"Check Charging System" takes several tries to start up...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco^^taco^^taco, Nov 22, 2018.
  1. Nov 22, 2018 at 9:12 AM
    Taco^^taco^^taco
    Taco^^taco^^taco [OP] Member
    Oregon
    2018 Toyota Tacoma TRD OR, Manual 6 Speed, Magnetic Gray Metallic
    Just bought my dream truck last Friday and I've been noticing issues with starting it. It only happens on occasion, but it's super annoying! I understand the "Check Charging System" warning and check engine light is normal, but occasionally I have to try the ignition several times to get a turnover. I have tried a few different things: clutch fully pressed to the floor, clutch 90%, in gear, in neutral, e-brake on/off, turn ignition off then back on. Not sure what is going on when that happens... Eventually it will start and everything seems fine. This does not happen only on cold starts. Any ideas?
  2. Nov 22, 2018 at 9:13 AM
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    have them check the battery, it may not be fully charged or one of the cells are dead. Happens.
    Taco^^taco^^taco[OP] likes this.
  3. Nov 22, 2018 at 9:17 AM
    Taco^^taco^^taco
    Oregon
    Is that something I could do at O'Reillys/Napa or do I have to go to the dealer? I'm two hours away from the dealership.
  4. Nov 22, 2018 at 9:21 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Is there any dealership close by? It does not have to be the one you purchased from, its a warranty issue since you just bought the truck.
    But yes, any autopart store can do a test on it, but then you would have to buy the battery and try to get reimbursement from Toyota.
  5. Nov 22, 2018 at 9:22 AM
    2005 TRD Sport
    2005 TRD Sport Well-Known Member
    NM
    17 Black LTD
    Chrome step tubes, bed extender
    Auozone can do it too
  6. Nov 22, 2018 at 9:24 AM
    rob4092xx
    rob4092xx Well-Known Member
    Phoenix, AZ
    Check the battery connections. Loosen them, twist them, then re-tighten.
    over60 and Taco^^taco^^taco[OP] like this.
  7. Nov 22, 2018 at 9:26 AM
    Taco^^taco^^taco
    Oregon
    Closest Toyota dealership is a little over an hour away. I live in the boonies! It's just an inconvenience to go there if I don't have to.
  8. Nov 22, 2018 at 9:26 AM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Bad battery is my guess.
    shakerhood likes this.
  9. Nov 22, 2018 at 9:28 AM
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    It could be one of two things, or both. As a 2018 it probably sat on the lot for awhile (1) and the Johnson Controls batteries are not always that great (2). They should have tested the battery on delivery. That's what my dealer did, but I've replaced mine with an Odyssey sealed battery.
  10. Nov 22, 2018 at 9:28 AM
    2005 TRD Sport
    NM
    17 Black LTD
    Go to auto parts store and have them check the battery. If it’s bad call the dealer & take it in.
  11. Nov 22, 2018 at 9:30 AM
    TD90S
    TD90S Cool as a cucumber in a bowl of hot sauce
    GA
    ‘18 TRDOR 6MT
    As already stated. Have the battery checked first. Any number of your local auto parts stores can do it for you.
    If it tests bad you will have to decide to take to dealer or handle it on your own.
    Good luck!
  12. Nov 22, 2018 at 9:33 AM
    Taco^^taco^^taco
    Oregon
    Thank you all, I will post again with results. Happy Thanksgiving!
    TD90S likes this.
  13. Nov 22, 2018 at 9:40 AM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    Don't know if this is your first Tacoma or not, if it is one thing I had to adjust to when I bought my first in 02 was getting used to the clutch sensor. I came from Honda manuals none of witch had a sensor that stopped it from starting without the clutch fully engaged. So i was used to cheating a bit by not having the clutch completely to the floor. On Tacomas with a manual you have to completely put the pedal to the floor for the truck to start.
    Don't know if that's what's happening in your case but for me I had to adjust with my first one.
    Congrats on the truck by the way, and Happy Thanksgiving.
  14. Nov 22, 2018 at 10:01 AM
    Taco^^taco^^taco
    Oregon
    It very well could be user error on my part. I've heard the floor mats can sometimes obstruct the clutch, so I will be mindful of that this weekend and take it in on Monday if the problem persists. Thank you for your reply and Happy Thanksgiving to you too!
    02Duck[QUOTED] and shakerhood like this.
  15. Nov 22, 2018 at 10:11 AM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Welcome to TW!
  16. Nov 22, 2018 at 10:17 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If you are unsure about how far you are pushing the pedal in try the Clutch Cancel Switch and see if it starts that way.
    tacoguy88, black coffee and 02Duck like this.
  17. Nov 22, 2018 at 12:58 PM
    Troglodyte
    Troglodyte New Member
    2018 TRD OR MT
    I haven’t had any problems starting the truck, but my wife complained about this issue. The only problem was she wasn’t giving it enough time to catch. Once she let the starter do its job, the truck started fine for her. I think she was used to her WRX and expected the truck to start the same.
  18. Nov 22, 2018 at 7:41 PM
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I had the same problem about a year ago. Turns out it was a bad battery. Dealer tested it and replaced it
  19. Nov 27, 2018 at 10:03 PM
    Taco^^taco^^taco
    Oregon
    I am now convinced it was just user error, thank God! I have been diligent with pushing the clutch all the way to the floor to start my truck and it has worked every single time! Thank you all for your input, you saved me a trip to the dealership!
    black coffee and shakerhood like this.
