Check emguine light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beckleyota, Mar 17, 2012.
  1. Mar 17, 2012 at 6:38 AM
    beckleyota
    beckleyota [OP] Well-Known Member
    wv
    o7 taco
    vent visors,tint,kenwood headunit, trex eyelids,kenwood componants,5100's,1 aal,cabellas seatcovers,painted stereo suround
    So I put plugs in my 4cyl taco yesterday rode around for about 20 miles that night and then my check engine light came on. Everything went smooth plugs came in and out fine i put ngk iridiums back in it and took denso iridums out of it. Is there sumthing I need to check first? And info would b very helpfully
  2. Mar 17, 2012 at 6:50 AM
    beckleyota
    wv
    o7 taco
    Bump fer advice wers Chris at
  3. Mar 17, 2012 at 6:59 AM
    beckleyota
    wv
    o7 taco
    Just checked everything is pluged back up vaccume lines n all I didn't pull the plugs back out to check gap because I've Ben told there no good after I flatten the crush washer on then.
  4. Mar 17, 2012 at 7:06 AM
    jbrenn
    jbrenn Well-Known Member
    allen texas
    10 sr5
    take it to autoparts store to read the code. You can remove and reinstall the plugs it wont hurt anything.
  5. Mar 17, 2012 at 7:08 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Have you pulled the plugs out just to take a look? They may have seemed to go in smoothly, but possibly could have sustained some damage?
  6. Mar 17, 2012 at 7:29 AM
    beckleyota
    wv
    o7 taco
    Just went to autozone the code was secondary airpump checkvalve stuck. Wtf is that
  7. Mar 17, 2012 at 9:02 AM
    dfxdig
    dfxdig Well-Known Member
    myrtle beach, sc
    06 trd offroad sr5
    k&n intake, custom bed rack
    your light came on because you don't know how to spell correctly. use spell check and peeps won't think you're an idiot.
  8. Mar 17, 2012 at 9:08 AM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    That's what I was thinking. Great way to help.
  9. Mar 17, 2012 at 9:09 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Very helpfull, thanks for your answer. :rolleyes:
  10. Mar 17, 2012 at 9:12 AM
    dfxdig
    myrtle beach, sc
    06 trd offroad sr5
    is that the same thing as this strange tasting water called budwieser?
    it's hard to take someone seriously when they can't even spell engine correctly.
  11. Mar 17, 2012 at 9:25 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Considering that the m is next to the n and the u next to the I, I would thinks its a typo.
  12. Mar 17, 2012 at 9:38 AM
    dfxdig
    myrtle beach, sc
    06 trd offroad sr5
    thank you, that info would b very helpfully.
  13. Mar 17, 2012 at 9:51 AM
    beckleyota
    wv
    o7 taco
    Back to topic..... I took it to work put it on the computer n cleared the code. Turns out i had to clean a sensor n she is good a new
  14. Mar 17, 2012 at 9:51 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Kind of harsh don't you think? He was probably a little flustered because he did his own maintenance and now the truck is acting up, hence he was typing frantically not concerned with spell check.
  15. Mar 17, 2012 at 9:52 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Good to hear!
  16. Mar 17, 2012 at 9:58 AM
    beckleyota
    wv
    o7 taco
    exactly
  17. Mar 17, 2012 at 10:19 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    I know the feeling, been there before, nothing like Krazie, but I've been there.
  18. Mar 18, 2012 at 10:37 AM
    dfxdig
    myrtle beach, sc
    06 trd offroad sr5
    maybe so, but misspelling and poor sentance structure makes it harder for someone to give advice.
    in other words, we be not likin plugs fur abot 4cyl my miles 130444 when changed.
    not being an ass, just saying, if you have a problem, think about it and post a comprehensive question.
  19. Mar 18, 2012 at 10:42 AM
    dfxdig
    myrtle beach, sc
    06 trd offroad sr5
    my point exactly, thank you.
  20. Mar 18, 2012 at 10:43 AM
    NelsonTacoma
    Tucson, AZ
    I think he's trying to parody the op.
