Check Engine and Trac Off
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lconhare, Dec 11, 2019.
  1. Dec 11, 2019 at 7:46 PM
    lconhare
    lconhare [OP] New Member
    Lisa
    16 Tacoma TRD Sport DblCab 6'
    Low Pro Bugflector, Tint, Mudguards,Blk Matte Window Visors
    Truck just hit 50k miles and trac off and check engine came on... Went to dealer and wanted to charge me $149. to pull codes... left went and borrowed my brothers scanner and codes are
    P0174, P1170, C0700 along w intermittent trac off
    I didn’t clear codes but disconnected battery(after checking gas cap) reconnected battery and codes gone
    Drove approx 5 miles and check engine back on along w Trac off.
    Drive Train Warranty 60k miles
    Any suggestions? I have taken excellent care of this truck.. first new vehicle in 30 yrs.. still all stock w aftermarket accessories only
    Had to have my stereo replaced 3 weeks ago apparently the “computer went bad”.. $1300. Part $149. Labor
    It’s a 2016 Tacoma Crew TRD Pro 6’ Inferno and I Love it but.... Slightly frustrated
  2. Dec 11, 2019 at 7:53 PM
    Bishop84
    Bishop84 Well-Known Member
    Typically P0174 is a air fuel ratio sensor. You'll need to read freeze frame data and compare bank to bank to understand the code.
  3. Dec 11, 2019 at 8:00 PM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    Is your air filter clean and your maf? Start with the simple stuff first
    Solid Seung likes this.
  4. Dec 11, 2019 at 9:38 PM
    rmac010
    rmac010 Well-Known Member
    2017 DCSB TRD Sport
    What scanner will provide / record that type of data?
  5. Dec 12, 2019 at 12:07 AM
    TRD Novice
    TRD Novice Member
    8oh8 State
    2017 TRD Offroad
    Same here. My CEL and Trac Off are lighted up, except it happened when I replaced my OEM gas cap with a Duralast locking one.
    lconhare[OP] likes this.
  6. Dec 12, 2019 at 1:13 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Get it fixed under warranty.
    lconhare[OP] and Chew like this.
  7. Dec 12, 2019 at 4:32 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    This, take it to another dealer (if you have one that is) that is more cooperative.
  8. Dec 12, 2019 at 6:45 AM
    CODSWALLOP
    CODSWALLOP Well-Known Member
    2019 Tacoma TRD ORSB
    skewp hood, running boards
    TECH SAID AT WORK IT WOULD HELP TO HAVE THE PROPER 6 DIGIT CODES AND NOT THE 4 DIGIT. HE SAID THE P0174 IS SYSTEM TO LEAN AND P1170 WAS POINTING TOWARDS A INJECTOR ISSUE AND C0700 HE COULDNT FIND. HE SAID IT WOULD NEED TO BE DIAGNOSED WITH 6 DIGIT CODES ETC. HE DIDNT THINK IT WOULD BE SOMETHING SIMPLE.
  9. Dec 12, 2019 at 6:50 AM
    GPC
    GPC Well-Known Member
    LFOD
    2015 Tacoma TRD Pro
    It's under warranty tell the dealer to fix it or you will call corporate.
    GreyBaldTaco likes this.
  10. Dec 12, 2019 at 6:32 PM
    lconhare
    Lisa
    Thanks for all the info. I am taking it back to dealer tomorrow My fuel mileage dropped to 13 mpg have not replaced gas cap, disconnected battery and all codes came back
    Will update after I take it in
    Thanks everyone!
  11. Dec 13, 2019 at 4:08 AM
    cop414
    cop414 Well-Known Member
    Tim
    Central PA
    2022 Blue Crush DCSB Sport
    Subscribed, good luck today.
  12. Dec 13, 2019 at 4:17 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Hate em when they break down , good luck .
  13. Jan 2, 2020 at 3:24 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    What did they say?
  14. Jan 21, 2020 at 10:23 AM
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    Having the same issue myself, my '17 has 46k and this just occurred. I fill up at the same gas station as always and never had an issue, I'm mostly sure I tightened the gas cap the first time...I filled up again after this and made sure that time...still on. trac comes back on above 31mph though...but the damn cruise won't work grrrrr. Haven't had time to go to the dealer or pull codes yet.
  15. Jan 21, 2020 at 12:32 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    OP vents, then disappeared
    robssol likes this.
  16. Jan 21, 2020 at 12:48 PM
    Bcjammerx
    North East Texas
    well mine apparently was gas cap, made sure it was tight and d/c’d the neg term. gone and hasn’t come back ¯\_(ツ)_/¯ I feel like an idiot XD
  17. Jan 21, 2020 at 12:53 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    It's amazing what a gas cap can do these days. Then you have the new Hondas they don't even come with a gas cap. Capless system.
    Mikeincal and StayinStock like this.
  18. Jan 21, 2020 at 2:44 PM
    Solid Seung
    Solid Seung GWOT Infidel
    New California Republic
    2013 SC V6 DCSB TRD OR 4x4
    TRD Supercharger aFe Stage-2 Si Pro DRY S CAI JBA Cat4ward Shorty Headers TRD Performance Exhaust PLX Wideband Air/Fuel Sensor Module Speedhut Boost & Wideband Air/Fuel Ratio Gauges CravenSpeed Flexpod ScanGauge SGIIFFP Computer Uni Filter Mod Mobil 1 Synthetic Oil Pelfreybilt Off-Road: Aluminum Front Plate Bumper, Rigid DOT/SAE Fog Lights, Pelfreybilt Hawse Fairlead & Flipster Winch License Plate Bracket, Aluminum IFS Skid Plate, Steel Standard Rear Bumper, Smittybilt 3/4" Black D-Rings w/Daystar Isolators & Washers KB Voodoo Tailgate Cap System King Shocks 2.5 Front Remote Reservoir Coilovers SPC Light Racing UCAs King Shocks 2.5 Rear Remote Reservoir Shocks OME Dakar EL095R Leaf Spring Set Wheelers Off-Road Front SuperBumps, Rear U-Bolt Flip Kit with SuperBumps Crown Performance Red SS Brake Line Kit Body Mount Chop Tandem Off-road 612 Bravo 17x8.5” Wheels BFG T/A KO2 285/70R17 Tires Redline Tuning QuickLIFT ELITE Hood Struts Redline Tuning Tailgate EZDOWN TRD Battery Hold Down Duralast Platinum Battery 24F-AGM OEM Black Grille Bezel TRD Pro TOYOTA Grille TRD Pro Black Headlights Sylvania Silverstar zXe H4 Lamps Rain-X Silicone AdvantEdge Wiper Blades OEM Running Boards OEM Tacoma Bed Mat AJT Design Climate Control Knobs WeatherTech Floor Liners Covercraft Carhartt Precision Fit Custom Seat Covers Emergency Assistance Kit First Aid Kit Salex Organizers Center Console & Glovebox OCD Anker 36W Dual USB Car Charger PowerDrive+ 2 Type S Drive Dash Camera Garmin nüvi 255W 4.3" GPS Navigator Steadfast Auto 8" Antenna Pioneer AVH-X3500BHS 2-DIN Multimedia DVD Receiver 6.1" WVGA iPod nano 8G (6th Gen) JL Audio XD700 Watt/5 Channel Amplifier JL Audio C2-650X & C2-650 6.5" speakers JL Audio 10W1v2-4 10" subwoofers (x2) in a JL Audio Stealthbox
    This was exactly my issue. Around 50K miles my TRAC OFF would not turn on, so I pulled the codes and reset my battery also. Rechecked the gas cap too. TRAC OFF was cleared but came back on. Checked my cone air filter and it was very dusty.
    Cleaned the cone air filter, the box it sits in, took the CAI tube off and cleaned the inside, cleaned the throttle body and the MAF sensor. I used a MAF sensor cleaner spray and clean rags.
    This fixed problem and I haven’t had any more issues. Hope this helps.
    robssol and IEsurfer[QUOTED] like this.
  19. Jan 22, 2020 at 7:13 PM
    jacobb81
    jacobb81 Well-Known Member
    2018 Inferno TRD Offroad Manual
    Similar thing happened on our 4Runner. Couple months ago it was throwing P2111 code. I cleared it and it worked fine until yesterday and it threw it again. Took it to dealer and they said it needs a new throttle body (I assumed it was under warranty which is why I took it to dealer). However the throttle body isn’t covered under power train warranty (it is in California however). They said it would be about $700 to fix (they also said I need a $45 cabin air filter change, $35 engine air filter, and $135 “brake fluid service”) for a grand total of about $1000 . So I’ll pull the throttle body off this weekend and try cleaning it myself. Only has about 45k miles on the vehicle. Disappointed I blew 99 bucks for them to read the code, disappointed the part isn’t covered by power train warranty, disappointed I’m having issues at less than 50k miles.
  20. Jan 22, 2020 at 7:18 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Hmmm, the TB is part of the engine AND part of the emission system, I'd bypass the dealer and see if you can get a straight answer from Toyota.
    I could see it not covered if it was just dirty but if you actually need a new one.........
    robssol likes this.
