Check charging system?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2023tacomer, Jul 29, 2023.
  1. Jul 29, 2023 at 3:38 PM
    2023tacomer
    2023tacomer [OP] Well-Known Member
    So while getting gas for the first time, key turned two clicks cause I'm trying to figure out how to reset the gas mileage, and I get a check charging system. Normal? Engine off, key on too mess with settings. Please say yes.
  2. Jul 29, 2023 at 3:40 PM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Gas mileage will update on its own. Message is normal in aux mode.
    Kolache007 likes this.
  3. Jul 29, 2023 at 3:41 PM
    2023tacomer
    I wanted to reset the avg mpg for the next tank. No toyota has ever done this on their own, confused
  4. Jul 29, 2023 at 3:46 PM
    LivinOnEdge
    Land of The Lost
    Ah, not the mileage left reset. Forgot how to do that too. Mines a push button and we get the same message.
  5. Jul 29, 2023 at 3:50 PM
    Azrael's Gaze
    Azrael's Gaze Well-Known Member
    Steve-O
    Springfield, Oregon
    2022 Black Tacoma TRD Offroad
    Check charging happens cause nothing is charging the battery when you turn it on with the engine off. Mpg resets automatically when you fill
  6. Jul 29, 2023 at 4:06 PM
    tcjacado
    tcjacado Well-Known Member
    That setting is in/the head unit. Get to main menu, touch" eco "
    And I belive there is a setting in heads up display/info center between speedometer and tach. Just scroll through the steering wheel controls to do that.
    musicisevil and TnShooter like this.
  7. Jul 29, 2023 at 6:15 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Pop quiz, what needs to be turning for the charging system to generate any power?
  8. Jul 29, 2023 at 6:17 PM
    Phenom3030
    Phenom3030 Well-Known Member
    Jon
    Colorado Springs, CO
    2021 Lunar Rock TRD Pro
    OEM+
    The flux capacitor
    WinterFalco likes this.
  9. Jul 29, 2023 at 6:18 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    The oil pump, at least for any long term charging.
  10. Jul 29, 2023 at 6:22 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Technically, the rotor is all that needs to spin.
    But now we’re getting way off track.
    You’re all good OP.
    Nothing to worry about.
  11. Jul 29, 2023 at 6:31 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    The MPG should reset as soon as you put it into drive.
    Yes the charge system message is normal. In most other vehicles you'd just see a battery light so yes, in a way, every vehicle does this under this same circumstance.
    RustyGreen, shakerhood and ktbell444 like this.
