Check charging system warning message
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2boat, Apr 18, 2018.
  1. Apr 19, 2018 at 2:44 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    If this is serious before you ask here are the other common questions that come with these.
    The jerky feeling you get while turning on dry pavement in 4x4 is normal for part time 4x4 and you shouldn't be driving in 4x4 without wheel slip. So 4x4 on pavement is a no no if it's not slippery
    You can only fit a 265 70 17 or 265 75 16 tire for sure without rubbing and needing to cut stuff.
    I think that covers most of the recurring threads
    daddy_o likes this.
  2. Apr 19, 2018 at 2:44 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Sounds like lesson learned. Not a big deal in the scheme of things. Now get back out and enjoy your truck.
  3. Apr 19, 2018 at 2:54 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    You forgot the system check after about 5 hours of truck being parked and you hear a pump running.
  4. Apr 19, 2018 at 2:58 PM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
  5. Apr 19, 2018 at 2:58 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    The ticking of the engine ! (cleaning of injectors)
    daddy_o[QUOTED], Joe23 and shakerhood like this.
  6. Apr 19, 2018 at 3:01 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Taco Lean
    daddy_o, 2016Tacoman and Joe23 like this.
  7. Apr 19, 2018 at 3:26 PM
    Joe23
    whistling at 45mph is LCA
    howling diff at 60mph while feathering throttle
    erratic shifting fixed by TSB and/or fluid check
    2016Tacoman likes this.
  8. Apr 19, 2018 at 3:35 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Please don’t start with the you can’t use 4 wheel drive on dry paventment. People do it all the time, just don’t do tight turns with it like an idiot and you’ll be fine
    daddy_o likes this.
