"Check charging system"
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xndak, Mar 16, 2023.
  1. Mar 16, 2023 at 8:19 AM
    xndak
    xndak [OP] Well-Known Member
    2023 Off Road
    2018 offroad 51k miles original battery. Last couple of days on startup its been just a little slow compared to normal to fire up. This morning take it out of warm garage go on a hike in 24 degree weather and when i go to start it starts, but barely (no power) and the "Check charging system" light comes on. I turn it off, hit the button again and it starts and runs normally (no warning lights). To me this says go get battery tested, probably replaced and avoid bringing it in. Any other thoughts?
  2. Mar 16, 2023 at 8:24 AM
    mushroom_man7
    mushroom_man7 Well-Known Member
    check your battery might be time to replace
    xndak[QUOTED][OP] and Stevie17 like this.
  3. Mar 16, 2023 at 8:24 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Yup, new battery!
    xndak[OP] and Stevie17 like this.
  4. Mar 16, 2023 at 8:57 AM
    Tacoma Rant
    Tacoma Rant I can’t be good all the time.
    Wisconsin
    2023 Tacoma TRD Sport Electric lime
    My rule about batteries is I change them every five years no matter what. Since I’ve been doing that for the last 20 years, I’ve never had a battery issue.
  5. Mar 16, 2023 at 8:58 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Elk Grove, Ca
    Yup, time for a new battery.
    xndak[OP], Stevie17 and wilcam47 like this.
  6. Mar 16, 2023 at 9:13 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Battery is suspect, but at that age, should be replaced anyways.
    xndak[OP] likes this.
  7. Mar 16, 2023 at 10:16 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    I, for one, think the battery should be replaced
  8. Mar 16, 2023 at 1:22 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Your description of the behavior is confusing to me. If you saw the “Check charging system” message while the engine was running, then the truck thought the alternator was not producing the correct voltage.
    On the other hand, if you saw the message when the ignition was on and the engine was NOT running, then that is perfectly normal and nothing to worry about.
    The battery produces about 12v and the alternator about 14v. It’s the alternator’s job to charge your battery and run the rest of your electrical an accessories when the engine is running. The battery’s primary purpose is to feed the starter motor, but it is also used to feed accessories while the engine is off.
    What do you mean by “little slow compared to normal to fire up”? Do you mean the starter struggled to crank the engine or do you mean the starter had to crank the engine longer than normal before the engine started?
    Brucey, xndak[OP] and Chew like this.
  9. Mar 16, 2023 at 1:23 PM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Test and probably replace battery. Then with known good battery, verify correct charging
  10. Mar 16, 2023 at 1:26 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    good points/questions.
    also, in some folk's mind; low mileage equates to a lack of wear. BUT, in terms of battery life,,,,, not so much, often the opposite. It means the battery has had to sit without charge for long periods of time, and/or been used in short trips, where the initial start demand is greater than time driven (to recharge).
  11. Mar 16, 2023 at 1:45 PM
    xndak
    2023 Off Road
    Slow meaning it just did not fire as quickly as normal - very slight difference but my ear caught it and initially i thought maybe the/a injector was fouled, etc. The check engine light came on when initially started/running but very poorly and 0 power, matter of fact it died when i gave it a bit of fuel. Im pretty sure it is the battery (replaced this morning) as where I live in Idaho the summer heat cooks them in 4-6 years. Thanks for everyone s input.....
  12. Mar 16, 2023 at 1:47 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  13. Mar 16, 2023 at 1:52 PM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    Some of us, myself included, subscribe to the philosophy of, "If it ain't broke, don't mess with it"; two cars back I had a "100-Month" Honda battery last two months shy of 10-years (yes, 118 months). :)
  14. Mar 16, 2023 at 2:17 PM
    gudujarlson
    Minnesota
    That does not sound like the battery. If the starter turns the engine over at normal speed, the battery is fine. It sounds like you got the check charging system message because the engine rpm was not high enough for the alternator to produce the normal voltage.
    I suspect you have a minor fuel or ignition system issue. I’d probably live with it unless it continued to be an annoying enough to take it to a mechanic. If you still have a warranty, it’s a no brainer to take it back to the dealer.
    xndak[QUOTED][OP] likes this.
  15. Mar 16, 2023 at 2:19 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    If you are hearing the crank difference, time to replace it. I have an 18 as well and replaced mine last spring with an AGM. Better battery all around and will not leave you stranded with a dead cell failure.
  16. Mar 16, 2023 at 2:23 PM
    gudujarlson
    Minnesota
    I interpreted his answer as saying the starter cranked the engine at normal rpm, but it had to crank it longer before it started and then it ran rough. That is not evidence of an issue with the battery.
  17. Mar 16, 2023 at 2:25 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    It sure will cause those symptoms - if the battery voltage drops low enough and does not recover quickly. Low voltage can cause all sorts of issues.
  18. Mar 16, 2023 at 2:28 PM
    gudujarlson
    Minnesota
    An engine will run just fine without a battery. Been there done that. The alternator is what provides electrical power to a running engine. The battery is just there to get the engine started, because the alternator can only provide power when rotating at a decent rpm.
  19. Mar 16, 2023 at 2:29 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    lol, sure it will. Go ahead and try that with your 2020. I'll wait.
  20. Mar 16, 2023 at 2:33 PM
    gudujarlson
    Minnesota
    Huh? Charging and starting systems haven’t changed significantly my lifetime. It’s very stable technology. Do you think my 2020 doesn’t have a battery, an alternator, and a starter?
  21. Mar 16, 2023 at 2:53 PM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
