Check engine and trac control light issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lohan808, Mar 22, 2023.
  1. Mar 22, 2023 at 12:21 PM
    Lohan808
    Lohan808 [OP] Member
    2015 Tacoma 4x4 base
    Bull bar
    Hey tacomaniacs,
    Recently had the combo trac control and check engine light issue. Turns out it was the evap solenoid unit. Not bad for 98k. Easy peazy, had a local shop do the work. Fast forward 6months. Now when I get down to a 1/3 of a tank, the pair of lights comes on. Run her down to E and refill. Drive 50or so clicks and low and behold the lights go out. Fishing for wisdom...
  2. Mar 22, 2023 at 12:33 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    I would recommend checking what the fault code(s) are to start.
    SR-71A, Dm93 and Geeves77 like this.
  3. Mar 22, 2023 at 12:36 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Codes. Codes. Codes. Plz
    Dm93 and TnShooter like this.
  4. Mar 22, 2023 at 12:36 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Sounds like the solenoid again... was it an OEM part, or after-market?
  5. Mar 22, 2023 at 12:51 PM
    Lohan808
    Bull bar
    Well honestly it was a non factory warranty repair. Bought it used. Sounds like an aftermarket FAIL. I didn't get the codes but will check on the ticket and see if they listed them. Get back to you Joeyv141 and Geeves77
  6. Mar 22, 2023 at 1:07 PM
    Clearwater Bill
    Billy
    Largo Florida
    The most common reasons for those lights is a loose or bad gas cap.
    Often making sure the cap is seated properly (or replacing if needed) and clearing the codes will do the trick.
    Not saying that's your issue. Just something to keep in mind.
    LeakyAC and Squirt like this.
  7. Mar 22, 2023 at 1:13 PM
    Lohan808
    Bull bar
    Thanks Bill i did just replace the gas cap. It was looking rough.
  8. Mar 22, 2023 at 1:34 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Pull the codes.
    We will be able to help you more if when know what we are dealing with.
    Dm93 likes this.
  9. Mar 23, 2023 at 5:03 AM
    Lohan808
    Bull bar
    Ok codes pulled. P0441 and P0446.
  10. Mar 23, 2023 at 6:00 AM
    joeyv141
    New Jersey
    Yeah I would go back to whatever shop replaced the evap solenoid and they should look at it, possibly under warranty depending on what they find.
    Lohan808[OP] likes this.
  11. Mar 23, 2023 at 9:01 AM
    Lohan808
    Bull bar
    Those guys sucked and had my truck for a week. I would rather do it myself. I have a better mechanic who is a personal friend. Couple of cold ones and a little guidance is all I should need.
  12. Mar 23, 2023 at 10:11 AM
    joeyv141
    New Jersey
    If the old invoice has the fault codes from then it would be nice to know if the same exact codes have returned or if something new is also present, also on the invoice see if they replaced only the solenoid or the whole charcoal canister. I just dealt with a 2012 4Runner and the vac pump, vent solenoid, pressure sensor were all part of the charcoal canister. Can your or your friends scan tool command on/off the separate EVAP solenoids? if so you can test them and see which dont work then tap on them while commanding on to see if they will knock loose, also check the wiring for damage. Some of the members here have access to the wiring diagrams and they can hopefully post the related ones but the more info you can supply the better.
  13. Mar 23, 2023 at 10:38 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I'm assuming you mean P0441 and P0456 as there is no 446 code on 2nd gens
    Those 2 codes together usually means there is a leak in the system or there is a problem with the leak detection pump being able to pull a vacuum on the system.
    A good video explaining how the system works.
    https://www.youtube.com/watch?v=xubgil8NeYI
  14. Mar 23, 2023 at 11:29 AM
    Lohan808
    Bull bar
    Yep that would be muh fat fingers.
  15. Mar 24, 2023 at 4:33 AM
    Lohan808
    Bull bar
    So in conclusion I powered each device and found that the solenoid was stuck in The shut position. Will stick to factory parts or Denso parts when I can get them. Thanks for the help and community.
    TnShooter, zguy1 and Dm93 like this.
