cheapest place to get genuine toyota d-rings?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xtirtzt, Mar 7, 2009.
  1. Mar 7, 2009 at 3:36 PM
    xtirtzt
    xtirtzt [OP] Addict.
    Connecticut
    08 trd sport 4x4
    afe pro-dry S, flowmaster 40 series, ipod interface, black headlights, yellow fogs
    want to order extra set of genuine toyota
    d-rings...where is the cheapest place to get em?
  2. Mar 7, 2009 at 3:39 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    Well are you looking for toyota's d-rings? or are you looking for d-rings that are similar?
    I think the toyota ones are pretty pricey but you can get similar ones for like $5 for a 5 pack.
  3. Mar 7, 2009 at 4:12 PM
    lasllc
    lasllc Well-Known Member
    SW Denver Burb
    13 SuperWhite DCSB Sport 4X4 Tow Pack
    SnugTop Super Sport, BedRug mat, Redline Tuning hood lifts, LED interior lights, 3D carpet protectors.
    PM'ed Xtirtzt.
    Roger
  4. Mar 7, 2009 at 4:53 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Salvage yard
  5. Mar 7, 2009 at 5:44 PM
    lasllc
    SW Denver Burb
    You might note that "similar D-rings" are, in fact, a dime a dozen, so to speak.
    But you wont get the backing plate, nor the nylon hold off washer to allow it to spin around, nor the proper length, non threaded fastner so that the unit can be torqued down to eliminate free play; very bad to have in plastic substrates.
    I dont think a composite bed is very campatible with a drilled thru d-ring with out a sizable backing plate, even if you use a large surface washer.
  6. Mar 7, 2009 at 6:26 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    ^Who said you're supposed to drill through the bed for the non-Toyota ones? You put them in the bed bolts.
  7. Mar 7, 2009 at 6:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Probably get more strength that way too. :)
  8. Mar 7, 2009 at 7:02 PM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2009 DC V6 TRDsport
    5100's all around - fronts at 1.75", 265/70/17 Bridgestone Revo 2, HID headlights and fog lights, factory skid plate, ss exhaust tip, tube steps, Access roll-up tonneau cover, Redline hood struts, 6 D-rings, seat MagLite, LED dome, fumoto oil drain, DTRL, fog light anytime, Kenwood/Clarion speakers, Pop-N-Lock 5300, LED bed lights and a few other things...
    Just did this today:
    (pack of 2) - www.TRDParts4U.com: $18.88 + $10.49 (shipping) = $29.37
    LINK TO PURCHASE
    Remove small black washer, bolt and backing plate from the d-ring assembly. Unbolt using a T-55 bit purchased from Auto Zone for $3.57. Using angle grinder, cut off portion of washer so it sits properly on the hinge (holding other side with pliers). The large washer does not come off the bed bolt unless you grind down lock rings. I just left it on there to cut. Used some blue thread lock on the bolt and stuck it back in. Total project took 30 minutes (w/ trip to Auto Zone).
    Did it just as Piercedtiger did in his thread.
    ANOTHER
    AND ANOTHER
  9. Mar 7, 2009 at 10:02 PM
    Veccster
    Veccster bass turds
    Eric
    2009 DC V6 TRDsport
    I may order another set for the middle bed bolts and would definitely order the cheaper ones. I'll compare because I want the stronger ones in front as they get the tie downs for my bikes.
    I thought I could use the backing plate as well. Later learned I couldn't. :eek:
  10. Mar 7, 2009 at 10:56 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Yes, as long as you don't cross thread the $12 bolt like some fools do... :pout:
  11. Mar 7, 2009 at 11:12 PM
    ldanny
    ldanny Well-Known Member
    where did you get the cheap ones?
  12. Mar 8, 2009 at 8:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :rofl:
    I wasnt going to say anything......
  13. Mar 8, 2009 at 11:42 AM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    These are out of a chevy uplander van.
    They are much heavier in construction than the OEM Toyota ones.
    Marc M
  14. Mar 8, 2009 at 5:05 PM
    rmb_crew
    I just got mine in the mail front army surplus and they seem pretty well made. I will work on putting them in just gotta get the hex bit and start working.
  15. Mar 10, 2009 at 5:55 PM
    ldanny
    where did you get the uplander van
  16. Mar 10, 2009 at 6:25 PM
    Marc M
    Marc
    '06 TRD O/R Dbl-Cab
    It's my dad's company vehicle. They were removed to install some custom cabinets for storage.
    Marc M
  17. Mar 10, 2009 at 6:28 PM
    rmb_crew
    It's was really easy to do. U just have to grind the ribs off the bolt. Enlarge the hole on the d-ring and slide it all together and they seem really sturdy.
