Check Engine and Trac Off
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lconhare, Dec 11, 2019.
  1. Jan 22, 2020 at 7:38 PM
    andrewkissam
    andrewkissam Well-Known Member
    Dallas, Texas
    2017 Tacoma TRD Sport, DCSB, Silver Sky Metallic
    heritage grille, TRD beadlock wheels, TRD exhaust, TRD intake, rokblokz mudflaps, BFG KO2s 265/75r16, Toytec front spacer leveling kit, 2nd gen running boards, chin spoiler delete, MESO gasshole, Toyota bed mat, Toyota all weather floor mats, Tufskinz doorsill protectors, Diode Dynamics LED headlight conversion, LED reverse and plate lights, LED interior lights, Diode Dynamics 30" stealth light bar, TRD shift knob, TRD start button
    WHY ARE WE YELLING?!
    Chew likes this.
  2. Jan 24, 2020 at 9:47 AM
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    Well...ok so the day after posting that mine was fixed it did it again...I KNOW I had the gas cap on tight. It seems to be happening around the time to fill up so I filled up, clicked the cap 3x's, and reset the light...I'm at half a tank now we'll see if it comes back on and when. If it comes back on this time I'll take it to the dealer with all the info, at least I'll have timeframes of exactly what's occurring on my truck
    BTW, since it was asked of op, my engine filter is clean, was changed a bit before I bought it, looks like oem quality one
  3. Jan 24, 2020 at 5:01 PM
    CODSWALLOP
    CODSWALLOP Well-Known Member
    2019 Tacoma TRD ORSB
    skewp hood, running boards
    Because I was at work and all the programs we use only work in all caps.
    Superdave1.0 likes this.
  4. Jan 24, 2020 at 6:56 PM
    Link master
    Link master Well-Known Member
    2016 Tacoma inferno trd off road dcsb
    Arb summit bumper. Morimoto led headlights and new grill. Grill and lights have sequential turn signals.
    I have the same issue, the lights came on after I had my arb bumper, new morimoto led headlights and new grill with lights installed.
    Have put in several full tanks since and I know the cap is locked.
    I hit a local auto parts shop that does free scanning and they said several sensors are the cause, oxygen sensor and something on exhaust.
    It's a 16 dc or with less then 45k miles
    Also if you have not checked, the crawl control and other options don't work.
    4 hi and lo and dif lock do work.
  5. Feb 16, 2020 at 2:22 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Filler cap wasn't tight. Fixed that and dcrc'd B- and it's all good.
  6. Feb 16, 2020 at 7:50 PM
    Link master
    Found out what mine was.
    Some of the extra lights was powered with a add a fuse in the fuse box under the hood.
    It caused a false read in the ecm.
    Guess that's not the place to tap for power for extra drl lights.
  7. Apr 11, 2020 at 5:04 PM
    Gianootz
    Gianootz New Member
    2006 Toyota Tacoma TRD Off-Road
    CAI, Throttle Body Spacer
    Having a similar issue with my 06 Prerunner TRD V6. Bought the truck May of 2019 with 124k miles, previous owners took meticulous care of this truck. Drove it up to Virginia and back with no problem at all. One day my check engine light comes on, with no noticeable change in how it runs/sounds/feels. Cleaned the air intake filter, took it to autozone and the codes read P0174 and P0171, both banks reading lean. Take it to a local reputable family-owned mechanic, he runs the sames codes...but says he's getting contradicting readings that they are showing too lean and too rich. Ultimately he found a deteriorated MAF Sensor o-ring, which was replaced and he cleaned the throttle body. The code was cleared and didn't return. After about one week of driving a maximum of 40 mph, I get on the highway...and it seemed as though as soon as I got up to 60mph the CEL comes back on....any thoughts?
