Check dipstick when truck is hot or cold?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaislife, Dec 17, 2019.
  1. Dec 17, 2019 at 10:10 AM
    Tacomaislife
    Tacomaislife [OP] Well-Known Member
    Texas
    2002 tacoma trd
    Should I check my oil dipstick level when my truck oil is hot or cold it's a 2004 tacoma v6 dc been looking online but can't find anything about it
    GQ7227 likes this.
  2. Dec 17, 2019 at 10:18 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    cold is fine. or warmed up with engine turned off.
  3. Dec 17, 2019 at 10:20 AM
    jtaco11
    jtaco11 Well-Known Member
    Either or
  4. Dec 17, 2019 at 10:25 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    You’re dip stick has a wide acceptable zone. I generally do it cold when I do the oil change and sometime later after running the vehicle around.
  5. Dec 17, 2019 at 10:48 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i do believe the level on the dipstick will be at its highest level when it is cold?
    check in morning before start up or other way if you are graveyard inclined
    That one old guy likes this.
  6. Dec 17, 2019 at 12:05 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Does not matter.
    In the good old days of crap domestics that burn more oil than gas, I'd check the oil at every fill up (or every other), which means when it's hot.
    Or do it when it's cold so you don't burn your hand, lol.
    TacomaJunkie8691 likes this.
  7. Dec 19, 2019 at 5:42 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    Well I did my oil change and upon checking my oil dip stick and it was at the full line so I drove around now it's reading half a quart more the oil i used was 5w30 mobile one
  8. Dec 19, 2019 at 5:43 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    I did the oil change was at the full line now that I drove around I checked it again and it's reads half a quart more
  9. Dec 19, 2019 at 5:46 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    did you change the oil filter too?
    how much oil did you put in?
  10. Dec 19, 2019 at 5:47 PM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Check it in the morning, before start up as @GQ7227 suggested. That's as accurate as it gets.
    Edit- Half a quart I probably wouldn't be too concerned about, any more than that, I dump some.
  11. Dec 19, 2019 at 5:51 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    Yeah I even prefilled it or at least tried to half of it dropped when I screwed it on lol
    GQ7227[QUOTED] likes this.
  12. Dec 19, 2019 at 5:52 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    I well check in the moring
  13. Dec 20, 2019 at 10:02 AM
    Tacomaislife
    Texas
    2002 tacoma trd
    It's was on the full line so I guess it goes down after it cools down weird
    GQ7227 likes this.
  14. Dec 20, 2019 at 10:06 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i think it has to do with gravity!
    Wyoming09 and That one old guy like this.
  15. Dec 20, 2019 at 10:08 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    were you on a level surface? If I check my oil when my truck is tilted one way or the other, even slightly, it throws off the reading.
    Clearwater Bill likes this.
  16. Dec 20, 2019 at 5:24 PM
    Indy
    Indy Master of all I survey.
    Cold is fine. If you've been driving let it sit for a few minutes to let the oil drain to the pan. If you've been driving there will be residue in the tube that might show a higher than true reading. So fine it a couple minutes.
  17. Dec 21, 2019 at 1:58 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I check in the morning then look for big poodles under the truck just in case
  18. Dec 21, 2019 at 2:31 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    :D:rofl:
    That one old guy and Hook78 like this.
  19. Dec 21, 2019 at 3:55 AM
    02hilux
    Planet: EARTH
    Oh yea, that oil leak is big and dark. Definitely need an oil change. LOL
  20. Dec 21, 2019 at 4:09 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Big poodles just like that only not clipped as fine.
    I was about 9 years old Had a standard Poodle I found running wild he adopted me.
    I loved that Dog Mom sort of run him over it was not a good time .
    cruiserguy[QUOTED] likes this.
