Check Charging System and Check Brake System warnings coming on after using PB Blaster
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jbronnier, Mar 5, 2025.
  1. Mar 5, 2025 at 2:39 PM
    jbronnier
    jbronnier [OP] Well-Known Member
    Josh
    2019 TRD Sport
    So basically, i’ve had this issue with my manual safety switch for a while where it gets sticky when I don’t drive the truck for a while.
    Well, I’m looking to sell the truck cause I got a new one for work so I PB blast the manual safety switch a little to loosen it up. I’ve done this before and not had any issues. However, this time when I go to turn the truck on after I get these two warnings and it doesn’t even attempt to turn over.
  2. Mar 5, 2025 at 4:21 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    You likely pushed something, into contact. Vacuum
  3. Mar 5, 2025 at 4:30 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    you sprayed Peanut Butter on a safety switch?
    t0p_d0g, usmc2msu and BillF1564 like this.
  4. Mar 6, 2025 at 5:11 PM
    jbronnier
    Josh
    2019 TRD Sport
    You think air blasting the area might help? Vacuum what exactly?
  5. Mar 6, 2025 at 6:44 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    It’s called karma replace the switch.
    jmneill and photodoc like this.
  6. Mar 7, 2025 at 12:41 PM
    Greg-tacoma
    Greg
    2016 Black 4cyl 4wd
    Vacuum where you pb .
  7. Mar 7, 2025 at 12:45 PM
    jbronnier
    Josh
    2019 TRD Sport
    I'll give it a shot!
  8. Mar 7, 2025 at 12:50 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Check charging system is normal and always displayed if the ignition is on but the engine is not running. Focus on the brake system warning.
    soundman98 likes this.
  9. Mar 7, 2025 at 3:22 PM
    photodoc
    photodoc Of the paths u take in life make sure a few r dirt
    Northern Kentucky
    '23 TRD PRO 6MT
    This.
    t0p_d0g[QUOTED] likes this.
  10. Mar 7, 2025 at 4:12 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    If it didn't turn over, it means the switch is still stuck on.
    The warnings are what display of the ignition is turned on without the engine running.
  11. Jun 2, 2025 at 5:40 PM
    Texas-Gorilla
    Texas-Gorilla Well-Known Member
    Thomas
    2016 Tacoma TRD OR
    The check charging system warning light came on today on my son's Tacoma. Drove it about 2 minutes over to AutoZone to have them check the battery and alternator. Noticed the power steering was out and the AC wasn't coming on.
    Battery checked out good but the alternator fail. Upon further inspection the serpentine belt had broken in half. I borrowed a few tools and changed the belt out in the parking lot. Warning light went off as soon as I started the truck up and stayed off during a test drive so I think I'm all good now. Truck has 118k miles and I should have changed the belt sooner.
    Canadian Caber likes this.
