Check Brake System Warning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by baltimorebirds2, Apr 17, 2022.
  1. Apr 17, 2022 at 9:19 AM
    baltimorebirds2
    baltimorebirds2 [OP] tacomama
    Brooks
    Maryland, United States
    2018 MGM Tacoma TRD Sport DCSB 4x4
    TRD Pro 17” Wheels, Toyo Open Country AT3 33s” (255/80/R17), Hooke Road Offroad Roof Rack, LEDs (Low Beams, High Beams, Fog Lights, Interior Lights, Reverse Lights, License Plate Lights), Diode Dynamics SS3 Sport Fog Lights (Yellow), Sequential Turn Signals, OME Nitrocharger Plus, OME 4004's & HS 0.5 Spacer for 3" Lift, JBA UCA, Icon RXT Option 2 Leaf Springs 2.25" Lift, Yukon Clamshell Bushing, Alpine ILX W-650 Stereo, Infinity Primus 6004a Amplifier (140w*2), Sound Ordnance M75-4 Amplifier (75w*4), Infinity Kappa 693C Component 6x9 Speakers, Infinity Kappa 63XF 6.5 Speakers, TRD Shift Knob, Black Emblem Overlays, TRD Grille Badge, OEM Door Sill Protectors, Driver’s Seat Jackers, Pop and Lock Power Tailgate Lock, AJT Designs start button and trim, 4x4 knob, shifter trim, and cupholder trim, MESO Customs Vent Rings and Door Handle Covers, Gasshole, Drop Stops, AC Drain Mod, Bed Lights, Rough Country Roll Up Tonneau Cover, Window Tint, KDMAX Tune
    Hey all, Happy Easter.
    Just had a random question for you guys, just wanted to see whether anyone else has had this happen to them. So when at idle, after I had the drums off and was painting the drums, I messed with the shoes a little bit while also discovering I had a torn wheel cylinder boot. Anyway, ordered replacement advics units to replace them. They aren’t leaking now but want to do it and get it out of the way, so I don’t have to worry about it in the future. Anyway, I press the brake pedal several times and rapidly, a good bit into its travel, and then I pushed it down far enough, but it didn’t feel far, and then the check brake system light came on. Mind you, this is all at idle. Then I rev it up and start driving and it’s all back to normal. I was thinking this was because the engine can’t produce enough vacuum for the booster at idle, which would explain why it changes when the engine revs. Any thoughts? Thanks.
