Cheapest way to lift?
Discussion in 'Suspension' started by DaytonLax14, Nov 24, 2009.
  1. Nov 24, 2009 at 11:54 AM
    DaytonLax14
    DaytonLax14 [OP] Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    I want to lift my truck so I can fit some 33s under her. Plus, I want it to sit a little higher anyways.
    And by cheapest, I don't mean being ghetto and using hockey pucks. And I don't want a lift that is going to screw up my truck in the long run (some body lifts are bad for your truck?). If i can do a BL that isn't going to mess anything up with my truck in the long run, then i'm open to that.
    Thanks.
  2. Nov 24, 2009 at 11:55 AM
    Kenny650
    Kenny650 Well-Known Member
    Adjustable Bilsteins 5100's (4) for $300
  3. Nov 24, 2009 at 11:56 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Look into the Bilstein 5100s and an add-a-leaf kit. That will give you a 2.5" Lift. for the full 3" you can add a small topspacer with the 5100s.
  4. Nov 24, 2009 at 11:58 AM
    DaytonLax14
    Corey
    Ohio
    how much lift will that give me?
  5. Nov 24, 2009 at 9:47 PM
    nelztaco
    nelztaco Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
    Look at the year of his truck
  6. Nov 25, 2009 at 8:22 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Give us a budget on how much you want to spend on just the lift kit not including rims, tires, alignment and labor cost. && how you are going to use your truck daily.
  7. Nov 25, 2009 at 8:46 AM
    Brunes
    Brunes abides.
    Rotorhead
  8. Nov 25, 2009 at 2:13 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    To fit 33's completely you just might need a inch of Body Lift. And Body lifts are not horrible for the vehicle.
    Usually you are able to fit 32's with 3 inches of lift.
    With that old of vehicle, I would highly recommend staying away from spacers. With that many miles, you really need to replace both the front coil and shock.
    What is your exact budget?
  9. Nov 25, 2009 at 9:20 PM
    nelztaco
    Neil
    Levittown, PA
  10. Nov 26, 2009 at 12:33 AM
    VenomTaco88
    VenomTaco88 Just Got Engaged!
    Mtn Home AFB, ID
    Love my Venom Taco
    K&N cold air intake, Full Double Wall stainless steel Megaflow exhaust, custom nerf bars
    So would it be possible to do a 5125s wit ha aal to make it a even 3 inch lift then a 1inch body and how do body lifts work are they expensive cuz ive ogt this same problem i have about about 2k to spend on this lift total(without the tires and wheels) and i dont want a 6 but i want a little bigger then 3 so if u could explain a little more to me and ive looked into the ultimate package but how much would that cost to get installed?
  11. Nov 26, 2009 at 7:48 AM
    DaytonLax14
    Corey
    Ohio
    So are body lifts bad for your truck in the long run?
  12. Nov 26, 2009 at 2:55 PM
    DaytonLax14
    Corey
    Ohio
  13. Nov 26, 2009 at 6:36 PM
    sirsaechao
    Tim
    Commifornia
    I say a solid 3" suspension lift, correct BS wheels and 285's with some trimming will be best.
  14. Nov 28, 2009 at 3:00 PM
    Toytec Lifts
    Rocky Mountains
    Rear shocks offer no lift!
    Body lifts are not expensive at all.
    The ultimate package is going to take a shop between 4-8 hours to perform.
