Check Charging System
Discussion in '3rd Gen. Tacomas (2016-2023)' started by C-Rok275, Jul 3, 2019.
  1. Jul 3, 2019 at 1:06 PM
    C-Rok275
    C-Rok275 [OP] Well-Known Member
    2017 TRD Pro
    6112/5160s with Icon stage 2 leaf’s.
    I searched, no answer.
    The maintenance reminder came on, ~38,000 miles. I thought it was for routine maintenance but it shows “check charging system.”
    Is that a dealer only check? Probable battery?
    Thanks!
    I think I must just be a dumb ass and solved my own problem
  2. Dec 28, 2019 at 4:45 PM
    wallygatoresq
    wallygatoresq Well-Known Member
    travis
    Central Washington
    2018 Tacoma TRD Sport
    @C-Rok275 how did you solve this?
    I got this reminder today, it is about due for an oil change at 12.9K and the battery is less than a year old because I changed it out when I put in a dual battery system.
    Has anyone else seen this?
  3. Dec 28, 2019 at 8:22 PM
    Doobfucious
    Doobfucious I get it. It ain't makin' me laugh but I get it.
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    Stock AF. My 68 Bronco and 2000 2.5RS get the mods.
    Maintenance reminder it says.
    I have the option to set up the reminders in mine and it's 99% the same layout as that, visually. I suspect it's a preset maintenance... reminder; not a warning or fault.
    shakerhood likes this.
  4. Dec 28, 2019 at 8:38 PM
    wallygatoresq
    travis
    Central Washington
    Thanks for that, I suspect you are right with the timing for the oil change but thought it was strange that it said battery. I will see if I can dig in to the menu and find out the frequency it it set at.
    Doobfucious[QUOTED] likes this.
  5. Dec 28, 2019 at 8:52 PM
    Doobfucious
    Doobie
    WNC -> Midwest
    2020 TRDOR DCSB 6MT
    It was a few layers deep in the options. Vehicle options then there was lighting, maintenance and something else. I couldn't believe how many things I could set reminders for!
  6. Dec 29, 2019 at 6:28 AM
    C-Rok275
    2017 TRD Pro
    I don’t remember what mine was specifically, only that it wasn’t a problem and did not require any fixing.
  7. Dec 29, 2019 at 7:45 AM
    wallygatoresq
    travis
    Central Washington
    I haven’t dug that deep in the options,
    Thanks, seeing feedback I am pretty sure it is just a set maintenance thing. I will ask the dealer why it pops up with battery when I take it in.
    Doobfucious likes this.
