Check Engine and Auto Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08TacoTrD, Mar 20, 2011.
  1. Mar 20, 2011 at 9:32 AM
    08TacoTrD
    08TacoTrD [OP] Well-Known Member
    08 TRD Offroad
    Last night my check engine light came on and this morning I went out on the highway and I noticed that the tranny didn't shift all the way up to the top gear, 5th. I pulled over to the side and started out again and same thing, no top gear.:confused: Crappy thing is I can't get to a dealer until Tues because I have to use my truck to pick up a used boat I just bought today. No problems with it until to today, 38500 miles on it.
  2. Mar 20, 2011 at 9:50 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    get the code checked and report back, I personally would find another way to pick up that boat.
  3. Mar 20, 2011 at 9:57 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    X2
  4. Mar 23, 2011 at 2:33 PM
    08TacoTrD
    08 TRD Offroad
    Against popular advice I towed the boat and then took the truck in and right now the tech thinks it's either a sensor or a chewed up wire harness. I am leaning towards the chewed wires since I did see a chipmunk sitting on the top of my tire a little more than a week ago which I had forgot about until I talked to the service manager and he brought it up. Time to buy some pellets for some target practice. The chipmunks must pay.
  5. Mar 23, 2011 at 2:36 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Sorry to hear that OP. Let us know what the outcome is.
  6. Mar 24, 2011 at 3:52 PM
    08TacoTrD
    08 TRD Offroad
    Service manager called me today and the tech found the eaten harness. It's not in an easy spot to get too which means big $$$$ for labor to replace a $100 part. My insurance is sending an adjuster to look at it so hopefully it gets approved. Man I wish it had been a bad transmission, that would have been warranty work.
  7. Mar 24, 2011 at 5:32 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You know what you have to do ...
  8. Mar 24, 2011 at 6:03 PM
    08TacoTrD
    08 TRD Offroad
    I told my co-workers that if they hear PETA complaining about lifeless chipmunks they know who to blame.
  9. Mar 26, 2011 at 7:37 PM
    08TacoTrD
    08 TRD Offroad
    Anyone have experience with this type of thing? Did the vehicle start throwing weird errors later on due to unseen damage or faulty dealer work? I'm almost thinking about trading it for another truck a year newer.
  10. Mar 26, 2011 at 8:11 PM
    BlueT
    NorthEast
    If they replaced the harness you won't get anymore problems unless those little fookers chew on something else. Trading may work but how you know you wo't get a car that those little fookers like even more then Toyota.
    Get BB gun and have your revenge. Its only way you can protect that truck. Best time is early morning. If you ever in NE and you see a guy in underpants with Remington, coffee mug next to him and Cig in his mouth yelling "Eat lead little biatches" dont be frighten.:D
  11. Mar 29, 2011 at 2:50 PM
    08TacoTrD
    08 TRD Offroad
    The final diagnosis and fix is rodent chewed through the knock sensor harness and the computer was showing a P0333 code - high input for knock sensor. Tech replaced the harness and it it shifts fine now. They also performed the accelerator pedal recall and reflashed the transmission. I figured they would and didn't really mind when I saw it on the bill. The pedal looks fine.
  12. Mar 29, 2011 at 3:09 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Thanks for the report back
