Check Brake System Tacoma wont start
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dbmiller8, Feb 9, 2024.
  1. Feb 10, 2024 at 3:58 PM
    lavrishevo
    lavrishevo Well-Known Member
    2023 Trail Edition
    I would lean toward it being related to the switch you just replaced.
    dbmiller8[OP] likes this.
  2. Feb 10, 2024 at 4:13 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Me too.
    OP says he doesn't want to crawl under the truck, and checking at the relay will confirm if the switch is send power to the relay.
  3. Feb 10, 2024 at 5:01 PM
    dbmiller8
    dbmiller8 [OP] Member
    I will check that tomorrow. Thanks.
    TnShooter[QUOTED] likes this.
  4. Feb 11, 2024 at 2:50 AM
    dbmiller8
    I have a boroscope. I will try to use that to get eyes on the NSS today. I am pretty sure if the switch was bad, I would be getting the P0705 error I was getting before it was changed. Misalignment of a good switch? Seems like Check Brake System is a weird symptom for that issue but that may be the case. I am guessing I will have it towed to the garage that did the work on Tuesday. Again, thank you for the help.
  5. Feb 11, 2024 at 2:53 AM
    MGMDesertTaco
  6. Feb 13, 2024 at 2:19 PM
    dbmiller8
    To follow up on this, had the truck towed to the mechanic. They worked in it pretty much all day. Said someone put the EFI 2 fuse in the wrong slot. Also said the front brakes need replacing and that was the reason the Check Brake System was illuminated. When I told them I would bring it back next week to have them changed(as I stated earlier, I am too old at this point to sit on my cold driveway) they did say the Neutral Safety Switch they put in was also defective. My guess is that was the issue all along and they want to recoup their costs since the truck was exhibiting the same issue before I checked any fuses and they needed an excuse…
    Thanks again for the help. I appreciate it.
    MGMDesertTaco likes this.
  7. Feb 13, 2024 at 3:33 PM
    MGMDesertTaco
    I'd get another opinion regarding the front brakes needing replacement. You probably don't need them.
  8. Feb 13, 2024 at 3:50 PM
    dbmiller8
    I agree. That is why I told them I would bring it in next week.
