Cheapest way possible?
Discussion in '1st Gen. Tacomas (1995-2004)' started by magic, Feb 10, 2012.
  1. Feb 10, 2012 at 1:53 PM
    magic
    magic [OP] Well-Known Member
    So last year i went with a 3" toytec spacer lift with procomp shocks. And its not riding as good as i would like it. What is the most effective/cheapest way to improve ride quality?
    Put fox shocks up front with the spacer?
    Ebaich and 5100's up front?
    i know it would be best to just get nice king/icon coilovers but the fact is im a poor student haha and i dont offroad race so i dont need nor can i afford brand new performence coilovers.
    thanks
  2. Feb 10, 2012 at 1:55 PM
    ttran
    ttran Expert Mallcrawler
    Tim
    Cary, NC
    06 DCLB Prerunner Sport
    TRD Sport Prerunner
    Eibach and 5100's. You won't regret it. It's what I'm running right now and I love it.
  3. Feb 10, 2012 at 1:55 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Using Fox shocks with a spacer is like using Chanel to make a pig stie smell better...
    Lift coils with the appropriate shocks would be your best option, 5100's with stock coils would be next best and a little bit cheaper.
  4. Feb 10, 2012 at 2:23 PM
    alove0750
    alove0750 Well-Known Member
    Adam
    Concord, NC
    2015 DCSB 4x4
    Icon coilovers, shocks and springs SPC Upper Control Arms SCS Ray 10’s w/ 265/70R17 BFG KO2’s Leer 100XR shell
    Just pinch pennies and save up for the coilovers... the price seems rough, but once you do it you will never look back... I had the 5100's and coils, not a bad ride, but it doesn't hold a candle to coilovers
  5. Feb 11, 2012 at 7:20 PM
    magic
    what kind do you recomend? please remember $$ is an issue for me haha
  6. Feb 11, 2012 at 7:43 PM
    magic
    and wouldnt i need to upgrade UCA's? so im looking a 450 atleast.... it looks like ill be sticking with spacer and prcomp shocks for a while
  7. Feb 11, 2012 at 7:46 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Fox shocks with a spacer? :confused:
  8. Feb 11, 2012 at 7:53 PM
    Irish020
    Irish020 Well-Known Member
    Phil
    Pennsylvania
    '05 Tacoma TRD Sport 4 Door Longbed
    ARE Hard Tonneau Cover Flowmaster American Thunder Super 50 Series Stainless Dual Exhaust Toytec Ultimate 3" w/ UCA's
    Coilovers, UCA's, and sway bar relocator....
  9. Feb 11, 2012 at 7:54 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    im not sure if you people that post that realize what it is like to be on a limited budget and try to lift a truck the right way, but "pinching pennies" for a 700 dollar C/O lift is not practical. depending on the budget you could wait a year.
    personally i just ordered a set of 4 5100s, a toytec AAL and the diff drop kit. My coils and leafs are in surprisingly good condition considering the age of the truck, so i can use the stock coils. if your leafs and coils are still good, with no negative arch or weak coils you could get what i did. $418 to lift the truck 2.5" the right way. getting eibach front coils, which would improve the ride and give you 3" with the 5100s set at o, will be an extra 150. not bad if you are on a budget.
    body lift<block/spacer<5100s/AAL<5100s with eibachs/progressive 3 aal<C/Os with a brand new leaf pack
    just went through all the same questions and situation as you man. you need new ucas ($500) after 3" of lift of you will not be able to get your alignment back . also for anything over an inch the diff drop is highly recommended, it actually works for the 1st gens. so you are going to want to keep it under 3" if you dont plan on doubling the cost of your lift
  10. Feb 11, 2012 at 7:58 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    this
  11. Feb 11, 2012 at 8:00 PM
    sir1123
    Charleston
    some people have gotten there tires back to aligned with 3" on here. i had 3 1/2 inches when i first got into modding my truck and there was no crowning. now i just have 3" and they were fine till i took it to tire kingdom.FML
  12. Feb 11, 2012 at 8:03 PM
    TexasTacoma37
    It wouldn't be camber or toe that they can't get right without ucas, so no effect on tire wear. Its the caster you can't get right, which can lead to a wandering feeling.
  13. Feb 11, 2012 at 8:05 PM
    TACWUT
    TACWUT Well-Known Member
    San Diego
    12 prerunner DC
    Flowmaster turndown, 5100 up front/5150 rear, maxtrac spindles, 2" tuff country add a leaf+TSB.
    Are u a 4*4?
  14. Feb 11, 2012 at 8:07 PM
    sir1123
    Charleston
    oh i see so camber is pretty adjustable? and in my case i have never had wandering
  15. Feb 11, 2012 at 8:12 PM
    TexasTacoma37
    They can usually get the camber in spec by making the caster way too low. And the wandering is all relative, I'm sure your truck would handle better with aftermarket ucas, but if you can live with it then its all good.
  16. Feb 11, 2012 at 8:41 PM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
  17. Feb 12, 2012 at 4:09 PM
    magic
    To answer any Q's..... Yes my truck is a 4x4.... My current setup is 3" toytec spacer with w/ stock tacoma coils(coils were in good shape) w/ decent promcomp shocks with diff drop. In the rear 1.5" toytec spacer w/ decent procomp shocks. On procomp black 16x8" with 3.75" bs with 285/75/16
  18. Feb 12, 2012 at 4:16 PM
    alove0750
    Adam
    Concord, NC
    2015 DCSB 4x4
    For the money I don't think you can beat the Toytec's... they aren't horribly expensive and have a great ride quality!
  19. Feb 12, 2012 at 4:23 PM
    alove0750
    Adam
    Concord, NC
    2015 DCSB 4x4
    I'm a full time college student working minimum wage, it doesn't get much more limited. The biggest thing is your budget... if you want a nice lift, wheels, tires or anything else for that matter you just have to cut out all the non-necessities. Cut out the fast food and other nickel and dime things that you don't think about for one of two months and you would be amazed at how much money you have.
  20. Feb 12, 2012 at 7:29 PM
    magic
    arent the toytec's just ebaich coils with 5100's with a different name because toytec essemblied them?
