"Check charging system"
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xndak, Mar 16, 2023.
  1. Mar 16, 2023 at 3:03 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    You don’t need a fancy tool to diagnose whether the battery is the root cause of a starting issue. If the battery has enough juice to rotate the engine fast enough that it creates self sustaining ignition, it’s not the problem. The battery might not be at 100%, but it’s not the root cause for why the engine does not continue to run.
    I recommend you guys to watch the YouTube channel Vice Grip Garage where he demonstrates basic and advanced troubleshooting processes. Yes he is usually dealing with very old cars with carburetors, but batteries, alternators, fuel, and spark have not really changed since then. And he’s funny.
  2. Mar 16, 2023 at 3:11 PM
    HighIronHooligan
    HighIronHooligan TW Misfit
    Paul
    Tucson, AZ
    2022 MGM OR DCSB MT
    Tocamo likes this.
  3. Mar 16, 2023 at 3:34 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I just got through winter # 5 on my OEM battery. All good. I'll replace it when it dies... yes, I live for danger!
    I do however carry a booster pack with me.
  4. Mar 16, 2023 at 3:41 PM
    Bishop84
    Bishop84 Well-Known Member
    For reference, this code is usually a cluster, not an alternator or battery (as they would have symptoms)
    Continue bickering fellas.
    gudujarlson likes this.
  5. Mar 16, 2023 at 4:53 PM
    xndak
    xndak [OP] Well-Known Member
    2023 Off Road
    Whats a cluster?
  6. Mar 16, 2023 at 4:54 PM
    Bishop84
    speedometer, combination meter
  7. Mar 16, 2023 at 5:00 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    You don't think a computer controlling all of those isn't a huge change? A carb doesn't care about voltage but a computer does.
    And I think dude tries to hard to have a stupid name for each part instead of just calling it by its name. :anonymous:
  8. Mar 16, 2023 at 5:04 PM
    mbigpops
    mbigpops Well-Known Member
    2017 TRD Sport
    A battery tester will check the entire charging system. Since your battery is old anyway have it tested and if the cold cranking amps are low replace and try the truck again to see if it clears the problem.
    I have in the past had an alternator go and it had all the symptoms of a bad battery.
    The rule to troubleshooting on your own without a mechanic is eliminate one possibility at a time.
    xndak[OP] likes this.
  9. Mar 16, 2023 at 5:16 PM
    gudujarlson
    Minnesota
    Huh? The alternator puts out about 14v without the aid of a battery. The battery puts out about 12v. A battery is an energy storage device whose primary purpose is to run the starter motor. The alternator on the other hand supplies power to the engine and charges the battery when the truck is running.
