Check Charging System Warning Message
Discussion in '3rd Gen. Tacomas (2016-2023)' started by blens, Oct 16, 2015.
  1. Aug 28, 2017 at 1:57 PM
    #61
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    It's not going to charge until alternator is rotating.
  2. May 3, 2018 at 7:56 PM
    #62
    LILBEAR
    LILBEAR Well-Known Member
    Winnipeg , Manitoba
    2018 Tacoma SR5 Black
    None brand new
    I bought my 2018 Tacoma SR5 last week brand new.Waiting for my wife this morning listening to the radio for 10 minutes turned key forward to start and check charging system came up too with large battery below it. I know owners manual said not to do it for long periods of time.I called dealer they said no problem unless starter was draging trying to start or slow cranking.But that wasn't the issue fired right up no problem.It must be like an idiot light. LOL. Don't listen to radio without truck running.They also told me there were a lot of other things drawing power too not just the radio. So how does a person know that the system is not over charging and that is why it is coming up?
  3. May 5, 2018 at 5:57 PM
    #63
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    That is normal for that screen to come on like that, if the truck is running and it comes up then you have an issue.
    2016Tacoman likes this.
  4. May 5, 2018 at 6:58 PM
    #64
    LILBEAR
    Winnipeg , Manitoba
    None brand new
    Ok thanks I feel better about that now.
    shakerhood[QUOTED] likes this.
  5. May 6, 2018 at 2:13 AM
    #65
    unk
    unk Well-Known Member
    San Jose
    2017 TRD OFFROAD
    FOX 2.5 Factory Coilovers w/resi DSC @fox ———————————————- Camburg Kinetik Series Upper Billet Control Arms @camburgracing ——————————————— FOX 2.5 Factory Shocks w/resi DSC @fox ——————————————— Icon Vehicle Dynamics AAL @ivdsuspension ——————————————— Baja Designs Squadron-R amber fog light kit @bajadesignsofficial ——————————————— RCI Bed Rack @rcioffroad ——————————————— Tepui KUKENAM 4 XL Ruggedized @tepui
    Have not tried yet, but using the radio at the drive-in scares me. Anyone use radio for 2hrs?
  6. May 6, 2018 at 3:13 AM
    #66
    KBOX
    KBOX In a va.. *cough* truck down by the river.
    Jody
    Acton, Ontario
    2017 Tacoma DC Sport V6M 4X4
    Stock
    Drive-ins still exist?
    Kodiak420 and shakerhood like this.
  7. May 6, 2018 at 6:39 AM
    #67
    shakerhood
    Southern Ohio
    Wish my local Drive-In had not closed a few years ago, was alot of fun.
  8. Jun 16, 2019 at 9:05 PM
    #68
    MtnMan75
    MtnMan75 Member
    2016 Tacoma SR5 Access Cab / 2016 Tundra SR Double Cab LB
    A battery indicator LED was all that was needed or the message should have read running on battery power only, not "Check Charging System". The message in the middle of the screen telling you to check your charging system that when cleared still shows back up during the same time you are trying to do something like reset TPMS is just piss poor engineering. Tapping off the tachometer circuit is all the more that was needed to know the engine isn't turning and a charging voltage is not required at that point so once the message was cleared that should have been the end of it. Instead, you make people question what is going on during a process listed in the book to reset the tire pressure sensors without mentioning this will be on the display. I'm very mechanically inclined and more so, electronics is my background, but I ended up getting a volt meter out for no reason to check this. Again... piss poor engineering.
    Kodiak420 likes this.
  9. Jan 4, 2020 at 11:53 PM
    #69
    MrLimber
    MrLimber New Member
    I agree, this is bad design. Have a new 2020 and will be having them check the battery on the first oil change. If this is normal it shouldn't show a warning, plain and simple.
  10. Dec 8, 2023 at 10:21 AM
    #70
    Trucktinker
    Trucktinker New Member
    2023 Tacoma access cab
    When the message came up, I checked battery voltage with truck not running. Measured 12 volts. Cranked truck and got tad over 13 volts. This proved that charging system is putting out. Glad to read all the replies. Makes me feel better. Glad to find tacomaworld!!!
    Kodiak420 and Chew like this.
  11. Dec 8, 2023 at 10:22 AM
    #71
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    welcome!
    It is kind of alarming, but we also get that it is looking for voltage while the engine isn't running.
