.7, so you're stuck with synthetic anyways.
  5. Sep 1, 2013 at 12:08 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I've had them done before when I was running longer oil change intervals. In retrospect they can be a good source of information about the internal condition of your engine and the life of your oil. However if you're running the normal recommended oil change interval I don't think it's something I would worry about.
  6. Sep 1, 2013 at 12:33 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Exactly.
    Not a bad idea to get one on a used car (especially if the oil hasn't been changed recently), and it's not a bad idea to have one done maybe every 40k to give a little insight as to your engine's possible future.
    Now that I think of it, I've got about 95k on my '08, I bought it a couple of years ago with 53k on it. I think I'm going to have one done this oil change.
