Check engin light coming on and then off???
Discussion in 'Technical Chat' started by SBmudhog, Nov 20, 2010.
  1. Nov 20, 2010 at 12:46 PM
    SBmudhog
    SBmudhog [OP] Member
    Huntland, TN
    07 SR5 Sport
    General Grabber AT2
    I have a 2007 SR5 Sport with the 4.0l and 6 speed manual. A few weeks ago on my way home the check engine light came on. It was late on a Friday night and I was a mile from my house. The next morning I started it up and the light was not on. I drove around for about 2 hours and it came on again!! I went to Advance Auto Part, dealership was closed, they hooked up a code read. It said it was the left bank timing retardation. On the next monday I drove back to State College, PA, about 2 hours, and the light has not came on since!!
    Sorry for the long post, but is this something I should be worried about?? the truck runs fine and it is up to date with the required services and oil changes. If anyone has any info on this please let me know!
    Thanks!!
  2. Nov 20, 2010 at 12:48 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    Retardation?
  3. Nov 20, 2010 at 12:54 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    The actual failure code number like "P0xxx" would be a lot more helpful in giving you info on what to do. Timing retardation is something your engine does based on readings from different sensors. So maybe a sensor or cam phaser is going out. Until we know the actual code number it's like shooting in the dark.
  4. Nov 20, 2010 at 2:08 PM
    Mod
    Mod Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Or the left bank is going lean, (sensor reads that), and it pulls back the timing. injector cleaner ran thru anytime recently?.
  5. Nov 21, 2010 at 12:31 PM
    SBmudhog
    Huntland, TN
    07 SR5 Sport
    General Grabber AT2
    I did not get the code itself. I have not ran any injector cleaner through it but that is a good idea! But like I said it has not came back on since. I drive 2 hours from State College, PA to home every weekend. I am going to get some injector cleaner, ant tips on which works best for the 4.0L????
    thanks!!
  6. Nov 21, 2010 at 12:40 PM
    NelsonTacoma
    Tucson, AZ
    I usually use the Lucas injector cleaner. It's very thick and you just add it to your gas tank. Used it on many different types of cars/trucks with no issues.
  7. Nov 21, 2010 at 2:20 PM
    Mod
    CR, WA
    stock
    Thats the stuff I use also.
  8. Nov 21, 2010 at 2:47 PM
    The Munster
    The Munster I like turtles!!!
    Lance
    Moody AFB, GA
    hope this might help, straight from toyota's TIS network
  9. Nov 21, 2010 at 2:49 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    do you have that website address, I believe it could be quite useful
  10. Nov 21, 2010 at 2:59 PM
    The Munster
    Lance
    Moody AFB, GA
    unfortunately it doesn't work like that, i work at a dealership....its one of the benefits :cool:
  11. Nov 21, 2010 at 4:53 PM
    SBmudhog
    Huntland, TN
    07 SR5 Sport
    General Grabber AT2
    Thanks for the info!!!
  12. Nov 21, 2010 at 4:57 PM
    NelsonTacoma
    Tucson, AZ
    Yikes!! from reading the possible causes this could be trouble. Hopefully is just the oil control valve/filter & not the timing gear, ecm or valve timing etc. Might have to take it to a shop for repairs like that. Unless your skilled in this type of work.
  13. Nov 21, 2010 at 5:02 PM
    tacos
    tacos Well-Known Member
    Andrew
    NKY
    05 A/C Off Road 4x4
    BHLM,5100's set 2.5,Toytec 2" aal,FJ TRD wheels,AFE pro-dry, Duratracs
    It could have been an oil control valve sticking. I see it occasionally on other cars and they can free themselves up with no issue. If the light comes back on most good scan tools can run an active test on the oil control valves to make sure they are no longer sticking. If it's off though I wouldn't worry about it.
