Check Charging System Message
Discussion in '3rd Gen. Tacomas (2016-2023)' started by winding2005, Jun 3, 2025.
  1. Jun 3, 2025 at 6:36 PM
    winding2005
    winding2005 [OP] New Member
    2022 V6 4x4
    I'm a first time Tacoma owner as of today. The first time I put key into the ignition, I got a "check charging system" warning. When I start the truck up, the warning goes away and there is no record of the message. Is there something wrong with the truck or is this normal startup stuff? I read some AI response about this how this feature is intended to let the operator know that the battery is being drained while in the "on" key position. Any insight would be welcome.
    Thanks.
  2. Jun 3, 2025 at 6:39 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Normal.
    If you want to keep the radio on, drive in movie, and drive an automatic, put the gear knob in Neutral, set parking brake, and turn off the ignition.
  3. Jun 3, 2025 at 6:58 PM
    WheelinDev
    WheelinDev Active Member
    2020 TRD Pro
    Normal. My truck does this too.
  4. Jun 4, 2025 at 3:44 AM
    winding2005
    2022 V6 4x4
    Thanks for the feedback.
  5. Jun 4, 2025 at 4:13 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Welcome to the forum :hattip:
    Normal.
    Vehicles have done this for 60 years or more, the "ALT" or "GEN" light came on when the key was on but the engine not running.
    Since modern vehicles use words on a screen instead of a light it really catches peoples eye - and imagination. :eek:
  6. Jun 4, 2025 at 2:38 PM
    Barok206
    Barok206 Well-Known Member
    2018 Cement Tacoma TRD OR
    Welcome to TacomaWorld.
    Patch Barracks likes this.
  7. Jun 4, 2025 at 7:13 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    Yep, no big deal, this truck just makes it more apparent than most.
    When any vehicle is on, but not running. The battery voltage is somewhere around 10-12 volts.
    When the engine is running, the charging system is active and makes the battery voltage 13-14v.
    The dash warning is programmed to come on for any voltage below 13 volts.
    Phlogiston, Chew and winding2005[OP] like this.
  8. Jun 7, 2025 at 1:37 PM
    winding2005
    2022 V6 4x4
    Thanks for all your responses. This seems to be a very informative forum. Glad I stumbled on to it.
    RustyGreen and Chew like this.
  9. Jun 7, 2025 at 5:40 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    This site is what the Internet was built for -
    Straight up information with a little teasing on the side.
    I belonged to another 'automobile-brand-site' and the rantings and ravings about nothing made me wanna hurl.
    After about a year of it I posted something so disgusting I got banned for life LOL... just what I wanted.
    Phlogiston likes this.
